CSEc command LOAD_KEY returns ERC_KEY_INVALID for some KeyIDs on S32k148
2,311件の閲覧回数
lwaszniowski
I have encountered an interesting problem. I want to install CSEc keys to S32k148 device. The device is partitioned for 20 keys (uCSEcKeySize = 0x03u). I am using functions calculate_M1_to_M5 and LOAD_KEY from AN5401SW in my code.
It works correctly (the LOAD_KEY function returns value 1 = NO_ERROR) for all KeyIDs (0x04 – 0x0D, 0x14 – 0x18) when the master key is used for authorization.
It also works correctly for KeyIDs 0x04 – 0x0D and 0x15 and 0x17, when the old value of the key itself is used for authorization.
However, when I use the old value of the key itself for authorization, the LOAD_KEY function returns value 8 (KEY_INVALID) for KeyIDs 0x14, 0x16, 0x18.
I am sure that the key value used for authorization is correct (the blank key 0xff…ff). I have tested that LOAD_KEY function returns value 0x80 (KEY_UPDATE_ERROR) when wrong value of the authorization key is used.
I have tested it several times. I always unsecure device by the following sequence:
DBG_CHAL,
DBG_AUTH,
FLASH_DRV_EraseAllBlock,
FLASH_DRV_Program configuration fields on address 0x0400 by values {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFE,0x7F,0xFF,0xFF};
FLASH_DRV_DEFlashPartition
Have anybody any idea what can be the root of the problem?
I can use it with master key authorization, but I want to be sure that I understand the process well.
Libor Waszniowski
2,300件の閲覧回数
lukaszadrapa
Hi @lwaszniowski
I reported a bug in function calculate_M1_to_M5() short time ago. It looks like the root cause is the same in your case. See please the report and suggestion how to fix it below:
In case of keys from second bank (when KBS = 1, keys KEY_11 - KEY_17), it is not possible to use the same key as authorization key when loading a key. Only MASTER_ECU_KEY can be used.
Reason:
AN5401 says that KBS field should not be considered when calculating M1 and M4 values:
However, the function calculate_M1_to_M5() masks KBS only in case of key_id:
If such M1-M5 values are used to load a key to second bank when using the same key as authorization key, ERC_KEY_INVALID is returned.
The solution is to add also this code here:
auth_key_id = auth_key_id & 0x0F;
Then everything works as expected.
Lukas
2 返答(返信)
2,301件の閲覧回数
lukaszadrapa
Hi @lwaszniowski
Reason:
Lukas
2,296件の閲覧回数
lwaszniowski
Thank you very much for fast response, it really works.
Libor Waszniowski
%3CLINGO-SUB%20id%3D%22lingo-sub-1881286%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECSEc%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20LOAD_KEY%20S32k148%20%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%AE%20KeyID%20%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%20ERC_KEY_INVALID%20%E3%82%92%E8%BF%94%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1881286%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E8%88%88%E5%91%B3%E6%B7%B1%E3%81%84%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82S32k148%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%ABCSEc%E3%82%AD%E3%83%BC%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%2020%20%E5%80%8B%E3%81%AE%E3%82%AD%E3%83%BC%20(uCSEcKeySize%20%3D%200x03u)%20%E3%81%AB%E5%88%86%E5%89%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E8%87%AA%E5%88%86%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%20%3CEM%3EAN5401SW%E3%81%8B%E3%82%89calculate_M1_to_M5%3C%2FEM%3E%20%E3%81%A8%20%3CEM%3ELOAD_KEY%3C%2FEM%3E%20%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%20%E3%82%AD%E3%83%BC%E3%81%8C%E6%89%BF%E8%AA%8D%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20KeyID%20(0x04%20%E2%80%93%200x0D%E3%80%810x14%20%E2%80%93%200x18)%20%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E6%AD%A3%E3%81%97%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%20(%20%3CEM%3ELOAD_KEY%3C%2FEM%3E%20%E9%96%A2%E6%95%B0%E3%81%AF%E5%80%A4%201%20%3D%20NO_ERROR%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99)%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81KeyIDs%20%E3%81%AE0x04%20(0x0D%20%E3%81%A8%200x15%20%E3%81%A8%200x17)%20%E3%81%A7%E3%82%82%E6%AD%A3%E3%81%97%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%80%81%E3%82%AD%E3%83%BC%E8%87%AA%E4%BD%93%E3%81%AE%E5%8F%A4%E3%81%84%E5%80%A4%E3%81%8C%E8%AA%8D%E8%A8%BC%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%82%E5%90%8C%E6%A7%98%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%82%AD%E3%83%BC%E8%87%AA%E4%BD%93%E3%81%AE%E5%8F%A4%E3%81%84%E5%80%A4%E3%82%92%E6%89%BF%E8%AA%8D%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%20%3CEM%3ELOAD_KEY%3C%2FEM%3E%20%E9%96%A2%E6%95%B0%E3%81%AF%20KeyIDs%200x14%E3%80%810x16%E3%80%810x18%20%E3%81%AE%E5%80%A4%208%20(KEY_INVALID)%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%AA%8D%E8%A8%BC%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%AD%E3%83%BC%E5%80%A4%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A8%E7%A2%BA%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(%E7%A9%BA%E7%99%BD%E3%81%AE%E3%82%AD%E3%83%BC%200xff...ff)%E3%81%A7%E3%81%99%E3%80%82%E8%AA%8D%E8%A8%BC%E3%82%AD%E3%83%BC%E3%81%AE%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E5%80%A4%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%20%3CEM%3ELOAD_KEY%3C%2FEM%3E%20%E9%96%A2%E6%95%B0%E3%81%8C%E5%80%A40x80(KEY_UPDATE_ERROR)%E3%82%92%E8%BF%94%E3%81%99%E3%81%93%E3%81%A8%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E6%95%B0%E5%9B%9E%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AF%E5%B8%B8%E3%81%AB%E6%AC%A1%E3%81%AE%E9%A0%86%E5%BA%8F%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E5%9B%BA%E5%AE%9A%E8%A7%A3%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EDBG_CHAL%E3%80%81%3C%2FP%3E%3CP%3EDBG_AUTH%E3