FS32K144UAT0VLLT ASIL B Report
1,571件の閲覧回数
damonmeng
I need the FS32K144UAT0VLLT ASIL B Report,Can you send me the report?
3 返答(返信)
1,547件の閲覧回数
davidtosenovjan
A safety documentation you may find as a secure file on the product webpage (section 'documentation'), so following procedure is needed to follow unless you have already done it before:
https://www.nxp.com/docs/en/user-guide/nxp-secure-access-rights-registration.pdf
1,531件の閲覧回数
damonmeng
What I need is the ASIL B certification certificate. Are these four documents? Or which one is the ASIL B certification certificate?
1,526件の閲覧回数
davidtosenovjan
We have only external ISO 26262 ASIL-D certificate for MPC5643L device, it is “Type Approval Certificate”:
https://www.nxp.com/docs/en/supporting-information/C26262_MPC5643L.pdf
No other MCU has been externally certified and is also not planned (ISO 26262 only requires an independent assessment, which can also be internal). Company is certified as a whole.
If you have allowed secure access, you can download Assessment / Confirmation Measurement Report for specific device.
