Error in services launch sequence.
3,974件の閲覧回数
Faker
Hi Expert:
   I encounter a question in S32K166 device to debug or run example of LPUART. The Interface uses JTAG configured in debug configurations. With I pushing debug or run button, a dialog pops out that writes "Error in serices launch sequence, Starting J-Link GDB Server timed out".I don't know how to solve this problem,so I hope anyone here could help me.
2 返答(返信)
3,963件の閲覧回数
Robin_Shen
Hi Faker,
There is a timeout value you can use for Launch the GDB server:
Please try to increase that zero value e.g. to 10, 100 or higher (I believe it it is in ms).
I hope this helps!
Robin
3,950件の閲覧回数
Faker
Hi Robin,
   The probelm has been solved by a way that this chip which is secure need to be unsecured.
