After the decoupling process, the S32K344 is equivalent to the S32K324. I created a dual-core project based on the S32K324, which contains two projects corresponding to Core 0 and Core 1. However, during debugging, even when using independent (per-core) debugging, I am only able to successfully debug Core 0, while Core 1 cannot be connected or debugged. Could you please advise on the possible reasons for this behavior?
