FS2400 current consumption after wakeup
325件の閲覧回数
PINKMAN
hello expert:
my chip is S32K312 and SBC is FS2400
now i need to wake up the chip and the wakeup source is a GPIO falling edge
before make S32K312 going to standby ,i set the FS2400 goto LPON mode
/* register M_WU1_EN : filed CAN_WUEN set to wakeup and interrupt(03) */
Sbc_FS24_Ip_WriteRegister(0, SBC_FS24_IP_M_WU1_EN_ADDR, SBC_FS24_IP_M_CAN_WUEN_MASK);
/* register M_IOWU_EN : filed WAKE2,WAKE3,HVIO1 set to no wakeup and interrupt(00) */
Sbc_FS24_Ip_WriteRegister(0, SBC_FS24_IP_M_IOWU_EN_ADDR, 0x00);
/* register M_CAN : filed CAN MODE set to Transceiver receive only mode */
Sbc_FS24_Ip_WriteRegister(0, SBC_FS24_IP_M_CAN_ADDR, SBC_FS24_IP_M_CAN_MODE_RX_ONLY);
/* go to LPON mode */
Sbc_FS24_Ip_WriteRegister(0, SBC_FS24_IP_M_SYS_CFG_ADDR, SBC_FS24_IP_M_GO2LPON_MASK)
after wakeup ,i set the SBC goto normal
Lpspi_Ip_Init(&Lpspi_Ip_PhyUnitConfig_SpiPhyUnit_SBC_Instance_0);
Sbc_FS24_Ip_InitDriver(&Sbc_FS24_Ip_Config);
Sbc_FS24_Ip_InitDevice(SBC_FS24_DEVICE_ID);
eReturnValue = Sbc_FS24_Ip_CanTrcvSetState(SBC_FS24_DEVICE_ID, SBC_FS24_CANTRCV_STATE_ACTIVE);
Sbc_FS24_Ip_WriteRegister(0, SBC_FS24_IP_M_SYS_CFG_ADDR, SBC_FS24_IP_M_GO2NORMAL_MASK);
i found the current consumption is 54mA but the POR current consumption is 72mA
if i do nothing about the SBC before goto standby ,after wakeup ,the current consumption is same as POR,
so i think the sbc status is something wrong ,can you tell me why?
2 返答(返信)
272件の閲覧回数
RafaR
Hello PINKMAN
Good day!
Based on the behavior you described, I do not think the FS2400 is necessarily "stuck", but it is very likely that after waking from LPON the SBC is not returning to exactly the same configuration/state as after a POR
The datasheet states that waking from LPON returns the device directly to Normal mode through the wake-up sequence. The device does not re-enter INIT state automatically after an LPON wake-up
Also, if the device goes in LPON or LPOFF or Fail-safe mode while in INIT state, the device stays in INIT state, which can lead to misconfiguration of the device. It is recommended to read the INIT_S status bit in M_STATUS register before going to LPON or LPOFF mode, and to go only if the device is no longer in INIT state
I would capture and compare the following registers in both cases (POR path and LPON-wakeup path):
M_STATUS
M_SYS_CFG
M_CAN
M_SYS1_CFG
M_REG_CTRL
M_IOWU_EN
M_WU1_EN
I hope this information has helped you, please let me know if you need help with anything else.
Have a great day and best of luck.
252件の閲覧回数
PINKMAN
hi : RafaR
Based on your suggestion, I compared the FS2400 registers during POR and wake-up. I found that during POR, the value of register M_REG_CTRL is 0x04, while after wake-up, the value of register M_REG_CTRL is 0x1304. Based on this finding, I traced it to the function Sbc_FS24_Ip_InitDevice → Sbc_FS24_Ip_OptionalInitSequence → Sbc_FS24_Ip_InitMain, where there is an operation on M_REG_CTRL. However, this function has a prerequisite that SBC_FS24_NORMAL == ePowState. Therefore, during POR, this function can be executed, but during wake-up, GOTONORMAL is executed after Sbc_FS24_Ip_InitDevice, so this function cannot be executed, resulting in a power consumption difference.
So I have two questions:
1. Is Sbc_FS24_Ip_InitDevice mandatory? Because I found that even if I do not call it during initialization, CAN message transmission/reception and power supply still work fine.
