CAN Transmit Issue
CAN Transmit Issue
1,719件の閲覧回数
Vamshi_
Hii,
  Here I am trying to transmit some dummy data from S32K148 to USBCAN_FD Tool using standard CAN, but I am not able to receive any data at the tool and when I am debugging the code I am getting CAN clock not sync, so can you tell me where did i made the mistake and also here I am using TJA1042B CAN transducer. and I have configured it to active mode by setting the pin low.
And also I will share my code and Pics of the config what I did.Screenshot 2025-11-13 054731.pngScreenshot 2025-11-13 054924.pngScreenshot 2025-11-13 054936.pngScreenshot 2025-11-13 054954.pngScreenshot 2025-11-13 055009.pngScreenshot 2025-11-13 055021.pngScreenshot 2025-11-13 055107.pngScreenshot 2025-11-13 055119.pngScreenshot 2025-11-13 055139.pngScreenshot 2025-11-13 055154.pngScreenshot 2025-11-13 055232.pngScreenshot 2025-11-13 055251.pngScreenshot 2025-11-13 055313.pngScreenshot 2025-11-13 055743.png
* (c) Copyright 2020 NXP
* NXP Confidential. This software is owned or controlled by NXP and may only be used strictly
* in accordance with the applicable license terms. By expressly accepting
* such terms or by downloading, installing, activating and/or otherwise using
* the software, you are agreeing that you have read, and that you agree to
* comply with and are bound by, such license terms. If you do not agree to
* be bound by the applicable license terms, then you may not retain,
* install, activate or otherwise use the software.
* This file contains sample code only. It is not part of the production code deliverables.
#ifdef __cplusplus
extern "C" {
#endif
* INCLUDE FILES
* 1) system and project includes
* 2) needed interfaces from external units
* 3) internal and external interfaces from this unit
#include "Mcu.h"
#include "Platform.h"
#include "Can_43_FLEXCAN.h"
#include "SchM_Can_43_FLEXCAN.h"
#include "check_example.h"
#include "stdio.h"
#include "Dio.h"
* LOCAL TYPEDEFS (STRUCTURES, UNIONS, ENUMS)
* LOCAL MACROS
* LOCAL CONSTANTS
* LOCAL VARIABLES
* GLOBAL CONSTANTS
uint8 Can_au8Sdu8bytes[8U] = {0x01U, 0x02U, 0x03U, 0x04U, 0x05U, 0x06U, 0x07U, 0x08};
* GLOBAL VARIABLES
uint8 CanIf_u8TxConfirmCnt = 0U;
boolean CanIf_bTxFlag = FALSE;
uint8 CanIf_u8RxIndicationCnt = 0U;
boolean CanIf_bRxFlag = FALSE;
Std_ReturnType status ;
uint8 dummyData1[8] = {0x11,0x11,0x11,0x11,0x11,0x11,0x11,0x11};
Can_PduType txPdu1;
uint8 rxData[8] = {0}; // Buffer for received data
Can_PduType rxPdu1; // Received PDU object
* LOCAL FUNCTION PROTOTYPES
void CAN_Transmit(uint8* data, uint8 length);
void CAN_Receive(void);
void CAN_WaitForClockSync(void);
* LOCAL FUNCTIONS
* @brief Wait for CAN controller to synchronize with CAN bus clock.
* This should be called after CAN controller is set to STARTED mode.
* The function will timeout if clock synchronization is not achieved.
