FS26 CAN'T NOT RESET S32K3
2,381 次查看
Wade0905
I am developing on the S32K314 with the FS26, using the RTD layer.
Currently, I am facing an issue with the FS26 can't reset MCU.
The FS26 successfully enters the NORMAL state, but when I intentionally stop feeding the watchdog, the RSTB pin is not pulled LOW, and the MCU is not reset.
Could you help me check what might be wrong? Thank you.
Please refer to the attached images for my configuration settings and the steps I used for the initialization.
6 回复数
2,174 次查看
petervlna
that is strange.
I had checked your registers:
If you read it back from FS26 is it really in normal mode?
Wade : Yes, I read FS_STATES by spi and it return 1011(normal).
1. your WDOG is not active
Wade : I read FS_I_WD_CFG by spi and it return 0101 1010 0001 0000 which same as my config.
WD_FS_REACTION[1:0]
Such config will trigger reset if the device is not in the debug mode.
2. you are in debug mode.
Wade : No, I read FS_STATES by spi and it return 1011(Not in DEBUG MODE).
That points to normal mode.
I am not sure what is happening at your side.
Can you check the reset line via scope, to see the reset is not pulled. Also do you see the same behaviour on NXP evaluation board?
What about debug pin, isnt it active?
By default, without any SBC configuration you reset is triggered, so there must be something in your SBC config which prevents reset to be executed from SBC to uC.
Did you tried our example SW for FS26 supplied with RTD package?
Peter
2,299 次查看
petervlna
Ok, thank you for explanation.
Besides, you also can see my configuration as attached, I select Debug mode exit.
OK, that is just checkbox in config GUI.
I tried flashing a version without any FS26 initialization, and in that version the FS26 continuously resets the MCU.
If FS26 was not initialized the WDOG will issue reset and reset phase will automatically start again.
Initialization phase must be closed with a good watchdog refresh before the 256 ms timeout. In case no watchdog refresh or a bad watchdog is sent during the initialization phase, an RSTB pulse is generated and the fault error counter is incremented by 1. A new initialization phase is automatically started when RSTB is released.
But debug mode is also held by debug pin active. But since the reset comes in case no init is done, I expect you do not have debug pin active.
However, when I flash back the version I provided to you (the software that includes the FS26 initialization), the FS26 no longer resets the MCU.
So, seems to me directly related to the code.
So there could be only 2 options I assume.
Otherwise the FS26 is issuing reset.
You can add check for FS26 mode Debug Mode Detection, to make sure after init of the SBC it is not in debug mode.
Also check  FS_I_WD_CFG
Peter
2,272 次查看
Wade0905
Hi Peter,
Please see my response in blue. Thanks.
Still haven’t found the root cause of why the watchdog does not trigger an MCU reset.
NORMAL & NOT IN DEBUG MODE.jpgNORMAL & NOT IN DEBUG MODE.jpgFS26_FS_I_WD_CFG_CODE.jpg
2,228 次查看
Wade0905
Hi Peter,
I missed one image in my previous post.
Please refer to it as well. Thank you.
2,356 次查看
petervlna
Could you share if you are using NXP evaluation board or your custom board?
Make sure your FS26 is not in debug mode. In such case the WDOG is disabled and will not react on timeout.
Peter
2,339 次查看
Wade0905
Hi Peter,
Thanks for your response.
I am developing on a custom board, and I can confirm that the hardware has already exited DEBUG MODE.
