CSEC
CSEC
1,670件の閲覧回数
vramalingam
Enabled cSEC in the bootloader , during any memory write operation in application if power reset happens , we are facing hard fault.
2 返答(返信)
1,566件の閲覧回数
ZEROOO
    You check to see if the location of the fault is PRAM, which is a hard fault if there is an access error
1,649件の閲覧回数
lukaszadrapa
Hi @vramalingam
I think that more details will be needed. Enabled CSEc does not affect memory writes.
What kind of memory writes do you mean? To program flash, data flash, Emulated EEPROM, RAM? If you check the core registers, what's the root cause of hard fault?
Lukas
