Debug problem
Debug problem
Hermit
Dear Team,
I want to debug the project on S32K342. However, some errors appeared. I attached the screenshot.  And the debugger I used is PE micro multilink.
VaneB
Hi @Hermit
To confirm, when developing an Arm® circuit board, it is recommended to use a standard debug signal arrangement to make a connection to the debugger easier, as it is shown in the below image:
The connections were made in this way. If not, could you share how you have the debugger connection?
B.R.
VaneB
Hermit
Hi VaneB,
The error I metioned before has been resolved by adjusting the speed. However, there are some new errors appearing. I attached the screenshots below. Hope your response.
Hermit
VaneB
Hi @Hermit
Could you share with me your hardware connections?
Hermit
Hi VaneB
The problem has been resolved. Thanks.
Hermit
Hermit
Hi VaneB,
I have ensured that our connections are similarly to what you offered. Is there any other configuration I should perform to make it successful? For example,the speed?
Hermit