Please help to check whether there are any mistakes in the FS26 initialization process. Thank you.SETTING4.png
%3CLINGO-SUB%20id%3D%22lingo-sub-2252064%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFS26%20%E6%97%A0%E6%B3%95%20RESET%20S32K3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252064%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20RTD%20%E5%B1%82%E5%9C%A8%E5%B8%A6%E6%9C%89%20FS26%20%E7%9A%84%20S32K314%20%E4%B8%8A%E8%BF%9B%E8%A1%8C%E5%BC%80%E5%8F%91%E3%80%82%3CBR%20%2F%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%20FS26%20%E6%97%A0%E6%B3%95%20RESET%20MCU%20%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3EFS26%20%E6%88%90%E5%8A%9F%E8%BF%9B%E5%85%A5%E6%AD%A3%E5%B8%B8%E7%8A%B6%E6%80%81%EF%BC%8C%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E6%95%85%E6%84%8F%E5%81%9C%E6%AD%A2%E4%B8%BA%E7%9C%8B%E9%97%A8%E7%8B%97%E4%BE%9B%E7%94%B5%E6%97%B6%EF%BC%8CRSTB%20%E5%BC%95%E8%84%9A%E6%B2%A1%E6%9C%89%E8%A2%AB%E6%8B%89%E8%87%B3%E4%BD%8E%E7%94%B5%E5%B9%B3%EF%BC%8C%E4%B9%9F%E6%B2%A1%E6%9C%89%20RESET%20MCU%E3%80%82%3CBR%20%2F%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E6%88%91%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E5%8F%AF%E8%83%BD%E5%87%BA%E4%BA%86%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E8%B0%A2%E8%B0%A2%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%9C%89%E5%85%B3%E6%88%91%E7%9A%84%E9%85%8D%E7%BD%AE%E8%AE%BE%E7%BD%AE%E5%92%8C%E5%88%9D%E5%A7%8B%E5%8C%96%E6%AD%A5%E9%AA%A4%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E6%89%80%E9%99%84%E7%9A%84%E5%9B%BE%E7%89%87%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22SETTING1.png%22%20style%3D%22width%3A%20969px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING1.png%22%20style%3D%22width%3A%20969px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING1.png%22%20style%3D%22width%3A%20969px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING1.png%22%20style%3D%22width%3A%20969px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING1.png%22%20style%3D%22width%3A%20969px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING1.png%22%20style%3D%22width%3A%20969px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367935i4657B15BF27CF19C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SETTING1.png%22%20alt%3D%22SETTING1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22SETTING2.png%22%20style%3D%22width%3A%20938px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING2.png%22%20style%3D%22width%3A%20938px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING2.png%22%20style%3D%22width%3A%20938px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING2.png%22%20style%3D%22width%3A%20938px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING2.png%22%20style%3D%22width%3A%20938px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING2.png%22%20style%3D%22width%3A%20938px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367936iAA75740E8ACE2A53%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SETTING2.png%22%20alt%3D%22SETTING2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22SETTING3.png%22%20style%3D%22width%3A%20287px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING3.png%22%20style%3D%22width%3A%20287px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING3.png%22%20style%3D%22width%3A%20287px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING3.png%22%20style%3D%22width%3A%20287px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING3.png%22%20style%3D%22width%3A%20287px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING3.png%22%20style%3D%22width%3A%20287px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367934i539188658DC7CB1E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SETTING3.png%22%20alt%3D%22SETTING3.