FlexIO pin config
FlexIO pin config
1,367件の閲覧回数
yuegao1996
hi,
the manual says the pin can be
00b - Timer pin output disabled
01b - Timer pin open drain or bidirectional output enable
10b - Timer pin bidirectional output data
11b - Timer pin output
does this mean:
00- inpput and 11 - output
whats  ''01b'' and '10b' refer to ?
thanks!
1,348件の閲覧回数
lukaszadrapa
take a look at this description:
Input, output and open drain are clear, I think. Bidirectional output then can be used to emulate data bus when you need both read and write operation on such bus.
Lukas