2. Where does this power consumption difference mainly come from?
%3CLINGO-SUB%20id%3D%22lingo-sub-2403637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFS2400%E3%81%AE%E8%B5%B7%E5%8B%95%E5%BE%8C%E3%81%AE%E6%B6%88%E8%B2%BB%E9%9B%BB%E6%B5%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2403637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E5%B0%82%E9%96%80%E5%AE%B6%E3%81%95%E3%82%93%EF%BC%9A%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%81%E3%83%83%E3%83%97%E3%81%AFS32K312%E3%81%A7%E3%80%81SBC%E3%81%AFFS2400%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%8A%E5%BA%A6%E3%81%AF%E3%83%81%E3%83%83%E3%83%97%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%95%E3%81%9B%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E8%B5%B7%E5%8B%95%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AFGPIO%E3%81%AE%E7%AB%8B%E3%81%A1%E4%B8%8B%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ES32K312%E3%82%92%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81FS2400%E3%82%92LPON%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%2F*%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20M_WU1_EN%20%3A%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%20CAN_WUEN%20%E3%82%92%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%8A%E3%82%88%E3%81%B3%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF(03)%E3%81%AB%E8%A8%AD%E5%AE%9A%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESbc_FS24_Ip_WriteRegister%3C%2FSPAN%3E%20%3CSPAN%3E(0%2C%20SBC_FS24_IP_M_WU1_EN_ADDR%2C%3C%2FSPAN%3E%20%3CSPAN%3ESBC_FS24_IP_M_CAN_WUEN_MASK%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20M_IOWU_EN%20%3A%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%20WAKE2%E3%80%81WAKE3%E3%80%81HVIO1%20%E3%82%92%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%8A%E3%82%88%E3%81%B3%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AA%E3%81%97(00)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESbc_FS24_Ip_WriteRegister(0%2C%20SBC_FS24_IP_M_IOWU_EN_ADDR%2C%200x00)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFM_CAN%20%3A%20%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%9FCAN%20MODE%E3%81%AF%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E5%8F%97%E4%BF%A1%E3%81%AE%E3%81%BF%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESbc_FS24_Ip_WriteRegister(0%2C%20SBC_FS24_IP_M_CAN_ADDR%2C%20SBC_FS24_IP_M_CAN_MODE_RX_ONLY)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20LPON%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E7%A7%BB%E8%A1%8C%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESbc_FS24_Ip_WriteRegister(0%2C%20SBC_FS24_IP_M_SYS_CFG_ADDR%2C%20SBC_FS24_IP_M_GO2LPON_MASK)%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E8%B5%B7%E5%8B%95%E5%BE%8C%E3%80%81SBC%E3%82%92%E9%80%9A%E5%B8%B8%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3ELpspi_Ip_Init(%26amp%3BLpspi_Ip_PhyUnitConfig_SpiPhyUnit_SBC_Instance_0)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESbc_FS24_Ip_InitDriver(%26amp%3BSbc_FS24_Ip_Config)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESbc_FS24_Ip_InitDevice(SBC_FS24_DEVICE_ID)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EeReturnValue%20%3D%20Sbc_FS24_Ip_CanTrcvSetState(SBC_FS24_DEVICE_ID%2C%3C%2FSPAN%3E%20%3CSPAN%3ESBC_FS24_CANTRCV_STATE_ACTIVE%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESbc_FS24_Ip_WriteRegister(0%2C%20SBC_FS24_IP_M_SYS_CFG_ADDR%2C%20SBC_FS24_IP_M_GO2NORMAL_MASK)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%3CSPAN%3E%E9%9B%BB%E6%B5%81%E6%B6%88%E8%B2%BB%E9%87%8F%E3%81%AF54mA%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81POR%E3%81%AE%E9%9B%BB%E6%B5%81%E6%B6%88%E8%B2%BB%E9%87%8F%E3%81%AF72mA%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%AA%E3%82%8B%E5%89%8D%E3%81%ABSBC%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E4%BD%95%E3%82%82%E6%93%8D%E4%BD%9C%E3%82%92%E8%A1%8C%E3%82%8F%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E5%BE%8C%E3%81%AE%E6%B6%88%E8%B2%BB%E9%9B%BB%E6%B5%81%E3%81%AFPOR%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESO%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%8C%E4%BD%95%E3%81%8B%E5%95%8F%E9%A1%8C%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%AA%E3%81%9C%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2403795%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS2400%20current%20consumption%20after%20wakeup%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2403795%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%94%E3%83%B3%E3%82%AF%E3%83%9E%E3%83%B3%3C%2FP%3E%0A%3CP%3E%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%AA%AC%E6%98%8E%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E5%8B%95%E4%BD%9C%E3%81%8B%E3%82%89%E5%88%A4%E6%96%AD%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81FS2400%E3%81%8C%E5%BF%85%E3%81%9A%E3%81%97%E3%82%82%E3%80%8C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%80%8D%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81LPON%E3%81%8B%E3%82%89%E5%BE%A9%E5%B8%B0%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81SBC%E3%81%8CPOR%E5%BE%8C%E3%81%A8%E5%85%A8%E3%81%8F%E5%90%8C%E3%81%98%E6%A7%8B%E6%88%90%2F%E7%8A%B6%E6%85%8B%E3%81%AB%E6%88%BB%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