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CODE1.png%22%20style%3D%22width%3A%20925px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CODE1.png%22%20style%3D%22width%3A%20925px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CODE1.png%22%20style%3D%22width%3A%20925px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CODE1.png%22%20style%3D%22width%3A%20925px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CODE1.png%22%20style%3D%22width%3A%20925px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CODE1.png%22%20style%3D%22width%3A%20925px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367939iCB714049AD7230B9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22CODE1.png%22%20alt%3D%22CODE1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CODE2.png%22%20style%3D%22width%3A%20620px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CODE2.png%22%20style%3D%22width%3A%20620px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CODE2.png%22%20style%3D%22width%3A%20620px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CODE2.png%22%20style%3D%22width%3A%20620px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CODE2.png%22%20style%3D%22width%3A%20620px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CODE2.png%22%20style%3D%22width%3A%20620px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367938i09F0CCB8F4F35DC9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22CODE2.png%22%20alt%3D%22CODE2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CODE3.png%22%20style%3D%22width%3A%20743px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CODE3.png%22%20style%3D%22width%3A%20743px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CODE3.png%22%20style%3D%22width%3A%20743px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CODE3.png%22%20style%3D%22width%3A%20743px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CODE3.png%22%20style%3D%22width%3A%20743px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CODE3.png%22%20style%3D%22width%3A%20743px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367937i0C901D6BAC11061D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22CODE3.png%22%20alt%3D%22CODE3.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252608%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS26%20CAN'T%20NOT%20RESET%20S32K3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252608%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CSPAN%3E%EF%BC%8C%E5%BD%BC%E5%BE%97%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%AE%9A%E5%88%B6%E6%9D%BF%E4%B8%8A%E5%BC%80%E5%8F%91%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E7%A1%AE%E8%AE%A4%E7%A1%AC%E4%BB%B6%E5%B7%B2%E7%BB%8F%E9%80%80%E5%87%BA%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E3%80%82%3CBR%20%2F%3E%E6%88%91%E5%B0%9D%E8%AF%95%E5%88%B7%E6%96%B0%E4%B8%80%E4%B8%AA%3CSTRONG%3E%E6%B2%A1%E6%9C%89%E8%BF%9B%E8%A1%8C%E4%BB%BB%E4%BD%95%20FS26%20%E5%88%9D%E5%A7%8B%E5%8C%96%E7%9A%84%3C%2FSTRONG%3E%E7%89%88%E6%9C%AC%EF%BC%8C%E5%9C%A8%E9%82%A3%E4%B8%AA%E7%89%88%E6%9C%AC%E4%B8%AD%EF%BC%8CFS26%20%E4%BC%9A%E6%8C%81%E7%BB%AD%20RESET%20MCU%E3%80%82%3CBR%20%2F%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E9%97%AA%E5%9B%9E%E6%88%91%E6%8F%90%E4%BE%9B%E7%BB%99%E4%BD%A0%E7%9A%84%E7%89%88%E6%9C%AC%EF%BC%88%E5%8C%85%E5%90%AB%20FS26%20%E5%88%9D%E5%A7%8B%E5%8C%96%E7%9A%84%E8%BD%