Facing the HSE_SRV_RSP_INVALID_ADDR issue while importing authenticated key in NVM catalog
ソリューションへジャンプ
775件の閲覧回数
KaleRushikesh
Hi NXP Team,
I am currently working with the HSE on S32K3xx and attempting to import an authorized key into an NVM Key Catalog Slot.
To achieve this, I created a container and performed CMAC to obtain the TAG. However, when I used the Import service to import the key, I received the response HSE_SRV_RSP_INVALID_ADDR from the HSE.
Could you please review the provided code snippet and guide me on how to correctly carry out this operation?
uint8_t keyContainer[496] __attribute__((section(".mcal_bss_no_cacheable")));
static hseKeyInfo_t AuthkeyInfo __attribute__((section(".mcal_data_no_cacheable")));
uint8_t containerTag[16]__attribute__((section(".mcal_bss_no_cacheable")));
uint32_t containerTagLen __attribute__((section(".mcal_data_no_cacheable"))) = sizeof(containerTag);
//void fillContainer(uint8_t* pContainer, hseKeyInfo_t* pkeyInfo, uint8_t keyInfoLen, uint8_t* pkey, uint8_t keyLen)
void fillContainer(void)
AuthkeyInfo.keyBitLen = 128;
AuthkeyInfo.keyType = HSE_KEY_TYPE_AES;
AuthkeyInfo.keyFlags = HSE_KF_USAGE_ENCRYPT | HSE_KF_USAGE_DECRYPT; //| HSE_KF_USAGE_KEY_PROVISION;
AuthkeyInfo.keyCounter = 0; // first time while NVM key importing it should be greater than or equal to 0.
AuthkeyInfo.smrFlags = 0;
AuthkeyInfo.specific.aesBlockModeMask = HSE_KU_AES_BLOCK_MODE_ANY;
unsigned int i = 0;
i= i + 10;
memcpy(&keyContainer[i],&AuthkeyInfo,sizeof(hseKeyInfo_t));
i= i+sizeof(hseKeyInfo_t);
i= i+5;
memcpy(&keyContainer[i], App_au8EncAesNvmKey,sizeof(App_au8EncAesNvmKey));
hseSrvResponse_t AppGenCmac(void)
uint8_t u8MuInstance = 0U;
hseSrvDescriptor_t* pCmacGenSrvDescriptor;
hseSrvResponse_t RetVal = HSE_SRV_RSP_GENERAL_ERROR;
uint8_t muChannel = Hse_Ip_GetFreeChannel(u8MuInstance);
pCmacGenSrvDescriptor = &Hse_aSrvDescriptor[muChannel];
hseMacSrv_t* pMacSrv =  &pCmacGenSrvDescriptor->hseSrv.macReq;
pCmacGenSrvDescriptor->srvId = HSE_SRV_ID_MAC;
pMacSrv->accessMode = HSE_ACCESS_MODE_ONE_PASS;
pMacSrv->sgtOption = HSE_SGT_OPTION_NONE;
pMacSrv->streamId = 0;
pMacSrv->authDir = HSE_AUTH_DIR_GENERATE;
pMacSrv->macScheme.macAlgo = HSE_MAC_ALGO_CMAC;
pMacSrv->macScheme.sch.cmac.cipherAlgo= HSE_CIPHER_ALGO_AES;
pMacSrv->keyHandle = GET_KEY_HANDLE(1,1,0); //Normal AES key
pMacSrv->inputLength = sizeof(keyContainer);
pMacSrv->pInput = (HOST_ADDR)keyContainer;
pMacSrv->pTagLength = (HOST_ADDR) &containerTagLen;
pMacSrv->pTag = (HOST_ADDR) containerTag;
HseIp_aRequest[muChannel].eReqType   = HSE_IP_REQTYPE_SYNC;
HseIp_aRequest[muChannel].u32Timeout = TIMEOUT_TICKS_U32;
/* Send the request to Hse Ip layer */
RetVal = Hse_Ip_ServiceRequest(u8MuInstance, muChannel, &HseIp_aRequest[muChannel], pCmacGenSrvDescriptor);
return RetVal;
  Can we import an encrypted key into the RAM/NVM catalog without using authentication if I have superuser rights?
