Can Bus Error
Can Bus Error
8,764 次查看
Vamsi421
Presently I am working on NXPS32k344 Board. In  this board i try to implement can protocol by using can controller0 and micro chip can bus analyzer, while i make transmission i am receiving "ERROR PASSIVE" as shown in the attachments.
5 回复数
8,741 次查看
PetrS
most probably it is due to inaccurate bit timing setting.
I see you have PE clock running from FIRC, select rather FXOSC or AIPS_PLAT if running from FXOSC.
BR, Petr
8,727 次查看
Vamsi421
HI @PetrS ,
I changed clock to FXOSC and run my program still it giving same error.
8,710 次查看
PetrS
if a CAN tool is sending a message and stays in error passive with TX error 128, it means opposite site does not ACK this message. So check pin setting and if used CAN transceiver is active. Ideally measure MCU's TX/RX pins and bus signal and check module MCR, ECR, ESR1 registers as well.
BR, Petr
8,543 次查看
Vamsi421
HI @PetrS ,
My code is going to hard fault while executing the line provided in the below attachment.
8,524 次查看
PetrS
if you get fault when access peripheral register it can be caused by missing peripheral clock. So check if peripheral clock is not gated-off.
BR, Petr