AF%E4%BB%B6%EF%BC%89%E6%97%B6%EF%BC%8CFS26%20%E4%B8%8D%E5%86%8D%20RESET%20MCU%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E4%BD%A0%E8%BF%98%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E6%88%91%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%8C%E5%A6%82%E9%99%84%E4%BB%B6%E6%89%80%E7%A4%BA%EF%BC%8C%E6%88%91%E9%80%89%E6%8B%A9%E4%BA%86%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E9%80%80%E5%87%BA%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%A3%80%E6%9F%A5%20FS26%20%E5%88%9D%E5%A7%8B%E5%8C%96%E8%BF%87%E7%A8%8B%E4%B8%AD%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E9%94%99%E8%AF%AF%E3%80%82%E8%B0%A2%E8%B0%A2%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22SETTING4.png%22%20style%3D%22width%3A%20994px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING4.png%22%20style%3D%22width%3A%20994px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING4.png%22%20style%3D%22width%3A%20994px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING4.png%22%20style%3D%22width%3A%20994px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING4.png%22%20style%3D%22width%3A%20994px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SETTING4.png%22%20style%3D%22width%3A%20994px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368083iD604E3D7D1508875%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SETTING4.png%22%20alt%3D%22SETTING4.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252300%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS26%20CAN'T%20NOT%20RESET%20S32K3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252300%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E8%83%BD%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%8B%E4%BD%A0%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E6%81%A9%E6%99%BA%E6%B5%A6%E8%AF%84%E4%BC%B0%E6%9D%BF%E8%BF%98%E6%98%AF%E5%AE%9A%E5%88%B6%E4%B8%BB%E6%9D%BF%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E7%A1%AE%E4%BF%9D%20FS26%20%E6%9C%AA%E5%A4%84%E4%BA%8E%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E3%80%82%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8CWDOG%20%E5%B0%86%E8%A2%AB%E7%A6%81%E7%94%A8%EF%BC%8C%E8%B6%85%E6%97%B6%E6%97%B6%E4%B8%8D%E4%BC%9A%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8F%8D%E5%BA%94%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS26%20CAN'T%20NOT%20RESET%20S32K3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E8%A7%A3%E9%87%8A%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E4%BD%A0%E8%BF%98%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E6%88%91%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%8C%E5%A6%82%E9%99%84%E4%BB%B6%E6%89%80%E7%A4%BA%EF%BC%8C%E6%88%91%E9%80%89%E6%8B%A9%E4%BA%86%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E9%80%80%E5%87%BA%E3%80%82%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E8%BF%99%E5%8F%AA%E6%98%AF%E9%85%8D%E7%BD%AE%E5%9B%BE%E5%BD%A2%E7%94%A8%E6%88%B7%E7%95%8C%E9%9D%A2%E4%B8%AD%E7%9A%84%E5%A4%8D%E9%80%89%E6%A1%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E4%BB%8E%20FS26%20%E8%AF%BB%E5%9B%9E%EF%BC%8C%E5%AE%83%E7%9C%9F%E7%9A%84%E5%A4%84%E4%BA%8E%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_0-1764660041119.png%22%20style%3D%22width%3A%20602px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1764660041119.png%22%20style%3D%22width%3A%20602px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1764660041119.png%22%20style%3D%22width%3A%20602px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1764660041119.png%22%20style%3D%22width%3A%20602px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1764660041119.png%22%20style%3D%22width%3A%20602px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368163i0BB191519CD6AD4D%2Fimage-dimensions%2F602x160%3Fv%3Dv2%22%20width%3D%22602%22%20height%3D%22160%22%20role%3D%22button%22%20title%3D%22petervlna_0-1764660041119.png%22%20alt%3D%22petervlna_0-1764660041119.