Difference between Fast and Standard Plus PADs
JRodrigues
Hello everyone,
Could anyone clarify what is meant by "fast-pads" and "standard-plus pads" in the System Clock Configurations in the S32K3XX RM?
JRodrigues
VaneB
Hi @JRodrigues
This refers to the Pad type, which indicates the theoretical maximum output frequency and drive strength (not set, it is given for MCU pad). See the "S32K3xx_IO Signal Table" tab of the "S32K3xx_IOMUX.xlsx" file attached to the Reference Manual.
BR, VaneB
VaneB
Hi @JRodrigues
BR, VaneB
JRodrigues
Hello @VaneB,
Thank you for your help!
JRodrigues
