S32 Design Studio 3.6.2 generates invalid driver code
ソリューションへジャンプ
1,402件の閲覧回数
durga_choudhury
Contributor V
Here are the relevant details:
S32 Design Studio for S32 Platform
Version: 3.6.2
Build id: 250529 (Update 2)
Target processor: S32K148
Autogenerated driver: Adc_Ip
The autogenerated code that seems invalid:
* @brief ADC Ip Config for the ADC0 configuration variant .
const Adc_Ip_ConfigType AdcHwUnit_0 =
ADC_IP_CLK_FULL_BUS, /* ClockDivide */
ADC_IP_CLK_EIGHTH_BUS, /* CalibrationClockDivide */
ADC_IP_CLK_ALT_1, /* InputClock */
1U, /* SampleTime */
(boolean)FALSE, /* AvgEn */
ADC_IP_AVG_4_CONV, /* AvgSel */
ADC_IP_RESOLUTION_12BIT, /* Resolution */
ADC_IP_TRIGGER_SOFTWARE, /* TriggerMode */
#if (ADC_IP_ENABLE_SIM_SOURCE_SELECTION == STD_ON)
ADC_IP_PRETRIGGER_SEL_PDB, /* PretriggerSel */
ADC_IP_TRIGGER_SEL_PDB, /* TriggerSel */
#endif /* (ADC_IP_ENABLE_SIM_SOURCE_SELECTION == STD_ON) */
(boolean)FALSE, /* DmaEnable */
ADC_IP_VOLTAGEREF_VREF, /* VoltageRef */
(boolean)FALSE, /* ContinuousConvEnable */
#if (ADC_IP_SUPPLY_MONITORING_ENABLED == STD_ON)
(boolean)FALSE, /* SupplyMonitoringEnable */
#endif /* (ADC_IP_SUPPLY_MONITORING_ENABLED == STD_ON) */
(boolean)FALSE, /* CompareEnable */
(boolean)FALSE, /* CompareGreaterThanEnable */
(boolean)FALSE, /* CompareRangeFuncEnable */
0U, /* CompVal1 */
0U, /* CompVal2 */
4U, /* UsrGain */
0U, /* UsrOffset */
1U, /* NumChannels */
AdcIpChansConfig_0, /* ChannelConfigs */
#if (ADC_IP_AIEN_INTERRUPT_ENABLE == STD_ON)
&NULL_PTR /* ConversionCompleteNotification */
#endif /* (ADC_IP_AIEN_INTERRUPT_ENABLE == STD_ON) */
(The line that fails to compile: &NULL_PTR)
The compiler (correctly) fails to compile this code with error:
lvalue required as unary '&' operand
Is this an user error on my part? If not, is a fix available or will become available?
Durga Choudhury
1,344件の閲覧回数
durga_choudhury
Contributor V
Hello @VaneB
Thank you very much for your help in this matter. This is more of a code formality issue for us ("was the auto-generated code altered in any way?") than a show stopper. This is not blocking us.
Durga Choudhury
3 返答(返信)
1,345件の閲覧回数
durga_choudhury
Contributor V
Hello @VaneB
Durga Choudhury
1,333件の閲覧回数
VaneB
Hi @durga_choudhury
It is good to hear that it is not impacting your progress.
I will still make sure the team is aware, just in case it helps improve future versions of the tool or documentation.
1,348件の閲覧回数
VaneB
Hi @durga_choudhury
Thanks so much for your feedback. I took a look at the generated code and, as you pointed out, there is an error when assigning NULL_PTR to the Conversion Complete Notification. I will share this information with the appropriate team for further investigation.
In the meantime, here are a couple of quick suggestions that might help:
  • You can manually remove the "&" symbol from the ADC configuration struct. Please note that this character will be reinserted each time the code is updated in ConfigTools.
  • Alternatively, you could assign a dummy handler where the interrupt is disabled.