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E5%88%B7%E6%96%B0%E4%B8%80%E4%B8%AA%3CSTRONG%3E%E6%B2%A1%E6%9C%89%E8%BF%9B%E8%A1%8C%E4%BB%BB%E4%BD%95%20FS26%20%E5%88%9D%E5%A7%8B%E5%8C%96%E7%9A%84%3C%2FSTRONG%3E%E7%89%88%E6%9C%AC%EF%BC%8C%E5%9C%A8%E9%82%A3%E4%B8%AA%E7%89%88%E6%9C%AC%E4%B8%AD%EF%BC%8CFS26%20%E4%BC%9A%E6%8C%81%E7%BB%AD%20RESET%20MCU%E3%80%82%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%20FS26%20%E6%9C%AA%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%8CWDOG%20%E5%B0%86%E5%8F%91%E5%87%BA%20RESET%20%E5%91%BD%E4%BB%A4%EF%BC%8CRESET%20%E9%98%B6%E6%AE%B5%E5%B0%86%E8%87%AA%E5%8A%A8%E9%87%8D%E6%96%B0%E5%BC%80%E5%A7%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CEM%3E%E5%88%9D%E5%A7%8B%E5%8C%96%E9%98%B6%E6%AE%B5%E5%BF%85%E9%A1%BB%E5%9C%A8%20256%20%E6%AF%AB%E7%A7%92%E8%B6%85%E6%97%B6%E5%89%8D%E9%80%9A%E8%BF%87%E8%89%AF%E5%A5%BD%E7%9A%84%E7%9C%8B%E9%97%A8%E7%8B%97%E5%88%B7%E6%96%B0%E5%85%B3%E9%97%AD%E3%80%82%E5%A6%82%E6%9E%9C%E5%9C%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E9%98%B6%E6%AE%B5%E6%B2%A1%E6%9C%89%E5%8F%91%E9%80%81%E7%9B%91%E8%A7%86%E5%99%A8%E5%88%B7%E6%96%B0%E6%88%96%E7%9B%91%E8%A7%86%E7%A8%8B%E5%BA%8F%E4%B8%8D%E6%AD%A3%E7%A1%AE%EF%BC%8C%E5%88%99%E4%BC%9A%E7%94%9F%E6%88%90%20RSTB%20%E8%84%89%E5%86%B2%EF%BC%8C%E6%95%85%E9%9A%9C%E9%94%99%E8%AF%AF%E8%AE%A1%E6%95%B0%E5%99%A8%E5%B0%86%E5%A2%9E%E5%8A%A0%201%E3%80%82%E5%BD%93%20RSTB%20%E7%89%88%E6%9C%AC%E5%8F%91%E5%B8%83%E6%97%B6%EF%BC%8C%E6%96%B0%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%E9%98%B6%E6%AE%B5%E4%BC%9A%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%E4%BD%86%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E4%B9%9F%E6%98%AF%E9%80%9A%E8%BF%87%E8%B0%83%E8%AF%95%E5%BC%95%E8%84%9A%E6%BF%80%E6%B4%BB%E6%9D%A5%E4%BF%9D%E6%8C%81%E7%9A%84%E3%80%82%E4%BD%86%E6%98%AF%E7%94%B1%E4%BA%8ERESET%E6%98%AF%E5%9C%A8%E6%B2%A1%E6%9C%89%E5%AE%8C%E6%88%90%E5%88%9D%E5%A7%8B%E5%8C%96%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E8%BF%9B%E8%A1%8C%E7%9A%84%EF%BC%8C%E6%88%91%E9%A2%84%E8%AE%A1%E4%BD%A0%E6%B2%A1%E6%9C%89%E6%BF%80%E6%B4%BB%E8%B0%83%E8%AF%95%E5%BC%95%E8%84%9A%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E9%97%AA%E5%9B%9E%E6%88%91%E6%8F%90%E4%BE%9B%E7%BB%99%E4%BD%A0%E7%9A%84%E7%89%88%E6%9C%AC%EF%BC%88%E5%8C%85%E5%90%AB%20FS26%20%E5%88%9D%E5%A7%8B%E5%8C%96%E7%9A%84%E8%BD%AF%E4%BB%B6%EF%BC%89%E6%97%B6%EF%BC%8CFS26%20%E4%B8%8D%E5%86%8D%20RESET%20MCU%E3%80%82%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%9C%A8%E6%88%91%E7%9C%8B%E6%9D%A5%EF%BC%8C%E8%BF%99%E4%B8%8E%E4%BB%A3%E7%A0%81%E7%9B%B4%E6%8E%A5%E7%9B%B8%E5%85%B3%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E5%8F%AF%E8%83%BD%E5%8F%AA%E6%9C%89%E4%B8%A4%E7%A7%8D%E9%80%89%E6%8B%A9%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%20%E6%82%A8%E7%9A%84%20WDOG%20%E6%9C%AA%E6%BF%80%E6%B4%BB%3C%2FP%3E%0A%3CP%3E2.