* GLOBAL FUNCTIONS
void CanIf_ControllerBusOff(uint8 ControllerId)
(void)ControllerId;
void CanIf_ControllerModeIndication(uint8 ControllerId, Can_ControllerStateType ControllerMode )
(void)ControllerId;
(void)ControllerMode;
void CanIf_TxConfirmation(PduIdType CanTxPduId)
CanIf_u8TxConfirmCnt++;
CanIf_bTxFlag = TRUE;
(void)CanTxPduId;
void CanIf_RxIndication(const Can_HwType* Mailbox, const PduInfoType* PduInfoPtr )
CanIf_u8RxIndicationCnt++;
CanIf_bRxFlag = TRUE;
// Copy received data to local buffer for CAN_Receive()
if ((PduInfoPtr != NULL_PTR) && (PduInfoPtr->SduLength <= 8)) {
for (uint8 i = 0; i < PduInfoPtr->SduLength; i++)
rxData[i] = PduInfoPtr->SduDataPtr[i];
rxPdu1.id = Mailbox->CanId;
rxPdu1.length = PduInfoPtr->SduLength;
rxPdu1.sdu = rxData;
(void)Mailbox;
(void)PduInfoPtr;
void Can_DummyDelay(uint32 loops)
VAR( volatile uint32, CAN_VAR) data = 0xAA55AA55;
VAR( volatile uint32, CAN_VAR) contor1 = 0;
VAR( volatile uint32, CAN_VAR) contor2 = loops;
do
for (contor1 = 0; contor1 < 0x2FF; contor1++)
data ^= (1 << contor1) | (0xAAAAAA | contor2);
contor2--;
} while( contor2 > 0);
Can_PduType Can_CreatePduInfo(Can_IdType id, PduIdType swPduHandle, uint8 length, uint8* sdu)
Can_PduType PduInfo;
PduInfo.id = id;
PduInfo.swPduHandle = swPduHandle;
PduInfo.length = length;
PduInfo.sdu = sdu;
return PduInfo;
uint32_t counter1=0;
uint32_t counter2=0;
uint32_t counter3=0;
uint8_t step=0;
// Function for CAN transmit
Can_PduType txPdu;
txPdu.id = 0x111; // Example CAN ID
txPdu.length = length;
txPdu.swPduHandle = 0;
txPdu.sdu = data;
status = Can_43_FLEXCAN_Write(CanHardwareObject_TX, &txPdu);
if(status==E_OK)
printf("CAN_Transmit: Transfer successful\n");
else
printf("CAN_Transmit: Transfer not successful!!\n");
int main(void)
#if (MCU_PRECOMPILE_SUPPORT == STD_ON)
Mcu_Init(NULL_PTR);
#elif (MCU_PRECOMPILE_SUPPORT == STD_OFF)
Mcu_Init(&Mcu_Config_VS_0);
#endif /* (MCU_PRECOMPILE_SUPPORT == STD_ON) */
/* Initialize the clock tree and apply PLL as system clock */
Mcu_InitClock(McuClockSettingConfig_0);
#if (MCU_NO_PLL == STD_OFF)
while ( MCU_PLL_LOCKED != Mcu_GetPllStatus() )
/* Busy wait until the System PLL is locked */
Mcu_DistributePllClock();
#endif
Mcu_SetMode(McuModeSettingConf_0);
/* Initialize Platform driver */
Platform_Init(NULL_PTR);
Can_43_FLEXCAN_Init(NULL_PTR);
Dio_WriteChannel(DioConf_DioChannel_DioChannel_CANSTDBY,STD_LOW);
Can_43_FLEXCAN_SetControllerMode(CanController_0, CAN_CS_STARTED);
txPdu1.id = 0x111;
txPdu1.length = 8;
txPdu1.swPduHandle = 0;
txPdu1.sdu = dummyData1;
while(1)
// Example: transmit and attempt to receive
CAN_Transmit(dummyData1, 8);
Can_DummyDelay(0xFFFFF);
return (0U);
#ifdef __cplusplus
#endif
3 返答(返信)
1,638件の閲覧回数
Senlent
Hi@Vamshi_
Your "Port" configuration is wrong, please refer to below configurations.
1,672件の閲覧回数
Vamshi_
This is my project file.
1,680件の閲覧回数
Senlent
Hi@Vamshi_
Please share your project , and I will take the time to check it for you.