E9%9D%9E%E5%B8%B8%E3%81%AB%E9%AB%98%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81LPON%E3%81%8B%E3%82%89%E3%81%AE%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AF%E3%80%81%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E7%B5%8C%E3%81%A6%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E7%9B%B4%E6%8E%A5%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E6%88%BB%E3%81%99%E3%81%A8%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82LPON%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E5%BE%8C%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%ABINIT%E7%8A%B6%E6%85%8B%E3%81%AB%E5%86%8D%E7%A7%BB%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%20%3CEM%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8CINIT%E7%8A%B6%E6%85%8B%E3%81%A7LPON%E3%80%81LPOFF%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%BB%E3%83%BC%E3%83%95%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%A8%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AFINIT%E7%8A%B6%E6%85%8B%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%AA%E3%82%8A%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E8%AA%A4%E6%A7%8B%E6%88%90%E3%81%AB%E3%81%A4%E3%81%AA%E3%81%8C%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82LPON%E3%81%BE%E3%81%9F%E3%81%AFLPOFF%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81M_STATUS%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AEINIT_S%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8CINIT%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AE%E3%81%BF%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E4%B8%A1%E6%96%B9%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF(POR%E3%83%91%E3%82%B9%E3%81%A8LPON%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%91%E3%82%B9)%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%81%A6%E6%AF%94%E8%BC%83%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EM_STATUS%3C%2FP%3E%0A%3CP%3EM_SYS_CFG%3C%2FP%3E%0A%3CP%3EM_CAN%3C%2FP%3E%0A%3CP%3EM_SYS1_CFG%3C%2FP%3E%0A%3CP%3EM_REG_CTRL%3C%2FP%3E%0A%3CP%3EM_IOWU_EN%3C%2FP%3E%0A%3CP%3EM_WU1_EN%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E4%BB%96%E3%81%AB%E4%BD%95%E3%81%8B%E3%81%94%E4%B8%8D%E6%98%8E%E3%81%AA%E7%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%8A%E6%B0%97%E8%BB%BD%E3%81%AB%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%E3%82%92%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%B9%B8%E9%81%8B%E3%82%92%E7%A5%88%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS2400%20current%20consumption%20after%20wakeup%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%20%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242156%22%20target%3D%22_blank%22%3E%3CSPAN%20class%3D%22%22%3ERafaR%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%94%E6%8F%90%E6%A1%88%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8D%E3%80%81POR%E6%99%82%E3%81%A8%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E6%99%82%E3%81%AEFS2400%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82POR%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AF%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFM_REG_CTRL%E3%81%AE%E5%80%A4%E3%81%8C0x04%E3%81%A7%E3%81%82%E3%82%8B%E3%81%AE%E3%81%AB%E5%AF%BE%E3%81%97%E3%80%81%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E5%BE%8C%E3%81%AF%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFM_REG_CTRL%E3%81%AE%E5%80%A4%E3%81%8C0x1304%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E7%99%BA%E8%A6%8B%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8D%E3%80%81%E5%8E%9F%E5%9B%A0%E3%82%92%E9%96%A2%E6%95%B0%20Sbc_FS24_Ip_InitDevice%20%E2%86%92%20Sbc_FS24_Ip_OptionalInitSequence%20%E2%86%92%20Sbc_FS24_Ip_InitMain%20%E3%81%AB%E3%81%9F%E3%81%A9%E3%81%A3%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%81%9D%E3%81%93%E3%81%A7%20M_REG_CTRL%20%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E6%93%8D%E4%BD%9C%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AB%E3%81%AF%E3%80%81SBC_FS24_NORMAL%20%3D%3D%20ePowState%20%E3%81%A8%E3%81%84%E3%81%86%E5%89%8D%E6%8F%90%E6%9D%A1%E4%BB%B6%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81POR%E4%B8%AD%E3%81%AF%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E6%99%82%E3%81%AB%E3%81%AFSbc_FS24_Ip_InitDevice%E5%BE%8C%E3%81%ABGOTONORMAL%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%AF%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E3%81%AE%E5%B7%AE%E3%81%8C%E7%94%9F%E3%81%98%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%93%E3%81%A7%E3%80%812%E3%81%A4%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E1.Sbc_FS24_Ip_InitDevice%E3%81%AF%E5%BF%85%E9%A0%88%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E5%88%9D%E6%9C%9F%E5%8C%96%E6%99%82%E3%81%AB%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%81%AA%E3%81%8F%E3%81%A6%E3%82%82%E3%80%81CAN%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E9%80%81%E4%BF%A1%E3%83%BB%E5%8F%97%E4%BF%A1%E3%82%84%E9%9B%BB%E6%BA%90%E4%BE%9B%E7%B5%A6%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E2.%E3%81%93%E3%81%AE%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E3%81%AE%E5%B7%AE%E3%81%AF%E4%B8%BB%E3%81%AB%E3%81%A9%E3%81%93%E3%81%8B%E3%82%89%E7%94%9F%E3%81%98%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
