EMIOS_ICU
EMIOS_ICU
DouDou1
I want to use the IPWM mode of the EMIOS module of the S32K358 chip to capture PWM waves, but my function cannot enter the interrupt function (User_EdgeDetect4), what is the problem? I'm sure there is a PWM wave input.
PetrS
comment Emios_Icu_Ip_StartSignalMeasurement function and you should get callback.
BR, Petr
PetrS
BR, Petr
DouDou1
Sorry for taking so long to reply you. The problem was solved when I commented out the function
%3CLINGO-SUB%20id%3D%22lingo-sub-1972664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EEMIOS_ICU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1972664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20want%20to%20use%20the%20IPWM%20mode%20of%20the%20EMIOS%20module%20of%20the%20S32K358%20chip%20to%20capture%20PWM%20waves%2C%20but%20my%20function%20cannot%20enter%20the%20interrupt%20function%20(User_EdgeDetect4)%2C%20what%20is%20the%20problem%3F%20I'm%20sure%20there%20is%20a%20PWM%20wave%20input.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1978746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20EMIOS_ICU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1978746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESorry%20for%20taking%20so%20long%20to%20reply%20you.%20The%20problem%20was%20solved%20when%20I%20commented%20out%20the%20function%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1974310%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20EMIOS_ICU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1974310%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3Ecomment%26nbsp%3BEmios_Icu_Ip_StartSignalMeasurement%20function%20and%20you%20should%20get%20callback.%3C%2FP%3E%0A%3CP%3EBR%2C%20Petr%3C%2FP%3E%3C%2FLINGO-BODY%3E
