Cannot see the local static variable in the .map file
826件の閲覧回数
zhlei327
For example, I cannot see the local static variable UDS_ExFlash_PageWrite_step in the .map file. I am using S32K314.
790件の閲覧回数
Senlent
Hi@zhlei327
From the test results, if the variable does not specifically specify the location where it needs to be stored, this will not be displayed in the map file.
