CMU interrupt in s32k3xx
已解决
跳至解决方案
1,245 次查看
jhuang1
Hi, I'm adding CMU to my project aim to achive the asil-b level. The chip on my board is s32k312. I found CMU0_IRQ~ CMU2_IRQ in the interrupt map, but I havn't found the interrupt source of the 3 interrupts, do they have any relationship with FCCU?
1 解答
1,233 次查看
petervlna
No, I do not see FCCU faults related to CMU:
They are related to CMU module dirrectly.
I never tested it, but I expect once CMU_0 interrupt is enabled and latched in Status Register (SR) of that CMU module interrupt is called.
Since there is only one interrupt from these signals, you will read the Status Register (SR) of that CMU to find the root cause of that interrupt.
best regards,
Peter
Peter
在原帖中查看解决方案
1 回复
1,234 次查看
petervlna
best regards,
Peter
Peter
