DCD tool does not support selected processor
GaryZhang1
I try to compile an example project for S32K358, it says "DCD tool does not support selected processor. Select different tool."
Have I missed a tool setting or I do not need this DCD tool? the compile error says the *.h file can not be found.
Gary
GaryZhang1
Thank you, Robin, the issue was solved. I did not find "Mark Correct" button.
Robin_Shen
You are welcome! Please sign in and click ACCEPT AS SOLUTION.
Robin_Shen
Hi Gary,
You don't need DCD tool. Please select other tool, for example: Peripherals tool and then click Update Code.
Robin