%20%E6%82%A8%E5%B7%B2%E8%BF%9B%E5%85%A5%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%90%A6%E5%88%99%EF%BC%8CFS26%20%E5%B0%86%E5%8F%91%E5%87%BA%20RESET%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8F%AF%E4%BB%A5%E6%B7%BB%E5%8A%A0%20FS26%20%E6%A8%A1%E5%BC%8F%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E6%A3%80%E6%B5%8B%E6%A3%80%E6%9F%A5%EF%BC%8C%E4%BB%A5%E7%A1%AE%E4%BF%9D%20SBC%20%E5%90%AF%E5%8A%A8%E5%90%8E%E4%B8%8D%E5%A4%84%E4%BA%8E%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%90%8C%E6%97%B6%E6%A3%80%E6%9F%A5%20FS_I_WD_CFG%20%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_1-1764661359151.png%22%20style%3D%22width%3A%20806px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_1-1764661359151.png%22%20style%3D%22width%3A%20806px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_1-1764661359151.png%22%20style%3D%22width%3A%20806px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_1-1764661359151.png%22%20style%3D%22width%3A%20806px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_1-1764661359151.png%22%20style%3D%22width%3A%20806px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368170iE5EE6C8457E19EF3%2Fimage-dimensions%2F806x133%3Fv%3Dv2%22%20width%3D%22806%22%20height%3D%22133%22%20role%3D%22button%22%20title%3D%22petervlna_1-1764661359151.png%22%20alt%3D%22petervlna_1-1764661359151.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2253577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS26%20CAN'T%20NOT%20RESET%20S32K3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2253577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%BD%BC%E5%BE%97%E3%80%81%3C%2FP%3E%3CP%3E%E8%AF%B7%E7%9C%8B%E6%88%91%3CFONT%20color%3D%22%230000FF%22%3E%E8%93%9D%E8%89%B2%3C%2FFONT%3E%E5%AD%97%E4%BD%93%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E8%B0%A2%E8%B0%A2%E3%80%82%3CBR%20%2F%3E%E4%BB%8D%E6%9C%AA%E6%89%BE%E5%88%B0%E7%9B%91%E8%A7%86%E7%A8%8B%E5%BA%8F%E6%9C%AA%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%20MCU%20RESET%20%E7%9A%84%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E4%BB%8E%20FS26%20%E8%AF%BB%E5%9B%9E%EF%BC%8C%E5%AE%83%E7%9C%9F%E7%9A%84%E5%A4%84%E4%BA%8E%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CFONT%20color%3D%22%230000FF%22%3EWade%20%3A%20%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E9%80%9A%E8%BF%87%20spi%20%E8%AF%BB%E5%8F%96%E4%BA%86%20FS_STATES%EF%BC%8C%E5%AE%83%E8%BF%94%E5%9B%9E%201011%EF%BC%88%E6%AD%A3%E5%B8%B8%EF%BC%89%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CP%3E1.%20%E6%82%A8%E7%9A%84%20WDOG%20%E6%9C%AA%E6%BF%80%E6%B4%BB%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%230000FF%22%3E%E9%9F%A6%E5%BE%B7%EF%BC%9A%E6%88%91%3CSPAN%3E%E7%94%A8%20spi%3C%2FSPAN%3E%E8%AF%BB%E5%8F%96%E4%BA%86FS_I_WD_CFG%20%E5%B9%B6%E8%BF%94%E5%9B%9E%E4%BA%86%200101%201010%200001%200000%EF%BC%8C%E4%B8%8E%E6%88%91%E7%9A%84%E9%85%8D%E7%BD%AE%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CP%3E2.%20%E6%82%A8%E5%B7%B2%E8%BF%9B%E5%85%A5%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%230000FF%22%3EWade%20%3A%20%E6%B2%A1%E6%9C%89%EF%BC%8C%E6%88%91%E9%80%9A%E8%BF%87%20spi%20%E8%AF%BB%E5%8F%96%20FS_STATES%EF%BC%8C%E5%AE%83%E8%BF%94%E5%9B%9E%201011%EF%BC%88%E4%B8%8D%E5%9C%A8%20DEBUG%20%E6%A8%A1%E5%BC%8F%E4%B8%8B%EF%BC%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22NORMAL%20%26amp%3B%20NOT%20IN%20DEBUG%20MODE.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22NORMAL%20%26amp%3B%20NOT%20IN%20DEBUG%20MODE.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22NORMAL%20%26amp%3B%20NOT%20IN%20DEBUG%20MODE.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22NORMAL%20%26amp%3B%20NOT%20IN%20DEBUG%20MODE.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368321i7639AE0764FD3350%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22NORMAL%20%26amp%3B%20NOT%20IN%20DEBUG%20MODE.jpg%22%20alt%3D%22NORMAL%20%26amp%3B%20NOT%20IN%20DEBUG%20MODE.