Configuring MCAL AND Driver modules under Peripherals
ekmas-19
I have added driver modules in the peripherals tab under the MCAL section. when i select a particular deriver, like SPI, there are many tabs with many options to configure.  Some of it is obvious but much of it I am just guessing at.
Is there a guide on how to configure these options and what settings make sense? I interested in the SPI, MCU, MCL, platform and DIO modules.
VaneB
Hi @ekmas-19
I recommend reviewing each Driver Integration Manual and the User Manual. These documents provide detailed information on driver limitations, hardware/software requirements, usage instructions, and configuration guidelines. You can find them, for example, at the following location:
C:\NXP\S32DS.3.6.2\S32DS\software\PlatformSDK_S32K3\RTD\I2c_TS_T40D34M60I0R0\doc
Additionally, the RTD includes several example projects covering most of the family’s modules. These examples are a great starting point to understand how the peripherals work and how they can be configured.
BR, VaneB
%3CLINGO-SUB%20id%3D%22lingo-sub-2153746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EConfiguring%20MCAL%20AND%20Driver%20modules%20under%20Peripherals%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2153746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20added%20driver%20modules%20in%20the%20peripherals%20tab%20under%20the%20MCAL%20section.%20when%20i%20select%20a%20particular%20deriver%2C%20like%20SPI%2C%20there%20are%20many%20tabs%20with%20many%20options%20to%20configure.%26nbsp%3B%20Some%20of%20it%20is%20obvious%20but%20much%20of%20it%20I%20am%20just%20guessing%20at.%26nbsp%3B%3C%2FP%3E%3CP%3EIs%20there%20a%20guide%20on%20how%20to%20configure%20these%20options%20and%20what%20settings%20make%20sense%3F%20I%20interested%20in%20the%20SPI%2C%20MCU%2C%20MCL%2C%20platform%20and%20DIO%20modules.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2153854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Configuring%20MCAL%20AND%20Driver%20modules%20under%20Peripherals%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2153854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252673%22%20target%3D%22_blank%22%3E%40ekmas-19%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20recommend%20reviewing%20each%20Driver%20Integration%20Manual%20and%20the%20User%20Manual.%20These%20documents%20provide%20detailed%20information%20on%20driver%20limitations%2C%20hardware%2Fsoftware%20requirements%2C%20usage%20instructions%2C%20and%20configuration%20guidelines.%20You%20can%20find%20them%2C%20for%20example%2C%20at%20the%20following%20location%3A%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSTRONG%3EC%3A%5CNXP%5CS32DS.3.6.2%5CS32DS%5Csoftware%5CPlatformSDK_S32K3%5CRTD%5CI2c_TS_T40D34M60I0R0%5Cdoc%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3EAdditionally%2C%20the%20RTD%20includes%20several%20example%20projects%20covering%20most%20of%20the%20family%E2%80%99s%20modules.%20These%20examples%20are%20a%20great%20starting%20point%20to%20understand%20how%20the%20peripherals%20work%20and%20how%20they%20can%20be%20configured.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%2C%20VaneB%3C%2FP%3E%3C%2FLINGO-BODY%3E