- No. The HSE Service API reference manual explicitly says:
“An encrypted key can be imported only authenticated.”
This is valid for both User rights and SuperUser rights.
static hseSrvResponse_t App_AesLoadAuthNvmKey(void)
hseSrvDescriptor_t *pHseSrvDescriptor;
uint8 u8MuChannel = Hse_Ip_GetFreeChannel(MU0_INSTANCE_U8);
if(HSE_IP_INVALID_MU_CHANNEL_U8 != u8MuChannel)
pHseSrvDescriptor   = &Hse_aSrvDescriptor[u8MuChannel];
memset(pHseSrvDescriptor, 0, sizeof(hseSrvDescriptor_t));
pHseSrvDescriptor->srvId = HSE_SRV_ID_IMPORT_KEY;
pHseSrvDescriptor->hseSrv.importKeyReq.keyLen[2] = 16;
pHseSrvDescriptor->hseSrv.importKeyReq.pKey[2] = HSE_PTR_TO_HOST_ADDR(App_au8EncAesNvmKey);
pHseSrvDescriptor->hseSrv.importKeyReq.pKeyInfo= HSE_PTR_TO_HOST_ADDR(&AuthkeyInfo);
pHseSrvDescriptor->hseSrv.importKeyReq.targetKeyHandle = GET_KEY_HANDLE(1,1,2);
// Both the fields given below must be configured.
pHseSrvDescriptor->hseSrv.importKeyReq.cipher.cipherKeyHandle = HSE_INVALID_KEY_HANDLE;
// pHseSrvDescriptor->hseSrv.importKeyReq.cipher.cipherScheme.symCipher.cipherAlgo = HSE_CIPHER_ALGO_AES ;
// pHseSrvDescriptor->hseSrv.importKeyReq.cipher.cipherScheme.symCipher.cipherBlockMode = HSE_CIPHER_BLOCK_MODE_ECB ;
// pHseSrvDescriptor->hseSrv.importKeyReq.cipher.cipherScheme.symCipher.ivLength = ;
// pHseSrvDescriptor->hseSrv.importKeyReq.cipher.cipherScheme.symCipher.pIV = ;
pHseSrvDescriptor->hseSrv.importKeyReq.keyContainer.authKeyHandle = GET_KEY_HANDLE(1,1,0);
pHseSrvDescriptor->hseSrv.importKeyReq.keyContainer.authLen[0] = containerTagLen;
pHseSrvDescriptor->hseSrv.importKeyReq.keyContainer.authScheme.macScheme.macAlgo = HSE_MAC_ALGO_CMAC ;
pHseSrvDescriptor->hseSrv.importKeyReq.keyContainer.authScheme.macScheme.sch.cmac.cipherAlgo= HSE_CIPHER_ALGO_AES;
pHseSrvDescriptor->hseSrv.importKeyReq.keyContainer.keyContainerLen = sizeof(keyContainer);
pHseSrvDescriptor->hseSrv.importKeyReq.keyContainer.pAuth[0] = (HOST_ADDR)containerTag;
pHseSrvDescriptor->hseSrv.importKeyReq.keyContainer.pKeyContainer = (HOST_ADDR)keyContainer;
        /* Build the request to be sent to Hse Ip layer */
        HseIp_aRequest[u8MuChannel].eReqType   = HSE_IP_REQTYPE_SYNC;
        HseIp_aRequest[u8MuChannel].u32Timeout = TIMEOUT_TICKS_U32;
        RetVal = Hse_Ip_ServiceRequest(MU0_INSTANCE_U8, u8MuChannel, &HseIp_aRequest[u8MuChannel], pHseSrvDescriptor);
return RetVal;
Thank you for your support.
Best regards, Rushikesh
743件の閲覧回数
lukaszadrapa
Hi @KaleRushikesh
It looks like you are passing addresses of original key and KeyInfo:
But you need to use addresses of key and KeyInfo inside the container. If HSE finds out that you are trying to provide key and KeyInfo from addresses which do not fall within the container, it will return invalid address error.
Lukas
2 返答(返信)
653件の閲覧回数
KaleRushikesh
Thank you @lukaszadrapa.
