Call LPSPI_DRV_MasterTransferBlocking on S32K144
8,128 次查看
bryan_hong
Senior Contributor I
Dear NXP
If LPSPI_DRV_MasterTransferBlocking be called, wdog_ewm_irqhandler error present.
plz lookup attached file rtos.c line 62.
thanks
Bryan
11 回复数
8,109 次查看
danielmartynek
Hi @bryan_hong,
This is probably a fault exception.
You need to have at least HardFault_Handler() implemented in the project.
Refer to this document / example
https://community.nxp.com/t5/S32K-Knowledge-Base/Fault-handling-on-S32K14x/ta-p/1114447
Thank you,
BR, Daniel
8,088 次查看
bryan_hong
Dear @danielmartynek
thanks for your comments.
I open Example_S32K144_Fault_Handling_v2_S32DS22\ then can not find CFSR to check DIVBYZERO like below.
thanks
Bryan
8,076 次查看
danielmartynek
Hi Bryan,
Select the register in Peripheral Register.
Then, the register can be read in the Watch registers view.
8,072 次查看
bryan_hong
Hi Daniel
I click Window->Peripherals Registers
then Anything did not present
then I click Window->Watch registers, also Anything did not present
I need more detail description
thanks
Bryan
8,068 次查看
danielmartynek
Are the registers missing in your own project and RTD examples?
Or is it just the imported one?
8,047 次查看
bryan_hong
Dear Daniel
I use Example Example_S32K144_Fault_Handling_v2_S32DS22.zip on https://community.nxp.com/t5/S32K-Knowledge-Base/Fault-handling-on-S32K14x/ta-p/1114447
and I did not import anything for this issue.
thanks
Bryan
8,020 次查看
danielmartynek
Hello @bryan_hong,
Can you create a new project from SDK/RTD example a test the view in active debug session?
If this does not work either, can you try with a new workspace?
8,014 次查看
bryan_hong
hi @danielmartynek
You have captured two below. right?
and The below is my status. At that time, I can't this on `Peripheral Registers` and  `CFSR EmbSys Register`.
I create a new project from SDK/RTD example, It's same too. and this is not related with workspace.
I will wait your feedback today.
thanks
Bryan
8,011 次查看
danielmartynek
Hi Bryan,
An expert on the IDE has recommended testing it with a new workspace.
Since this issues is not related to neither LPSPI nor Fault exceptions, can you create a new thread on the S32DS community?
https://community.nxp.com/t5/S32-Design-Studio/bd-p/s32ds
8,005 次查看
bryan_hong
7,867 次查看
bryan_hong
Hi @danielmartynek, Daniel
sorry for delaying answer,
As you know, I had found how to check CSFR register.
https://community.nxp.com/t5/S32-Design-Studio/how-to-check-CSFR-on-S32SD/td-p/1745845
so, I ask my customer to capture the CSFR when the wdog_ewm_irqhandler error was occurred at customer's source and send it to me.
BTW, my customer did not answer for this yet. so I close this case for now and I will reopen for this as soon as I get the answer from customer.
thanks for your helps again~
thanks
Bryan
