Facing the HSE_SRV_RSP_INVALID_ADDR issue while importing authenticated key in NVM catalog
KaleRushikesh
Hi NXP Team,
I am currently working with the HSE on S32K3xx and attempting to import an authorized key into an NVM Key Catalog Slot.
To achieve this, I created a container and performed CMAC to obtain the TAG. However, when I used the Import service to import the key, I received the response HSE_SRV_RSP_INVALID_ADDR from the HSE.
Could you please review the provided code snippet and guide me on how to correctly carry out this operation?
uint8_t keyContainer[496] __attribute__((section(".mcal_bss_no_cacheable")));
static hseKeyInfo_t AuthkeyInfo __attribute__((section(".mcal_data_no_cacheable")));
uint8_t containerTag[16]__attribute__((section(".mcal_bss_no_cacheable")));
uint32_t containerTagLen __attribute__((section(".mcal_data_no_cacheable"))) = sizeof(containerTag);
//void fillContainer(uint8_t* pContainer, hseKeyInfo_t* pkeyInfo, uint8_t keyInfoLen, uint8_t* pkey, uint8_t keyLen)
void fillContainer(void)
AuthkeyInfo.keyBitLen = 128;
AuthkeyInfo.keyType = HSE_KEY_TYPE_AES;
AuthkeyInfo.keyFlags = HSE_KF_USAGE_ENCRYPT | HSE_KF_USAGE_DECRYPT; //| HSE_KF_USAGE_KEY_PROVISION;
AuthkeyInfo.keyCounter = 0; // first time while NVM key importing it should be greater than or equal to 0.
AuthkeyInfo.smrFlags = 0;
AuthkeyInfo.specific.aesBlockModeMask = HSE_KU_AES_BLOCK_MODE_ANY;
unsigned int i = 0;
i= i + 10;
memcpy(&keyContainer[i],&AuthkeyInfo,sizeof(hseKeyInfo_t));
i= i+sizeof(hseKeyInfo_t);
i= i+5;
memcpy(&keyContainer[i], App_au8EncAesNvmKey,sizeof(App_au8EncAesNvmKey));
hseSrvResponse_t AppGenCmac(void)
uint8_t u8MuInstance = 0U;
hseSrvDescriptor_t* pCmacGenSrvDescriptor;
hseSrvResponse_t RetVal = HSE_SRV_RSP_GENERAL_ERROR;
uint8_t muChannel = Hse_Ip_GetFreeChannel(u8MuInstance);
pCmacGenSrvDescriptor = &Hse_aSrvDescriptor[muChannel];
hseMacSrv_t* pMacSrv =  &pCmacGenSrvDescriptor->hseSrv.macReq;
pCmacGenSrvDescriptor->srvId = HSE_SRV_ID_MAC;
pMacSrv->accessMode = HSE_ACCESS_MODE_ONE_PASS;
pMacSrv->sgtOption = HSE_SGT_OPTION_NONE;
pMacSrv->streamId = 0;
pMacSrv->authDir = HSE_AUTH_DIR_GENERATE;
pMacSrv->macScheme.macAlgo = HSE_MAC_ALGO_CMAC;
pMacSrv->macScheme.sch.cmac.cipherAlgo= HSE_CIPHER_ALGO_AES;
pMacSrv->keyHandle = GET_KEY_HANDLE(1,1,0); //Normal AES key
pMacSrv->inputLength = sizeof(keyContainer);
pMacSrv->pInput = (HOST_ADDR)keyContainer;
pMacSrv->pTagLength = (HOST_ADDR) &containerTagLen;
pMacSrv->pTag = (HOST_ADDR) containerTag;
HseIp_aRequest[muChannel].eReqType   = HSE_IP_REQTYPE_SYNC;
HseIp_aRequest[muChannel].u32Timeout = TIMEOUT_TICKS_U32;
/* Send the request to Hse Ip layer */
RetVal = Hse_Ip_ServiceRequest(u8MuInstance, muChannel, &HseIp_aRequest[muChannel], pCmacGenSrvDescriptor);
return RetVal;
  Can we import an encrypted key into the RAM/NVM catalog without using authentication if I have superuser rights?
