FS26 VREF Output voltage not stable
1,039件の閲覧回数
GNANAPANDI
FS26 VREF Output voltage not stable but all other voltage are get and stable
LDO1, LDO2< VTRIK1, VTRIK2, VCORE
FS36 Part no. MFS2613AMD3D
1,016件の閲覧回数
TomasVaverka
Could you please share your schematic or at least part of your schematic with VREF?
Are you using the recommended input and outputs caps?
How big is the fluctuation of VREF and is it the same on all FS26 devices you have tested?
BRs, Tomas