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22NORMAL%20%26amp%3B%20NOT%20IN%20DEBUG%20MODE.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22NORMAL%20%26amp%3B%20NOT%20IN%20DEBUG%20MODE.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22NORMAL%20%26amp%3B%20NOT%20IN%20DEBUG%20MODE.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22NORMAL%20%26amp%3B%20NOT%20IN%20DEBUG%20MODE.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368322i097A8B3A9AE66489%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22NORMAL%20%26amp%3B%20NOT%20IN%20DEBUG%20MODE.jpg%22%20alt%3D%22NORMAL%20%26amp%3B%20NOT%20IN%20DEBUG%20MODE.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22FS26_FS_I_WD_CFG_CODE.jpg%22%20style%3D%22width%3A%20701px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FS26_FS_I_WD_CFG_CODE.jpg%22%20style%3D%22width%3A%20701px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FS26_FS_I_WD_CFG_CODE.jpg%22%20style%3D%22width%3A%20701px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FS26_FS_I_WD_CFG_CODE.jpg%22%20style%3D%22width%3A%20701px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368323iA24F2B3F1931D4BB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FS26_FS_I_WD_CFG_CODE.jpg%22%20alt%3D%22FS26_FS_I_WD_CFG_CODE.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2254674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS26%20CAN'T%20NOT%20RESET%20S32K3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2254674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%BD%BC%E5%BE%97%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E4%B8%8A%E4%B8%80%E7%AF%87%E6%96%87%E7%AB%A0%E4%B8%AD%E6%BC%8F%E6%8E%89%E4%BA%86%E4%B8%80%E5%BC%A0%E5%9B%BE%E7%89%87%E3%80%82%3CBR%20%2F%3E%E8%AF%B7%E4%B8%80%E5%B9%B6%E5%8F%82%E9%98%85%E3%80%82%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22FS_I_WD_CFG.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FS_I_WD_CFG.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FS_I_WD_CFG.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368491i9CF2E90F576C1EB0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FS_I_WD_CFG.jpg%22%20alt%3D%22FS_I_WD_CFG.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255247%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS26%20CAN'T%20NOT%20RESET%20S32K3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255247%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E5%B0%B1%E5%A5%87%E6%80%AA%E4%BA%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%A3%80%E6%9F%A5%E8%BF%87%E4%BD%A0%E4%BB%AC%E7%9A%84%E7%99%BB%E8%AE%B0%E7%B0%BF%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E4%BB%8E%20FS26%20%E8%AF%BB%E5%9B%9E%EF%BC%8C%E5%AE%83%E7%9C%9F%E7%9A%84%E5%A4%84%E4%BA%8E%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CFONT%20color%3D%22%230000FF%22%3EWade%20%3A%20%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E9%80%9A%E8%BF%87%20spi%20%E8%AF%BB%E5%8F%96%E4%BA%86%20FS_STATES%EF%BC%8C%E5%AE%83%E8%BF%94%E5%9B%9E%201011%EF%BC%88%E6%AD%A3%E5%B8%B8%EF%BC%89%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E1.%20%E6%82%A8%E7%9A%84%20WDOG%20%E6%9C%AA%E6%BF%80%E6%B4%BB%3C%2FP%3E%0A%3CP%3E%3CFONT%20color%3D%22%230000FF%22%3E%E9%9F%A6%E5%BE%B7%EF%BC%9A%E6%88%91%3CSPAN%3E%E7%94%A8%20spi%3C%2FSPAN%3E%E8%AF%BB%E5%8F%96%E4%BA%86FS_I_WD_CFG%20%E5%B9%B6%E8%BF%94%E5%9B%9E%E4%BA%86%200101%201010%200001%200000%EF%BC%8C%E4%B8%8E%E6%88%91%E7%9A%84%E9%85%8D%E7%BD%AE%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_0-1764843020748.png%22%20style%3D%22width%3A%20253px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1764843020748.png%22%20style%3D%22width%3A%20253px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368606i36AA436FE43D838B%2Fimage-dimensions%2F253x58%3Fv%3Dv2%22%20width%3D%22253%22%20height%3D%2258%22%20role%3D%22button%22%20title%3D%22petervlna_0-1764843020748.png%22%20alt%3D%22petervlna_0-1764843020748.