Flash Write
Flash Write
1,437 次查看
lohrsistemas
How I write only 4 byte in flash memory? I'm using S32k144.
1,104 次查看
danielmartynek
There is a flash example, which shows how to erase/program the flash, in the document section of this page.
The minimum you can write is an 8-byte phrase.
You can fill the rest of bytes (FCCOB registers) you don’t want to write to with 0xFF.