%80%81%3C%2FP%3E%3CP%3EFLASH_DRV_EraseAllBlock%E3%80%81%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x0400%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%82%92%E5%80%A4%E3%81%A7FLASH_DRV_Program%20%7B0xFF%2C0xFF%2C0xFF%2C0xFF%2C0xFF%2C0xFF%2C0xFF%2C0xFF%2C%200xFF%2C0xFF%2C0xFF%2C0xFF%2C0xFE%2C0x7F%2C0xFF%2C0xFF%7D%3B%3C%2FP%3E%3CP%3EFLASH_DRV_DEFlashPartition%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AE%E6%A0%B9%E6%BA%90%E3%81%8C%E4%BD%95%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%82%92%E8%AA%B0%E3%81%8B%E3%81%8C%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%82%AD%E3%83%BC%E3%81%AE%E8%AA%8D%E8%A8%BC%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E5%8D%81%E5%88%86%E3%81%AB%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3ELibor%20Waszniowski%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1882431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CSEc%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20LOAD_KEY%20%E3%81%8C%20S32k148%20%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%AE%20KeyID%20%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%20ERC_KEY_INVALID%20%E3%82%92%E8%BF%94%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1882431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%85%E9%80%9F%E3%81%AA%E5%AF%BE%E5%BF%9C%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E6%9C%AC%E5%BD%93%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3ELibor%20Waszniowski%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1882363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20CSEc%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20LOAD_KEY%20%E3%81%8C%20S32k148%20%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%AE%20KeyID%20%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%20ERC_KEY_INVALID%20%E3%82%92%E8%BF%94%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1882363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F145729%22%20target%3D%22_blank%22%3E%40lwaszniowski%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E5%B0%91%E3%81%97%E5%89%8D%E3%81%AB%E9%96%A2%E6%95%B0calculate_M1_to_M5()%E3%81%AE%E3%83%90%E3%82%B0%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E6%A0%B9%E6%9C%AC%E7%9A%84%E3%81%AA%E5%8E%9F%E5%9B%A0%E3%81%AF%E5%90%8C%E3%81%98%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A8%E4%BF%AE%E6%AD%A3%E6%96%B9%E6%B3%95%E3%81%AE%E6%8F%90%E6%A1%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E***%3C%2FP%3E%0A%3CP%3E%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%89%E3%83%90%E3%83%B3%E3%82%AF%E3%81%8B%E3%82%89%E3%81%AE%E3%82%AD%E3%83%BC%E3%81%AE%E5%A0%B4%E5%90%88%20(KBS%20%3D%201%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%AD%E3%83%BC%20KEY_11%20-%20KEY_17)%E3%80%81%E3%82%AD%E3%83%BC%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E8%AA%8D%E8%A8%BC%E3%82%AD%E3%83%BC%E3%81%A8%E5%90%8C%E3%81%98%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82MASTER_ECU_KEY%E3%81%AE%E3%81%BF%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%90%86%E7%94%B1%EF%BC%9A%3C%2FP%3E%0A%3CP%3EAN5401%E3%81%AF%E3%80%81M1%E3%81%8A%E3%82%88%E3%81%B3M4%E3%81%AE%E5%80%A4%E3%82%92%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%ABKBS%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%82%92%E8%80%83%E6%85%AE%E3%81%99%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E8%BF%B0%E3%81%B9%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1717650875246.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1717650875246.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F282766i13BF8C88AF947261%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1717650875246.png%22%20alt%3D%22lukaszadrapa_0-1717650875246.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Elukaszadrapa_0-1717650875246.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_1-1717650875053.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_1-1717650875053.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F282767i7214BB0782E051DF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_1-1717650875053.png%22%20alt%3D%22lukaszadrapa_1-1717650875053.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Elukaszadrapa_1-1717650875053.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E9%96%A2%E6%95%B0%20calculate_M1_to_M5()%20%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AEkey_id%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BF%20KBS%20%E3%82%92%E3%83%9E%E3%82%B9%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_2-1717650875130.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_2-1717650875130.png%22%20style%3D%22width%3A%20397px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F282765iD9392FCA9AA6A8E5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_2-1717650875130.png%22%20alt%3D%22lukaszadrapa_2-1717650875130.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Elukaszadrapa_2-1717650875130.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AA%8D%E8%A8%BC%E3%82%AD%E3%83%BC%E3%81%A8%E5%90%8C%E3%81%98%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%20M1-M5%20%E5%80%A4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AD%E3%83%BC%E3%82%92%202%20%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%90%E3%83%B3%E3%82%AF%E3%81%AB%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%E3%81%A8%E3%80%81ERC_KEY_INVALID%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%80%81%E3%81%93%E3%81%93%E3%81%AB%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%82%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3Eauth_key_id%20%3D%20auth_key_id%20%26amp%3B%200x0F%3B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E6%9C%9F%E5%BE%85%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E