- No. The HSE Service API reference manual explicitly says:
“An encrypted key can be imported only authenticated.”
This is valid for both User rights and SuperUser rights.
static hseSrvResponse_t App_AesLoadAuthNvmKey(void)
hseSrvDescriptor_t *pHseSrvDescriptor;
uint8 u8MuChannel = Hse_Ip_GetFreeChannel(MU0_INSTANCE_U8);
if(HSE_IP_INVALID_MU_CHANNEL_U8 != u8MuChannel)
pHseSrvDescriptor   = &Hse_aSrvDescriptor[u8MuChannel];
memset(pHseSrvDescriptor, 0, sizeof(hseSrvDescriptor_t));
pHseSrvDescriptor->srvId = HSE_SRV_ID_IMPORT_KEY;
pHseSrvDescriptor->hseSrv.importKeyReq.keyLen[2] = 16;
pHseSrvDescriptor->hseSrv.importKeyReq.pKey[2] = HSE_PTR_TO_HOST_ADDR(App_au8EncAesNvmKey);
pHseSrvDescriptor->hseSrv.importKeyReq.pKeyInfo= HSE_PTR_TO_HOST_ADDR(&AuthkeyInfo);
pHseSrvDescriptor->hseSrv.importKeyReq.targetKeyHandle = GET_KEY_HANDLE(1,1,2);
// Both the fields given below must be configured.
pHseSrvDescriptor->hseSrv.importKeyReq.cipher.cipherKeyHandle = HSE_INVALID_KEY_HANDLE;
// pHseSrvDescriptor->hseSrv.importKeyReq.cipher.cipherScheme.symCipher.cipherAlgo = HSE_CIPHER_ALGO_AES ;
// pHseSrvDescriptor->hseSrv.importKeyReq.cipher.cipherScheme.symCipher.cipherBlockMode = HSE_CIPHER_BLOCK_MODE_ECB ;
// pHseSrvDescriptor->hseSrv.importKeyReq.cipher.cipherScheme.symCipher.ivLength = ;
// pHseSrvDescriptor->hseSrv.importKeyReq.cipher.cipherScheme.symCipher.pIV = ;
pHseSrvDescriptor->hseSrv.importKeyReq.keyContainer.authKeyHandle = GET_KEY_HANDLE(1,1,0);
pHseSrvDescriptor->hseSrv.importKeyReq.keyContainer.authLen[0] = containerTagLen;
pHseSrvDescriptor->hseSrv.importKeyReq.keyContainer.authScheme.macScheme.macAlgo = HSE_MAC_ALGO_CMAC ;
pHseSrvDescriptor->hseSrv.importKeyReq.keyContainer.authScheme.macScheme.sch.cmac.cipherAlgo= HSE_CIPHER_ALGO_AES;
pHseSrvDescriptor->hseSrv.importKeyReq.keyContainer.keyContainerLen = sizeof(keyContainer);
pHseSrvDescriptor->hseSrv.importKeyReq.keyContainer.pAuth[0] = (HOST_ADDR)containerTag;
pHseSrvDescriptor->hseSrv.importKeyReq.keyContainer.pKeyContainer = (HOST_ADDR)keyContainer;
        /* Build the request to be sent to Hse Ip layer */
        HseIp_aRequest[u8MuChannel].eReqType   = HSE_IP_REQTYPE_SYNC;
        HseIp_aRequest[u8MuChannel].u32Timeout = TIMEOUT_TICKS_U32;
        RetVal = Hse_Ip_ServiceRequest(MU0_INSTANCE_U8, u8MuChannel, &HseIp_aRequest[u8MuChannel], pHseSrvDescriptor);
return RetVal;
Thank you for your support.
