Faults occurred during S32K debugging using PE
Kevin-Roman
Hello:
     When I use PE to debug 148 chip, the following error occurs, why is this
     1、PEmicro GDB Launch Failure : Error during flash programming. Terminating debug session.
I hope any engineers who see it can help me out.
Thank you
Robin_Shen
Hi Kevin-Roman,
What's version of S32DS are you using? Please update the GNU ARM PEMicro Interface Debugging Support in S32DS Extensions and Updates.
Do you also encounter this problem when testing the examples in the S32 SDK?
Robin