It works.
744件の閲覧回数
lukaszadrapa
Hi @KaleRushikesh
Lukas
%3CLINGO-SUB%20id%3D%22lingo-sub-2380483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENVM%E3%82%AB%E3%82%BF%E3%83%AD%E3%82%B0%E3%81%AB%E8%AA%8D%E8%A8%BC%E6%B8%88%E3%81%BF%E3%82%AD%E3%83%BC%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81HSE_SRV_RSP_INVALID_ADDR%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2380483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81NXP%20%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AE%E7%9A%86%E6%A7%98%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%8F%BE%E5%9C%A8%E3%80%81S32K3xx%E3%81%AEHSE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E8%AA%8D%E8%A8%BC%E6%B8%88%E3%81%BF%E3%82%AD%E3%83%BC%E3%82%92NVM%E3%82%AD%E3%83%BC%E3%82%AB%E3%82%BF%E3%83%AD%E3%82%B0%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%AB%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81CMAC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6TAG%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AD%E3%83%BC%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81HSE%20%E3%81%8B%E3%82%89%3CSTRONG%3EHSE_SRV_RSP_INVALID_ADDR%20%E3%81%A8%E3%81%84%E3%81%86%3C%2FSTRONG%3E%E5%BF%9C%E7%AD%94%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%82%B9%E3%83%8B%E3%83%9A%E3%83%83%E3%83%88%E3%82%92%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%93%E3%81%AE%E6%93%8D%E4%BD%9C%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%94%E6%8C%87%E5%B0%8E%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3Euint8_t%20keyContainer%5B496%5D%20__attribute__%20((section(%22.mcal_bss_no_cacheable%22)))%3B%3C%2FDIV%3E%3CDIV%3Estatic%20hseKeyInfo_t%20AuthkeyInfo%20__attribute__%20((section(%22.mcal_data_no_cacheable%22)))%3B%3C%2FDIV%3E%3CDIV%3Euint8_t%20containerTag%5B16%5D%20__attribute__%20((section(%22.mcal_bss_no_cacheable%22)))%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20containerTagLen%20__attribute__%20((section(%22.mcal_data_no_cacheable%22)))%20%3D%20sizeof(containerTag)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F%2Fvoid%20fillContainer(uint8_t*%20pContainer%2C%20hseKeyInfo_t*%20pkeyInfo%2C%20uint8_t%20keyInfoLen%2C%20uint8_t*%20pkey%2C%20uint8_t%20keyLen)%3C%2FDIV%3E%3CDIV%3Evoid%20fillContainer(void)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EAuthkeyInfo.keyBitLen%20%3D%20128%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EAuthkeyInfo.keyType%20%3D%20HSE_KEY_TYPE_AES%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EAuthkeyInfo.keyFlags%20%3D%20HSE_KF_USAGE_ENCRYPT%20%7C%20HSE_KF_USAGE_DECRYPT%3B%20%2F%2F%7C%20HSE_KF_USAGE_KEY_PROVISION%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EAuthkeyInfo.keyCounter%20%3D%200%3B%20%2F%2F%20NVM%E3%82%AD%E3%83%BC%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E9%9A%9B%E3%80%81%E5%88%9D%E5%9B%9E%E3%81%AF0%E4%BB%A5%E4%B8%8A%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EAuthkeyInfo.smrFlags%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EAuthkeyInfo.specific.aesBlockModeMask%3D%20HSE_KU_AES_BLOCK_MODE_ANY%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eunsigned%20int%20i%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ei%20%3D%20i%20%2B%2010%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ememcpy(%26amp%3BkeyContainer%5Bi%5D%2C%26amp%3BAuthkeyInfo%2Csizeof(hseKeyInfo_t))%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ei%20%3D%20i%20%2B%20sizeof(hseKeyInfo_t)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ei%20%3D%20i%20%2B%205%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ememcpy(%26amp%3BkeyContainer%5Bi%5D%2C%20App_au8EncAesNvmKey%2Csizeof(App_au8EncAesNvmKey))%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EhseSrvResponse_t%20AppGenCmac(void)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euint8_t%20u8MuInstance%20%3D%200U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EhseSrvDescriptor_t*%20pCmacGenSrvDescriptor%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EhseSrvResponse_t%20RetVal%20%3D%20HSE_SRV_RSP_GENERAL_ERROR%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euint8_t%20muChannel%20%3D%20Hse_Ip_GetFreeChannel(u8MuInstance)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpCmacGenSrvDescriptor%20%3D%20%26amp%3BHse_aSrvDescriptor%5BmuChannel%5D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EhseMacSrv_t*%20pMacSrv%20%3D%20%26amp%3BpCmacGenSrvDescriptor-%26gt%3BhseSrv.macReq%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpCmacGenSrvDescriptor-%26gt%3BsrvId%20%3D%20HSE_SRV_ID_MAC%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BaccessMode%20%3D%20HSE_ACCESS_MODE_ONE_PASS%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BsgtOption%20%3D%20HSE_SGT_OPTION_NONE%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BstreamId%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BauthDir%20%3D%20HSE_AUTH_DIR_GENERATE%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BmacScheme.macAlgo%20%3D%20HSE_MAC_ALGO_CMAC%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BmacScheme.sch.cmac.cipherAlgo%3DHSE_CIPHER_ALGO_AES%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BkeyHandle%20%3D%20GET_KEY_HANDLE(1%2C1%2C0)%3B%20%2F%2F%20%E9%80%9A%E5%B8%B8%E3%81%AEAES%E3%82%AD%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BinputLength%20%3D%20sizeof(keyContainer)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BpInput%20%3D%20(HOST_ADDR)keyContainer%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BpTagLength%20%3D%20(HOST_ADDR)%20%26amp%3BcontainerTagLen%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BpTag%20%3D%20(HOST_ADDR)%20containerTag%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EHseIp_aRequest%5BmuChannel%5D.eReqType%20%3D%20HSE_IP_REQTYPE_SYNC%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EHseIp_aRequest%5BmuChannel%5D.u32Timeout%20%3D%20TIMEOUT_TICKS_U32%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%92Hse%20IP%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ERetVal%20%3D%20Hse_Ip_ServiceRequest(u8MuInstance%2C%20muChannel%2C%20%26amp%3BHseIp_aRequest%5BmuChannel%5D%2C%20pCmacGenSrvDescriptor)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ERetVal%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F*%3C%2FDIV%3E%3CDIV%3E%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E6%A8%A9%E9%99%90%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E8%AA%8D%E8%A8%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%9B%E3%81%9A%E3%81%AB%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AD%E3%83%BC%E3%82%92RAM%2FNVM%E3%82%AB%E3%82%BF%E3%83%AD%E3%82%B0%E3%81%AB%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%81%84%E3%81%84%E3%81%88%E3%80%82HSE%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9API%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%98%8E%E8%A8%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%80%8C%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AD%E3%83%BC%E3%81%AF%E3%80%81%E8%AA%8D%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BF%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%80%8D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E6%A8%A9%E9%99%90%E3%81%A8%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E6%A8%A9%E9%99%90%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AB%E5%BD%93%E3%81%A6%E3%81%AF%E3%81%BE%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Estatic%20hseSrvResponse_t%20App_AesLoadAuthNvmKey(void)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EhseSrvResponse_t%20RetVal%20%3D%20HSE_SRV_RSP_GENERAL_ERROR%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EhseSrvDescriptor_t%20*pHseSrvDescriptor%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euint8%20u8MuChannel%20%3D%20Hse_Ip_GetFreeChannel(MU0_INSTANCE_U8)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif(HSE_IP_INVALID_MU_CHANNEL_U8%20!%3D%20u8MuChannel)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor%20%3D%20%26amp%3BHse_aSrvDescriptor%5Bu8MuChannel%5D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ememset(pHseSrvDescriptor%2C%200%2C%20sizeof(hseSrvDescriptor_t))%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BsrvId%20%3D%20HSE_SRV_ID_IMPORT_KEY%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.keyLen%5B2%5D%3D%2016%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.pKey%5B2%5D%3D%20HSE_PTR_TO_HOST_ADDR(App_au8EncAesNvmKey)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.pKeyInfo%3DHSE_PTR_TO_HOST_ADDR(%26amp%3BAuthkeyInfo)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.targetKeyHandle%3D%20GET_KEY_HANDLE(1%2C1%2C2)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2F%20%E4%BB%A5%E4%B8%8B%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