%3CLINGO-SUB%20id%3D%22lingo-sub-2203985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECAN%E9%80%81%E4%BF%A1%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81%E6%A8%99%E6%BA%96%E3%81%AE%20CAN%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20S32K148%20%E3%81%8B%E3%82%89%20USBCAN_FD%20%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AB%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%A8%20CAN%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E5%90%8C%E6%9C%9F%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82SO%E3%80%81%E3%81%A9%E3%81%93%E3%81%A7%E9%96%93%E9%81%95%E3%81%84%E3%82%92%E7%8A%AF%E3%81%97%E3%81%9F%E3%81%AE%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%20TJA1042B%20CAN%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%87%E3%83%A5%E3%83%BC%E3%82%B5%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%83%94%E3%83%B3%E3%82%92%E3%83%AD%E3%83%BC%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E7%A7%81%E3%81%8C%E8%A1%8C%E3%81%A3%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E8%A8%AD%E5%AE%9A%E3%81%AE%E5%86%99%E7%9C%9F%E3%82%82%E5%85%B1%E6%9C%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-11-13%20054731.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-11-13%20054731.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365366i870CFF75BD44D58B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-11-13%20054731.png%22%20alt%3D%22Screenshot%202025-11-13%20054731.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-11-13%20054924.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-11-13%20054924.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365367i0E5A3809344F3AE9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-11-13%20054924.png%22%20alt%3D%22Screenshot%202025-11-13%20054924.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-11-13%20054936.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-11-13%20054936.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365368i11AE89AC686B3E8B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-11-13%20054936.png%22%20alt%3D%22Screenshot%202025-11-13%20054936.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-11-13%20054954.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-11-13%20054954.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365369i1B87C2A694169A92%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-11-13%20054954.png%22%20alt%3D%22Screenshot%202025-11-13%20054954.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-11-13%20055009.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-11-13%20055009.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365370i2E2579C351904430%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-11-13%20055009.png%22%20alt%3D%22Screenshot%202025-11-13%20055009.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-11-13%20055021.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-11-13%20055021.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365371i7C4AA82E6C9E6C9E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-11-13%20055021.png%22%20alt%3D%22Screenshot%202025-11-13%20055021.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-11-13%20055107.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-11-13%20055107.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365372i3B613397E7AAFFC7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-11-13%20055107.png%22%20alt%3D%22Screenshot%202025-11-13%20055107.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-11-13%20055119.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-11-13%20055119.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365373i24FBB6CE74349ED1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-11-13%20055119.png%22%20alt%3D%22Screenshot%202025-11-13%20055119.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-11-13%20055139.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-11-13%20055139.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365374iC226829323C7FA30%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-11-13%20055139.png%22%20alt%3D%22Screenshot%202025-11-13%20055139.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-11-13%20055154.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-11-13%20055154.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365375iFDB355DE841D1C09%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-11-13%20055154.png%22%20alt%3D%22Screenshot%202025-11-13%20055154.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-11-13%20055232.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-11-13%20055232.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365376iAE61F60F04D2F64D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-11-13%20055232.png%22%20alt%3D%22Screenshot%202025-11-13%20055232.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-11-13%20055251.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-11-13%20055251.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365377iDD7732ED92ABBB1F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-11-13%20055251.png%22%20alt%3D%22Screenshot%202025-11-13%20055251.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-11-13%20055313.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-11-13%20055313.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365378iFF89FE6AC95A5A22%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-11-13%20055313.png%22%20alt%3D%22Screenshot%202025-11-13%20055313.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-11-13%20055743.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-11-13%20055743.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365379i93110DB122BA014E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-11-13%20055743.png%22%20alt%3D%22Screenshot%202025-11-13%20055743.