BR, VaneB
%3CLINGO-SUB%20id%3D%22lingo-sub-2152910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32%20Design%20Studio%203.6.2%E7%84%A1%E5%8A%B9%E3%81%AA%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%A9%B3%E7%B4%B0%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3ES32%20Design%20Studio%20for%20S32%20Platform%3C%2FP%3E%3CP%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%203.6.2%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89ID%3A%20250529%20(%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%882)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%AF%BE%E8%B1%A1%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3A%20S32K148%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%87%AA%E5%8B%95%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3A%20Adc_Ip%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%84%A1%E5%8A%B9%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E8%87%AA%E5%8B%95%E7%94%9F%E6%88%90%E3%82%B3%E3%83%BC%E3%83%89%3A%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%2F**%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E*%20%40brief%3C%2FSPAN%3E%20%3CSPAN%3EADC0%20%E6%A7%8B%E6%88%90%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%3C%2FSPAN%3EADC%20%3CSPAN%3EIp%3C%2FSPAN%3E%3CSPAN%3E%E6%A7%8B%E6%88%90%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%AE%9A%E6%95%B0%3C%2FSPAN%3E%3CSPAN%3EAdc_Ip_ConfigType%3C%2FSPAN%3E%20%3CSPAN%3EAdcHwUnit_0%20%3D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EADC_IP_CLK_FULL_BUS%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%88%86%E5%91%A8*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EADC_IP_CLK_EIGHTH_BUS%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%88%86%E5%91%A8%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EADC_IP_CLK_ALT_1%3C%2FSPAN%3E%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E5%85%A5%E5%8A%9B%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E1U%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E6%99%82%E9%96%93%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E3%83%96%E3%83%BC%E3%83%AB%E5%80%A4%3C%2FSPAN%3E%3CSPAN%3E)FALSE%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E5%B9%B3%E5%9D%87%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EADC_IP_AVG_4_CONV%3C%2FSPAN%3E%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E5%B9%B3%E5%9D%87%E9%81%B8%E6%8A%9E%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EADC_IP_RESOLUTION_12BIT%3C%2FSPAN%3E%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E8%A7%A3%E5%83%8F%E5%BA%A6%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EADC_IP_TRIGGER_SOFTWARE%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%23if%3C%2FSPAN%3E%20%3CSPAN%3E(ADC_IP_ENABLE_SIM_SOURCE_SELECTION%20%3D%3D%20STD_ON)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EADC_IP_PRETRIGGER_SEL_PDB%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E3%83%97%E3%83%AC%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E9%81%B8%E6%8A%9E%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EADC_IP_TRIGGER_SEL_PDB%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E9%81%B8%E6%8A%9E%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%23endif%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20(ADC_IP_ENABLE_SIM_SOURCE_SELECTION%20%3D%3D%20STD_ON)%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E3%83%96%E3%83%BC%E3%83%AB%E5%80%A4%3C%2FSPAN%3E%3CSPAN%3E)%20FALSE%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20DmaEnable%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EADC_IP_VOLTAGEREF_VREF%3C%2FSPAN%3E%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E9%9B%BB%E5%9C%A7%E5%8F%82%E7%85%A7%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E3%83%96%E3%83%BC%E3%83%AB%E5%80%A4%3C%2FSPAN%3E%3CSPAN%3E)FALSE%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E9%80%A3%E7%B6%9A%E5%A4%89%E6%8F%9B%E6%9C%89%E5%8A%B9%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%23if%3C%2FSPAN%3E%20%3CSPAN%3E(ADC_IP_SUPPLY_MONITORING_ENABLED%20%3D%3D%20STD_ON)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E(%E3%83%96%E3%83%BC%E3%83%AB%E5%80%A4)FALSE%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E4%BE%9B%E7%B5%A6%E7%9B%A3%E8%A6%96%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%23endif%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20(ADC_IP_SUPPLY_MONITORING_ENABLED%20%3D%3D%20STD_ON)%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E3%83%96%E3%83%BC%E3%83%AB%E5%80%A4%3C%2FSPAN%3E%3CSPAN%3E)FALSE%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E6%AF%94%E8%BC%83%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E3%83%96%E3%83%BC%E3%83%AB%E5%80%A4%3C%2FSPAN%3E%3CSPAN%3E)%20FALSE%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20CompareGreaterThanEnable%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E3%83%96%E3%83%BC%E3%83%AB%E5%80%A4%3C%2FSPAN%3E%3CSPAN%3E)%20FALSE%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20CompareRangeFuncEnable%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0U%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E6%AF%94%E8%BC%83%E5%80%A41%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0U%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E6%AF%94%E8%BC%83%E5%80%A42%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E4U%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%B2%E3%82%A4%E3%83%B3%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