Best regards, Rushikesh
lukaszadrapa
Hi @KaleRushikesh
It looks like you are passing addresses of original key and KeyInfo:
But you need to use addresses of key and KeyInfo inside the container. If HSE finds out that you are trying to provide key and KeyInfo from addresses which do not fall within the container, it will return invalid address error.
Lukas
KaleRushikesh
Thank you @lukaszadrapa.
It works.
lukaszadrapa
Hi @KaleRushikesh
Lukas
%3CLINGO-SUB%20id%3D%22lingo-sub-2380483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFacing%20the%20HSE_SRV_RSP_INVALID_ADDR%20issue%20while%20importing%20authenticated%20key%20in%20NVM%20catalog%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2380483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHi%20NXP%20Team%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EI%20am%20currently%20working%20with%20the%20HSE%20on%20S32K3xx%20and%20attempting%20to%20import%20an%20authorized%20key%20into%20an%20NVM%20Key%20Catalog%20Slot.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ETo%20achieve%20this%2C%20I%20created%20a%20container%20and%20performed%20CMAC%20to%20obtain%20the%20TAG.%20However%2C%20when%20I%20used%20the%20Import%20service%20to%20import%20the%20key%2C%20I%20received%20the%20response%20%3CSTRONG%3EHSE_SRV_RSP_INVALID_ADDR%3C%2FSTRONG%3E%20from%20the%20HSE.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ECould%20you%20please%20review%20the%20provided%20code%20snippet%20and%20guide%20me%20on%20how%20to%20correctly%20carry%20out%20this%20operation%3F%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3Euint8_t%20keyContainer%5B496%5D%20__attribute__((section(%22.mcal_bss_no_cacheable%22)))%3B%3C%2FDIV%3E%3CDIV%3Estatic%20hseKeyInfo_t%20AuthkeyInfo%20__attribute__((section(%22.mcal_data_no_cacheable%22)))%3B%3C%2FDIV%3E%3CDIV%3Euint8_t%20containerTag%5B16%5D__attribute__((section(%22.mcal_bss_no_cacheable%22)))%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20containerTagLen%20__attribute__((section(%22.mcal_data_no_cacheable%22)))%20%3D%20sizeof(containerTag)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F%2Fvoid%20fillContainer(uint8_t*%20pContainer%2C%20hseKeyInfo_t*%20pkeyInfo%2C%20uint8_t%20keyInfoLen%2C%20uint8_t*%20pkey%2C%20uint8_t%20keyLen)%3C%2FDIV%3E%3CDIV%3Evoid%20fillContainer(void)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EAuthkeyInfo.keyBitLen%20%3D%20128%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EAuthkeyInfo.keyType%20%3D%20HSE_KEY_TYPE_AES%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EAuthkeyInfo.keyFlags%20%3D%20HSE_KF_USAGE_ENCRYPT%20%7C%20HSE_KF_USAGE_DECRYPT%3B%20%2F%2F%7C%20HSE_KF_USAGE_KEY_PROVISION%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EAuthkeyInfo.keyCounter%20%3D%200%3B%20%2F%2F%20first%20time%20while%20NVM%20key%20importing%20it%20should%20be%20greater%20than%20or%20equal%20to%200.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EAuthkeyInfo.smrFlags%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EAuthkeyInfo.specific.aesBlockModeMask%20%3D%20HSE_KU_AES_BLOCK_MODE_ANY%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eunsigned%20int%20i%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ei%3D%20i%20%2B%2010%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ememcpy(%26amp%3BkeyContainer%5Bi%5D%2C%26amp%3BAuthkeyInfo%2Csizeof(hseKeyInfo_t))%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ei%3D%20i%2Bsizeof(hseKeyInfo_t)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ei%3D%20i%2B5%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ememcpy(%26amp%3BkeyContainer%5Bi%5D%2C%20App_au8EncAesNvmKey%2Csizeof(App_au8EncAesNvmKey))%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EhseSrvResponse_t%20AppGenCmac(void)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euint8_t%20u8MuInstance%20%3D%200U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EhseSrvDescriptor_t*%20pCmacGenSrvDescriptor%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EhseSrvResponse_t%20RetVal%20%3D%20HSE_SRV_RSP_GENERAL_ERROR%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euint8_t%20muChannel%20%3D%20Hse_Ip_GetFreeChannel(