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Ewd_fs_reaction%5B1%3A0%5D%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_1-1764843054702.png%22%20style%3D%22width%3A%20756px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_1-1764843054702.png%22%20style%3D%22width%3A%20756px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368607iB70BA7197545622C%2Fimage-dimensions%2F756x139%3Fv%3Dv2%22%20width%3D%22756%22%20height%3D%22139%22%20role%3D%22button%22%20title%3D%22petervlna_1-1764843054702.png%22%20alt%3D%22petervlna_1-1764843054702.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E8%AE%BE%E5%A4%87%E6%9C%AA%E5%A4%84%E4%BA%8E%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%88%99%E6%AD%A4%E7%B1%BB%E9%85%8D%E7%BD%AE%E5%B0%86%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7RESET%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E2.%20%E6%82%A8%E5%B7%B2%E8%BF%9B%E5%85%A5%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CFONT%20color%3D%22%230000FF%22%3EWade%20%3A%20%E6%B2%A1%E6%9C%89%EF%BC%8C%E6%88%91%E9%80%9A%E8%BF%87%20spi%20%E8%AF%BB%E5%8F%96%20FS_STATES%EF%BC%8C%E5%AE%83%E8%BF%94%E5%9B%9E%201011%EF%BC%88%E4%B8%8D%E5%9C%A8%20DEBUG%20%E6%A8%A1%E5%BC%8F%E4%B8%8B%EF%BC%89%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E8%BF%99%E8%AF%B4%E6%98%8E%E6%98%AF%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%B8%8D%E6%B8%85%E6%A5%9A%E4%BD%A0%E9%82%A3%E8%BE%B9%E5%8F%91%E7%94%9F%E4%BA%86%E4%BB%80%E4%B9%88%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E8%83%BD%E4%B8%8D%E8%83%BD%E9%80%9A%E8%BF%87%E7%A4%BA%E6%B3%A2%E5%99%A8%E6%A3%80%E6%9F%A5RESET%E7%BA%BF%EF%BC%8C%E7%9C%8B%E7%9C%8BRESET%E6%B2%A1%E6%9C%89%E8%A2%AB%E6%8B%89%E5%87%BA%E3%80%82%E5%8F%A6%E5%A4%96%EF%BC%8C%E4%BD%A0%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6%E8%AF%84%E4%BC%B0%E6%9D%BF%E4%B8%8A%E7%9C%8B%E5%88%B0%E5%90%8C%E6%A0%B7%E7%9A%84%E8%A1%8C%E4%B8%BA%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E9%82%A3%E8%B0%83%E8%AF%95%E5%BC%95%E8%84%9A%E5%91%A2%EF%BC%8C%E4%B8%8D%E6%98%AF%E6%BF%80%E6%B4%BB%E7%9A%84%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E5%9C%A8%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95SBC%E9%85%8D%E7%BD%AE%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8CRESET%E4%BC%9A%E8%A2%AB%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%82%A8%E7%9A%84SBC%E9%85%8D%E7%BD%AE%E4%B8%AD%E5%BF%85%E9%A1%BB%E6%9C%89%E4%B8%80%E4%BA%9B%E5%86%85%E5%AE%B9%EF%BC%8C%E9%98%B2%E6%AD%A2%E4%BB%8ESBC%E5%90%91uC%E6%89%A7%E8%A1%8CRESET%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E5%B0%9D%E8%AF%95%E8%BF%87%20RTD%20%E8%BD%AF%E4%BB%B6%E5%8C%85%E6%8F%90%E4%BE%9B%E7%9A%84%20FS26%20%E7%A4%BA%E4%BE%8B%E8%BD%AF%E4%BB%B6%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_2-1764846698425.png%22%20style%3D%22width%3A%20641px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_2-1764846698425.png%22%20style%3D%22width%3A%20641px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368617iE99E4917E4D75C46%2Fimage-dimensions%2F641x370%3Fv%3Dv2%22%20width%3D%22641%22%20height%3D%22370%22%20role%3D%22button%22%20title%3D%22petervlna_2-1764846698425.png%22%20alt%3D%22petervlna_2-1764846698425.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
