DEBUG as a Maser, Can command access?
ソリューションへジャンプ
1,446件の閲覧回数
1260784871
Table 15-3. MPU Logical Bus Master Assignments
MPU
Logical
Bus
Master
ID
Bus
Master
Possible access types PID
avaialable
User Supervisor Data Instruction Read Write Execute
0 Core ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓
Debugger ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓
DMA - ✓ ✓ - ✓ ✓ - -
ENET
Not implemented. The region descriptor register fields for these master IDs are Reserved.
1
2
3
4-7
1,434件の閲覧回数
danielmartynek
Can you please elaborate?
I don't understand the question.
Thank you,
1,435件の閲覧回数
danielmartynek
Thank you,