0U%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E1U%2C%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E6%95%B0%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EAdcIpChansConfig_0%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E6%A7%8B%E6%88%90%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%23if%3C%2FSPAN%3E%20%3CSPAN%3E(ADC_IP_AIEN_INTERRUPT_ENABLE%20%3D%3D%20STD_ON)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3ENULL_PTR%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E5%A4%89%E6%8F%9B%E5%AE%8C%E4%BA%86%E9%80%9A%E7%9F%A5%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%23endif%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20(ADC_IP_AIEN_INTERRUPT_ENABLE%20%3D%3D%20STD_ON)%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E(%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E8%A1%8C%3A%20%26amp%3BNULL_PTR)%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AF%20(%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AF)%20%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%8D%98%E9%A0%85%20'%26amp%3B'%20%E3%82%AA%E3%83%9A%E3%83%A9%E3%83%B3%E3%83%89%E3%81%A8%E3%81%97%E3%81%A6%E5%B7%A6%E8%BE%BA%E5%80%A4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E4%BF%AE%E6%AD%A3%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AF%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%89%E3%82%A5%E3%83%AB%E3%82%AC%E3%83%BC%E3%83%BB%E3%83%81%E3%83%A7%E3%83%BC%E3%83%89%E3%83%AA%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2153826%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20Design%20Studio%203.6.2%20generates%20invalid%20driver%20code%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2153826%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F250000%22%20target%3D%22_blank%22%3E%40durga_choudhury%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%82%8C%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E9%80%B2%E6%AD%A9%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E8%81%9E%E3%81%84%E3%81%A6%E5%AE%89%E5%BF%83%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%84%E3%83%BC%E3%83%AB%E3%82%84%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AEFUTURE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E6%94%B9%E5%96%84%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A4%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AB%E5%BF%85%E3%81%9A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%A6%E3%81%8A%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2153822%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20Design%20Studio%203.6.2%20generates%20invalid%20driver%20code%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2153822%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F201913%22%20target%3D%22_blank%22%3E%40VaneB%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%9E%E3%82%BF%E3%83%BC%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%AF%E3%80%81%E3%82%B7%E3%83%A7%E3%83%BC%E3%82%B9%E3%83%88%E3%83%83%E3%83%91%E3%83%BC%E3%81%A8%E3%81%84%E3%81%86%E3%82%88%E3%82%8A%E3%82%82%E3%80%81%E3%82%80%E3%81%97%E3%82%8D%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E5%BD%A2%E5%BC%8F%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%99%EF%BC%88%E3%80%8C%E8%BB%8A%E8%BC%89%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E5%BD%A2%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%E3%80%8D%EF%BC%89%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%82%92%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%89%E3%82%A5%E3%83%AB%E3%82%AC%E3%83%BC%E3%83%BB%E3%83%81%E3%83%A7%E3%83%BC%E3%83%89%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2153814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20Design%20Studio%203.6.2%20generates%20invalid%20driver%20code%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2153814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F250000%22%20target%3D%22_blank%22%3E%40durga_choudhury%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89%E3%83%90%E3%83%83%E3%82%AF%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81SO%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%AA%BF%E3%81%B9%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%81%94%E6%8C%87%E6%91%98%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%80%81%E5%A4%89%E6%8F%9B%E5%AE%8C%E4%BA%86%E9%80%9A%E7%9F%A5%E3%81%AB%20NULL_PTR%20%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E9%81%A9%E5%88%87%E3%81%AA%E3%83%81%E3%83%BC%E3%83%A0%E3%81%A8%E5%85%B1%E6%9C%89%E3%81%97%E3%80%81%E3%81%95%E3%82%89%E3%81%AB%E8%AA%BF%E6%9F%BB%E3%82%92%E9%80%B2%E3%82%81%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%AE%E9%96%93%E3%80%81%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%AA%E3%81%84%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E7%B0%A1%E5%8D%98%E3%81%AA%E6%8F%90%E6%A1%88%E3%82%92%E6%AC%A1%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EADC%20%E6%A7%8B%E6%88%90%E6%A7%8B%E9%80%A0%E4%BD%93%E3%81%8B%E3%82%89%E3%80%8C%26amp%3B%E3%80%8D%E8%A8%98%E5%8F%B7%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E5%89%8A%E9%99%A4CAN%E3%80%82%E3%81%93%E3%81%AE%E6%96%87%E5%AD%97%E3%81%AF%E3%80%81ConfigTools%20%E3%81%A7%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%81%B3%E3%81%AB%E5%86%8D%E6%8C%BF%E5%85%A5%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%E3%80%81%E3%83%B4%E3%82%A7%E3%82%A4%E3%83%B3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
