Ebtresos key issue
Ebtresos key issue
Ashish4525
I have activated key from "Please use the following activation code within EB Client License Administrator to start EB tresos Studio: 9157-2EF4-ADA2-D9C2 (valid until 03/31/2025)
A new activation code will appear here 30 days before expiration of the current one, provided that your license to the target software (e.g. MCAL) is not expired by then." in desing: product download key is activated but when I am trying to open any module it shows no licence for particular ,module.
PFA attached images for better understanding
B.R
Ash
Julián_AragónM
Hi @Ashish4525,
Have you saved the license file that comes with the software? When installing the SW package, the license file is requested to use it.
Julián
Ashish4525
I have attached screenshot
Can You help me further what should I do?
B.R
Ashish
Julián_AragónM
Hi @Ashish4525
The license I was referring to was regarding the drivers, not EB Tresos. By your original screenshot, I can see you are using S32K1. Is the driver version S32K14x Autosar 4.2 MCAL (ISO26262)?
It may be an issue with the SW license instead of EB Tresos. Is this error present with all of the modules?
Julián
Ashish4525
Yes I am facing issue with all drivers
B.R
Ash
Julián_AragónM
Hi @Ashish4525,
Unlike RTD and SDK, S32K14X AUTOSAR 4.2 SMCAL RTM 1.0.2 (which is the software I assume you are using, since you did not answer my previous question) requires a license file upon installation.
This license file can be downloaded from the "license" tab as I've shown in the previous reply.
Ashish4525
hi
I have shared you licences tab ,unable to see any data in that ,again I have attached screenshot kindly look over it.
B.R
Ash
Julián_AragónM
Hi @Ashish4525,
As I said in the previous replies, the license is for the software, meaning S32K14X AUTOSAR 4.2 SMCAL RTM 1.0.2 needs the license file, not EB Tresos:
You still haven't shared which SW version you are using, so I cannot say for sure what is the issue, but please check the license for the S32K14X package.
Julián
Ashish4525
hi
I am using eb tresos 28.2.0 version
