Encountering a Bus Error while flashing software with Trace32.
1,488 次查看
代码织梦师
Hello, I encountered a bus error when refreshing the S32K324 chip using the trace32 script, as shown in the image above. Could you please tell me what's going on? Is the chip damaged or locked? How can I solve this?
标记 (1)
1,385 次查看
petervlna
Are those 2 different issues? Are you able to perform system up?
From the screenshot it seems like you are able to attach with reset = system.up.
So I see the issue in accessing the memory.
Here’s the short list of memory‑access–related solutions:
  1. Connect under reset to stop the application from blocking memory access.
  2. Full erase before flashing to remove problematic or protected flash content.
  3. Update TRACE32 to avoid flash‑driver memory‑access bugs.
  4. Fix clock configuration (e.g., oscillator mismatch) that can cause BusFault and block memory.
  5. Check C40/HSE security states and perform mass erase if memory access is restricted.
  6. Use HardFault/BusFault handler to identify which memory address is being blocked.
  7. Disable watchdogs early, as resets can interrupt flash algorithms and break memory access.
best regards,
Peter
1,323 次查看
代码织梦师
Hello, the first screenshot shows the issue that occurred when I ran the first data.load instruction, and the second screenshot shows the issue that occurred when I ran the second data.load instruction. I have flashed the built-in example routines of TRACE32, and the development version can be flashed normally. Thanks for your support.
1,293 次查看
petervlna
Ok. It seems that either you are using wrong programming scripts or your flash is corrupt.
Try to separately erase flash, then verify it is erased.
Then program the data into it. Buss errors can be cause by ECC faults in flash.
I am attaching mine programming script so you can test it also.
Peter
%3CLINGO-SUB%20id%3D%22lingo-sub-2295267%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20Trace32%20%E5%88%B7%E6%96%B0%E8%BD%AF%E4%BB%B6%E6%97%B6%E9%81%87%E5%88%B0%E6%80%BB%E7%BA%BF%E9%94%99%E8%AF%AF%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295267%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22_0-1768623495783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22_0-1768623495783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22_0-1768623495783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22_0-1768623495783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22_0-1768623495783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373223i8C7D3F3042564238%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22_0-1768623495783.png%22%20alt%3D%22_0-1768623495783.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22_1-1768624045416.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22_1-1768624045416.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22_1-1768624045416.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22_1-1768624045416.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22_1-1768624045416.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373224i08E0DAF08E9A3902%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22_1-1768624045416.png%22%20alt%3D%22_1-1768624045416.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E5%9C%A8%E4%BD%BF%E7%94%A8%20trace32%20%E8%84%9A%E6%9C%AC%E5%88%B7%E6%96%B0%20S32K324%20%E8%8A%AF%E7%89%87%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E6%80%BB%E7%BA%BF%E9%94%99%E8%AF%AF%EF%BC%8C%E5%A6%82%E4%B8%8A%E5%9B%BE%E6%89%80%E7%A4%BA%E3%80%82%E4%BD%A0%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E5%8F%91%E7%94%9F%E4%BA%86%E4%BB%80%E4%B9%88%E4%BA%8B%E5%90%97%EF%BC%9F%E8%8A%AF%E7%89%87%E6%98%AF%E5%90%A6%E6%8D%9F%E5%9D%8F%E6%88%96%E8%A2%AB%E9%94%81%E5%AE%9A%EF%BC%9F%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%20%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2295938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Encountering%20a%20Bus%20Error%20while%20flashing%20software%20with%20Trace32.