u8MuInstance)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpCmacGenSrvDescriptor%20%3D%20%26amp%3BHse_aSrvDescriptor%5BmuChannel%5D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EhseMacSrv_t*%20pMacSrv%20%3D%26nbsp%3B%20%26amp%3BpCmacGenSrvDescriptor-%26gt%3BhseSrv.macReq%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpCmacGenSrvDescriptor-%26gt%3BsrvId%20%3D%20HSE_SRV_ID_MAC%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BaccessMode%20%3D%20HSE_ACCESS_MODE_ONE_PASS%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BsgtOption%20%3D%20HSE_SGT_OPTION_NONE%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BstreamId%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BauthDir%20%3D%20HSE_AUTH_DIR_GENERATE%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BmacScheme.macAlgo%20%3D%20HSE_MAC_ALGO_CMAC%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BmacScheme.sch.cmac.cipherAlgo%3D%20HSE_CIPHER_ALGO_AES%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BkeyHandle%20%3D%20GET_KEY_HANDLE(1%2C1%2C0)%3B%20%2F%2FNormal%20AES%20key%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BinputLength%20%3D%20sizeof(keyContainer)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BpInput%20%3D%20(HOST_ADDR)keyContainer%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BpTagLength%20%3D%20(HOST_ADDR)%20%26amp%3BcontainerTagLen%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpMacSrv-%26gt%3BpTag%20%3D%20(HOST_ADDR)%20containerTag%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EHseIp_aRequest%5BmuChannel%5D.eReqType%26nbsp%3B%20%26nbsp%3B%3D%20HSE_IP_REQTYPE_SYNC%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EHseIp_aRequest%5BmuChannel%5D.u32Timeout%20%3D%20TIMEOUT_TICKS_U32%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20Send%20the%20request%20to%20Hse%20Ip%20layer%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ERetVal%20%3D%20Hse_Ip_ServiceRequest(u8MuInstance%2C%20muChannel%2C%20%26amp%3BHseIp_aRequest%5BmuChannel%5D%2C%20pCmacGenSrvDescriptor)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereturn%20RetVal%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F*%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20Can%20we%20import%20an%20encrypted%20key%20into%20the%20RAM%2FNVM%20catalog%20without%20using%20authentication%20if%20I%20have%20superuser%20rights%3F%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-%20No.%20The%20HSE%20Service%20API%20reference%20manual%20explicitly%20says%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E2%80%9CAn%20encrypted%20key%20can%20be%20imported%20only%20authenticated.%E2%80%9D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EThis%20is%20valid%20for%20both%20User%20rights%20and%20SuperUser%20rights.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Estatic%20hseSrvResponse_t%20App_AesLoadAuthNvmKey(void)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EhseSrvResponse_t%20RetVal%20%3D%20HSE_SRV_RSP_GENERAL_ERROR%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EhseSrvDescriptor_t%20*pHseSrvDescriptor%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euint8%20u8MuChannel%20%3D%20Hse_Ip_GetFreeChannel(MU0_INSTANCE_U8)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif(HSE_IP_INVALID_MU_CHANNEL_U8%20!%3D%20u8MuChannel)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor%26nbsp%3B%20%26nbsp%3B%3D%20%26amp%3BHse_aSrvDescriptor%5Bu8MuChannel%5D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ememset(pHseSrvDescriptor%2C%200%2C%20sizeof(hseSrvDescriptor_t))%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BsrvId%20%3D%20HSE_SRV_ID_IMPORT_KEY%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.keyLen%5B2%5D%20%3D%2016%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.pKey%5B2%5D%20%3D%20HSE_PTR_TO_HOST_ADDR(App_au8EncAesNvmKey)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.pKeyInfo%3D%20HSE_PTR_TO_HOST_ADDR(%26amp%3BAuthkeyInfo)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.targetKeyHandle%20%3D%20GET_KEY_HANDLE(1%2C1%2C2)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2F%20Both%20the%20fields%20given%20below%20must%20be%20configured.