Command not found
Command not found
郑文豪
Description Resource Path Location Type
make: *** [<builtin>: .o] Error 127 s32k144mcal20M C/C++ Problem
make: cc: Command not found s32k144mcal20M C/C++ Problem
dianabatrlova
Do you use your own project or some example?
Have you tried to clean the project before the build?
Which version of S32DS do you use?
Can you share your project?
Thank you.
Diana
dianabatrlova
Thank you.
Diana