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E4%B8%A4%E4%B8%AA%E4%B8%8D%E5%90%8C%E7%9A%84%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E6%82%A8%E8%83%BD%E8%BF%9B%E8%A1%8C%E7%B3%BB%E7%BB%9F%E5%8D%87%E7%BA%A7%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E4%BB%8E%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%E6%9D%A5%E7%9C%8B%EF%BC%8C%E4%BD%A0%E4%BC%BC%E4%B9%8E%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20reset%20%3D%20system.up%20%E8%BF%9B%E8%A1%8C%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E6%98%8E%E7%99%BD%E4%BA%86%E8%AE%BF%E9%97%AE%E5%86%85%E5%AD%98%E7%9A%84%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%E3%80%82%3C%2FP%3E%0A%3CDIV%20style%3D%22font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2014px%3B%20font-style%3A%20normal%3B%20font-weight%3A%20400%3B%20line-height%3A%2020px%3B%22%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E4%B8%8E%E5%86%85%E5%AD%98%E8%AE%BF%E9%97%AE%E7%9B%B8%E5%85%B3%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E7%AE%80%E8%A1%A8%EF%BC%9A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%3CSTRONG%3E%E5%9C%A8%20%E2%80%9CRESET%E2%80%9D%20%E4%B8%8B%E8%BF%9E%E6%8E%A5%3C%2FSTRONG%3E%EF%BC%8C%E9%98%BB%E6%AD%A2%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%98%BB%E6%AD%A2%E5%86%85%E5%AD%98%E8%AE%BF%E9%97%AE%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3E%E9%97%AA%E5%AD%98%E5%89%8D%E5%AE%8C%E5%85%A8%E6%93%A6%E9%99%A4%3C%2FSTRONG%3E%EF%BC%8C%E5%88%A0%E9%99%A4%E6%9C%89%E9%97%AE%E9%A2%98%E6%88%96%E5%8F%97%E4%BF%9D%E6%8A%A4%E7%9A%84%E9%97%AA%E5%AD%98%E5%86%85%E5%AE%B9%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3E%E6%9B%B4%E6%96%B0%20TRACE32%3C%2FSTRONG%3E%E4%BB%A5%E9%81%BF%E5%85%8D%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%86%85%E5%AD%98%E8%AE%BF%E9%97%AE%E9%94%99%E8%AF%AF%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3E%E4%BF%AE%E5%A4%8D%3C%2FSTRONG%3E%E5%8F%AF%E8%83%BD%E5%AF%BC%E8%87%B4%E6%80%BB%E7%BA%BF%E6%95%85%E9%9A%9C%E5%92%8C%E5%86%85%E5%AD%98%E9%98%BB%E5%A1%9E%E7%9A%84%E6%97%B6%E9%92%9F%E9%85%8D%E7%BD%AE%EF%BC%88%E5%A6%82%E6%8C%AF%E8%8D%A1%E5%99%A8%E4%B8%8D%E5%8C%B9%E9%85%8D%EF%BC%89%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3E%E6%A3%80%E6%9F%A5%20C40%2FHSE%20%E5%AE%89%E5%85%A8%E7%8A%B6%E6%80%81%3C%2FSTRONG%3E%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%86%85%E5%AD%98%E8%AE%BF%E9%97%AE%E5%8F%97%E5%88%B0%E9%99%90%E5%88%B6%EF%BC%8C%E5%88%99%E6%89%A7%E8%A1%8C%E6%89%B9%E9%87%8F%E6%93%A6%E9%99%A4%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3E%E4%BD%BF%E7%94%A8%20HardFault%2FBusFault%20%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%3C%2FSTRONG%3E%E7%A1%AE%E5%AE%9A%E5%93%AA%E4%B8%AA%E5%86%85%E5%AD%98%E5%9C%B0%E5%9D%80%E8%A2%AB%E9%98%BB%E5%A1%9E%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3E%E5%B0%BD%E6%97%A9%E7%A6%81%E7%94%A8%E7%9C%8B%E9%97%A8%E7%8B%97%3C%2FSTRONG%3E%EF%BC%8C%E5%9B%A0%E4%B8%BARESET%E4%BC%9A%E4%B8%AD%E6%96%AD%E9%97%AA%E5%AD%98%E7%AE%97%E6%B3%95%E5%B9%B6%E4%B8%AD%E6%96%AD%E5%86%85%E5%AD%98%E8%AE%BF%E9%97%AE%E3%80%82%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2296930%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Encountering%20a%20Bus%20Error%20while%20flashing%20software%20with%20Trace32.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2296930%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E7%AC%AC%E4%B8%80%E5%BC%A0%E6%88%AA%E5%9B%BE%E6%98%BE%E7%A4%BA%E7%9A%84%E6%98%AF%E6%88%91%E8%BF%90%E8%A1%8C%E7%AC%AC%E4%B8%80%E6%9D%A1%20data.load%20%E6%8C%87%E4%BB%A4%E6%97%B6%E5%87%BA%E7%8E%B0%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E7%AC%AC%E4%BA%8C%E5%BC%A0%E6%88%AA%E5%9B%BE%E6%98%BE%E7%A4%BA%E7%9A%84%E6%98%AF%E6%88%91%E8%BF%90%E8%A1%8C%E7%AC%AC%E4%BA%8C%E6%9D%A1%20data.load%20%E6%8C%87%E4%BB%A4%E6%97%B6%E5%87%BA%E7%8E%B0%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E5%88%B7%E6%96%B0%E4%BA%86%20TRACE32%20%E7%9A%84%E5%86%85%E7%BD%AE%E7%A4%BA%E4%BE%8B%E4%BE%8B%E7%A8%8B%EF%BC%8C%E5%BC%80%E5%8F%91%E7%89%88%E6%9C%AC%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%88%B7%E6%96%B0%E3%80%82%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2297171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Encountering%20a%20Bus%20Error%20while%20flashing%20software%20with%20Trace32.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2297171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E5%A5%BD%E7%9A%84%E3%80%82%E7%9C%8B%E6%9D%A5%E8%A6%81%E4%B9%88%E6%98%AF%E4%BD%A0%E4%BD%BF%E7%94%A8%E4%BA%86%E9%94%99%E8%AF%AF%E7%9A%84%E7%BC%96%E7%A8%8B%E8%84%9A%E6%9C%AC%EF%BC%8C%E8%A6%81%E4%B9%88%E6%98%AF%E4%BD%A0%E7%9A%84%E9%97%AA%E5%AD%98%E6%8D%9F%E5%9D%8F%E4%BA%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B0%9D%E8%AF%95%E5%8D%95%E7%8B%AC%E6%93%A6%E9%99%A4%E9%97%AA%E5%AD%98%EF%BC%8C%E7%84%B6%E5%90%8E%E9%AA%8C%E8%AF%81%E6%98%AF%E5%90%A6%E5%B7%B2%E6%93%A6%E9%99%A4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%84%B6%E5%90%8E%E5%B0%86%E6%95%B0%E6%8D%AE%E7%BC%96%E5%85%A5%E7%A8%8B%E5%BA%8F%E3%80%82%E9%97%AA%E5%AD%98%E4%B8%AD%E7%9A%84%20ECC%20%E6%95%85%E9%9A%9C%E5%8F%AF%E8%83%BD%E5%AF%BC%E8%87%B4%E6%80%BB%E7%BA%BF%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%9C%A8%E6%AD%A4%E9%99%84%E4%B8%8A%E6%88%91%E7%9A%84%E7%BC%96%E7%A8%8B%E8%84%9A%E6%9C%AC%EF%BC%8C%E6%82%A8%E4%B9%9F%E5%8F%AF%E4%BB%A5%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%3C%2FLINGO-BODY%3E