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.cipher.cipherKeyHandle%20%3D%20HSE_INVALID_KEY_HANDLE%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%2F%2F%20pHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.cipher.cipherScheme.symCipher.cipherAlgo%20%3D%20HSE_CIPHER_ALGO_AES%20%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20pHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.cipher.cipherScheme.symCipher.cipherBlockMode%20%3D%20HSE_CIPHER_BLOCK_MODE_ECB%20%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20pHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.cipher.cipherScheme.symCipher.ivLength%20%3D%20%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20pHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.cipher.cipherScheme.symCipher.pIV%20%3D%20%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.keyContainer.authKeyHandle%20%3D%20GET_KEY_HANDLE(1%2C1%2C0)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.keyContainer.authLen%5B0%5D%20%3D%20containerTagLen%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.keyContainer.authScheme.macScheme.macAlgo%20%3D%20HSE_MAC_ALGO_CMAC%20%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.keyContainer.authScheme.macScheme.sch.cmac.cipherAlgo%3D%20HSE_CIPHER_ALGO_AES%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.keyContainer.keyContainerLen%20%3D%20sizeof(keyContainer)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.keyContainer.pAuth%5B0%5D%20%3D%20(HOST_ADDR)containerTag%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.keyContainer.pKeyContainer%20%3D%20(HOST_ADDR)keyContainer%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%2F*%20Build%20the%20request%20to%20be%20sent%20to%20Hse%20Ip%20layer%20*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20HseIp_aRequest%5Bu8MuChannel%5D.eReqType%26nbsp%3B%20%26nbsp%3B%3D%20HSE_IP_REQTYPE_SYNC%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20HseIp_aRequest%5Bu8MuChannel%5D.u32Timeout%20%3D%20TIMEOUT_TICKS_U32%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%2F*%20Send%20the%20request%20to%20Hse%20Ip%20layer%20*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20RetVal%20%3D%20Hse_Ip_ServiceRequest(MU0_INSTANCE_U8%2C%20u8MuChannel%2C%20%26amp%3BHseIp_aRequest%5Bu8MuChannel%5D%2C%20pHseSrvDescriptor)%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereturn%20RetVal%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%3EThank%20you%20for%20your%20support.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBest%20regards%2C%20Rushikesh%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2381475%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Facing%20the%20HSE_SRV_RSP_INVALID_ADDR%20issue%20while%20importing%20authenticated%20key%20in%20NVM%20catalog%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2381475%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%40lukaszadrapa%3C%2FA%3E.%3CBR%20%2F%3EIt%20works.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2380844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Facing%20the%20HSE_SRV_RSP_INVALID_ADDR%20issue%20while%20importing%20authenticated%20key%20in%20NVM%20catalog%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2380844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253372%22%20target%3D%22_blank%22%3E%40KaleRushikesh%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EIt%20looks%20like%20you%20are%20passing%20addresses%20of%20original%20key%20and%20KeyInfo%3A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.pKey%5B2%5D%20%3D%20HSE_PTR_TO_HOST_ADDR(App_au8EncAesNvmKey)%3B%3C%2FP%3E%0A%3CP%3EpHseSrvDescriptor-%26gt%3BhseSrv.importKeyReq.pKeyInfo%3D%20HSE_PTR_TO_HOST_ADDR(%26amp%3BAuthkeyInfo)%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBut%20you%20need%20to%20use%20addresses%20of%20key%20and%20KeyInfo%20inside%20the%20container.%20If%20HSE%20finds%20out%20that%20you%20are%20trying%20to%20provide%20key%20and%20KeyInfo%20from%20addresses%20which%20do%20not%20fall%20within%20the%20container%2C%20it%20will%20return%20invalid%20address%20error.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E
