Flexcan, before send data, status the RAMn4 and RAMn5
已解决
跳至解决方案
2,003 次查看
buccno
I wonder why this change happens.
标记 (1)
1 解答
1,978 次查看
Senlent
Hi@buccno
Q1.you can take a look at the S32-RM Chapter 55.4.3 Message buffer structure-
>CODE->Message Buffer Code,
Both receiving and sending will query and update the CODE area.
Q2.You mean to parse a frame of data, which can be achieved by a shift operation, for example:
bit1~3 = (recvBuff.data[0] >> 1) & 0x07;;
在原帖中查看解决方案
2 回复数
1,996 次查看
buccno
I'm confused about one more thing, For example, I have a 64-bit length message with a single ID. how can I get bit 4.(starter bit),(length 4 bit), and bit (starter bit)50.(length 4 bit)?
1,979 次查看
Senlent
Hi@buccno