.cipher.cipherKeyHandle%3D%20HSE_INVALID_KEY_HANDLE%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%2F%2F%20pHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.cipher.cipherScheme.symCipher.cipherAlgo%20%3D%20HSE_CIPHER_ALGO_AES%20%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20pHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.cipher.cipherScheme.symCipher.cipherBlockMode%3D%20HSE_CIPHER_BLOCK_MODE_ECB%20%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20pHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.cipher.cipherScheme.symCipher.ivLength%20%3D%20%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20pHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.cipher.cipherScheme.symCipher.pIV%20%3D%20%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.keyContainer.authKeyHandle%3D%20GET_KEY_HANDLE(1%2C1%2C0)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.keyContainer.authLen%5B0%5D%3D%20containerTagLen%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.keyContainer.authScheme.macScheme.macAlgo%20%3D%20HSE_MAC_ALGO_CMAC%20%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.keyContainer.authScheme.macScheme.sch.cmac.cipherAlgo%3DHSE_CIPHER_ALGO_AES%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.keyContainer.keyContainerLen%3D%20sizeof(keyContainer)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.keyContainer.pAuth%5B0%5D%3D%20(HOST_ADDR)containerTag%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.keyContainer.pKeyContainer%3D%20(HOST_ADDR)%E3%82%AD%E3%83%BC%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F*%20HSE%20IP%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FDIV%3E%3CDIV%3EHseIp_aRequest%5Bu8MuChannel%5D.eReqType%20%3D%20HSE_IP_REQTYPE_SYNC%3B%3C%2FDIV%3E%3CDIV%3EHseIp_aRequest%5Bu8MuChannel%5D.u32Timeout%20%3D%20TIMEOUT_TICKS_U32%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F*%20%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%92Hse%20IP%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FDIV%3E%3CDIV%3ERetVal%20%3D%20Hse_Ip_ServiceRequest(MU0_INSTANCE_U8%2C%20u8MuChannel%2C%20%26amp%3BHseIp_aRequest%5Bu8MuChannel%5D%2C%20pHseSrvDescriptor)%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ERetVal%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%3E%E5%86%8D%E9%96%8B%E3%81%BE%E3%81%A7%E4%BB%8A%E3%81%97%E3%81%B0%E3%82%89%E3%81%8F%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%95%AC%E5%85%B7%E3%80%81%E3%83%AB%E3%82%B7%E3%82%B1%E3%82%B7%E3%83%A5%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2381475%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Facing%20the%20HSE_SRV_RSP_INVALID_ADDR%20issue%20while%20importing%20authenticated%20key%20in%20NVM%20catalog%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2381475%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%40lukaszadrapa%20%E3%81%95%E3%82%93%E3%80%81%3C%2FA%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2380844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Facing%20the%20HSE_SRV_RSP_INVALID_ADDR%20issue%20while%20importing%20authenticated%20key%20in%20NVM%20catalog%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2380844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253372%22%20target%3D%22_blank%22%3E%40KaleRushikesh%20%E3%81%95%E3%82%93%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%85%83%E3%81%AE%E3%82%AD%E3%83%BC%E3%81%A8KeyInfo%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E6%B8%A1%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%AD%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.pKey%5B2%5D%3D%20HSE_PTR_TO_HOST_ADDR(App_au8EncAesNvmKey)%3B%3C%2FP%3E%0A%3CP%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.pKeyInfo%3DHSE_PTR_TO_HOST_ADDR(%26amp%3BAuthkeyInfo)%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E5%86%85%E3%81%A7%E3%81%AF%E3%82%AD%E3%83%BC%E3%81%A8KeyInfo%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82HSE%E3%81%AF%E3%80%81%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%AA%E3%81%84%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8B%E3%82%89%E3%82%AD%E3%83%BC%E3%81%A8%E3%82%AD%E3%83%BC%E6%83%85%E5%A0%B1%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E7%84%A1%E5%8A%B9%E3%81%AA%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%AB%E3%83%BC%E3%82%AB%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E
