Can S32K3XX support open alliance SPI protocol
633 次查看
Deryck_Tsui
Hello NXP,
        I need use the MAC-PHY transceiver in Ethernet communication which support OA-SPI(Open Alliance SPI) interface. No relerant information was found. Can give me some information about it, thank you for your help.
The document link: OPEN Alliance 10BASE-T1x MAC-PHY Serial Interface (opensig.org)
标记 (1)
584 次查看
PetrS
yes, it generally looks like standard SPI communication, so LPSPI module would be able to handle that. But given protocol has to be done by own.
BR, Petr
585 次查看
PetrS
BR, Petr
560 次查看
Deryck_Tsui
Ok, I got it. Thanks for your reply
