EB Tresos loading error
4,460 次查看
sgp_118
Hi All,
I have downloaded an evaluation version of EB tresos and i wanted to configure MCAL using it. But whenever I try opening the EB tresos gui using ThirdParty\Mcal_S32k\Supply\tresos\bin\tresos_gui.exe the application fails to load.
I am getting image like the one below and application crashes. Have anyone else faced such error with EB tresos?
标记 (1)
4 回复数
4,370 次查看
sgp_118
Yes there was an application named Java(TM) Platform SE binary. I tried killing that process and restarting. It seems to be working now.
However I think I am facing license issue where the application is not generating MCAL source files.
4,370 次查看
namnguyenviet
Can you show me the error log for that?
4,370 次查看
namnguyenviet
Is there any Eclipse application was opening during that time? You can check by Task Manager. The EB application is displayed as a Java application
4,333 次查看
SSabariManoj
Yes, I am facing the same issue.
What is the solution for this?
Thanks and regards,
S.Sabari Manoj