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%2F*%3CBR%20%2F%3E%20*%20(c)%202020%20NXP%E3%81%AE%E8%91%97%E4%BD%9C%E6%A8%A9%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20NXP%20%E6%A9%9F%E5%AF%86%E6%83%85%E5%A0%B1%E3%80%82%E3%81%93%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AFNXP%E3%81%8C%E6%89%80%E6%9C%89%E3%81%BE%E3%81%9F%E3%81%AF%E7%AE%A1%E7%90%86%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E5%8E%B3%E5%AF%86%E3%81%AB%3CBR%20%2F%3E*%20%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E6%9D%A1%E9%A0%85%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%82%88%E3%82%8A%3CBR%20%2F%3E*%20%E5%BD%93%E8%A9%B2%E8%A6%8F%E7%B4%84%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%80%81%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%99%E3%83%BC%E3%83%88%E3%80%81%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%3CBR%20%2F%3E*%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%81%94%E5%88%A9%E7%94%A8%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8F%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E6%9C%AC%E8%A6%8F%E7%B4%84%E3%82%92%E3%81%8A%E8%AA%AD%E3%81%BF%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%97%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A8%E3%81%BF%E3%81%AA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20*%20%E3%81%8B%E3%81%8B%E3%82%8B%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E6%9D%A1%E9%A0%85%E3%82%92%E9%81%B5%E5%AE%88%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%81%AB%E6%8B%98%E6%9D%9F%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E5%90%8C%E6%84%8F%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%3CBR%20%2F%3E*%20%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E6%9D%A1%E9%A0%85%E3%81%AB%E6%8B%98%E6%9D%9F%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%3CBR%20%2F%3E%20*%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%80%81%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8C%96%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%81%BF%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E8%A3%BD%E5%93%81%E7%89%88%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E6%88%90%E6%9E%9C%E7%89%A9%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E*%2F%3C%2FP%3E%3CP%3E%23ifdef%20__cplusplus%3CBR%20%2F%3E%E5%A4%96%E9%83%A8%20%22C%22%20%7B%3CBR%20%2F%3E%20%23endif%3C%2FP%3E%3CP%3E%2F*%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%20*%20%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3CBR%20%2F%3E*%201)%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A8%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%202)%20%E5%A4%96%E9%83%A8%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%8B%E3%82%89%E3%81%AE%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3CBR%20%2F%3E*%203)%20%E3%81%93%E3%81%AE%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%AE%E5%86%85%E9%83%A8%E3%81%8A%E3%82%88%E3%81%B3%E5%A4%96%E9%83%A8%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D*%2F%3CBR%20%2F%3E%20%23include%20%22Mcu.h%22%3CBR%20%2F%3E%23include%20%22%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0.h%22%3CBR%20%2F%3E%23include%20%22Can_43_FLEXCAN.h%22%3CBR%20%2F%3E%20%23include%20%22SchM_Can_43_FLEXCAN.h%22%3CBR%20%2F%3E%20%23include%20%22check_example.h%22%3CBR%20%2F%3E%20%23include%20%22stdio.h%22%3CBR%20%2F%3E%23include%20%22Dio.h%22%3C%2FP%3E%3CP%3E%2F*%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%20*%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E5%9E%8B%E5%AE%9A%E7%BE%A9%EF%BC%88%E6%A7%8B%E9%80%A0%E4%BD%93%E3%80%81%E5%85%B1%E7%94%A8%E4%BD%93%E3%80%81%E5%88%97%E6%8C%99%E5%9E%8B%EF%BC%89%3CBR%20%2F%3E%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D*%2F%3C%2FP%3E%3CP%3E%2F*%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%20*%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%9E%E3%82%AF%E3%83%AD%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D*%2F%3C%2FP%3E%3CP%3E%2F*%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%20*%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E5%AE%9A%E6%95%B0%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D*%2F%3C%2FP%3E%3CP%3E%2F*%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%20*%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E5%A4%89%E6%95%B0%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D*%2F%3C%2FP%3E%3CP%3E%2F*%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%20*%20%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E5%AE%9A%E6%95%B0%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D*%2F%3C%2FP%3E%3CP%3Euint8%20Can_au8Sdu8bytes%5B8U%5D%20%3D%20%7B0x01U%2C%200x02U%2C%200x03U%2C%200x04U%2C%200x05U%2C%200x06U%2C%200x07U%2C%200x08%7D%3B%3C%2FP%3E%3CP%3E%2F*%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%20*%20%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E5%A4%89%E6%95%B0%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D*%2F%3C%2FP%3E%3CP%3Euint8%20CanIf_u8TxconfirmCnt%20%3D%200U%3B%3CBR%20%2F%3E%E3%83%96%E3%83%BC%E3%83%AB%E5%80%A4%20CanIf_bTxFlag%20%3D%20FALSE%3B%3CBR%20%2F%3E%20uint8%20CanIf_u8RxIndicationCnt%20%3D%200U%3B%3CBR%20%2F%3E%E3%83%96%E3%83%BC%E3%83%AB%E5%80%A4%20CanIf_bRxFlag%20%3D%20FALSE%3B%3CBR%20%2F%3E%20Std_ReturnType%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3B%3CBR%20%2F%3E%20uint8%20%E3%83%80%E3%83%9F%E3%83%BC%E3%83%87%E3%83%BC%E3%82%BF1%5B8%5D%20%3D%20%7B0x11%2C0x11%2C0x11%2C0x11%2C0x11%2C0x11%2C0x11%2C0x11%7D%3B%3CBR%20%2F%3E%20Can_PduType%20txPdu1%3B%3CBR%20%2F%3E%20uint8%20rxData%5B8%5D%20%3D%20%7B0%7D%3B%20%2F%2F%20%E5%8F%97%E4%BF%A1%E3%83%87%E3%83%BC%E3%82%BF%E7%94%A8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%3CBR%20%2F%3ECan_PduType%20rxPdu1%3B%20%2F%2F%20%E5%8F%97%E4%BF%A1PDU%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3C%2FP%3E%3CP%3E%2F*%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%20*%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E9%96%A2%E6%95%B0%E3%83%97%E3%83%AD%E3%83%88%E3%82%BF%E3%82%A4%E3%83%97%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D*%2F%3CBR%20%2F%3E%20void%20CAN_Transmit(uint8*%20%E3%83%87%E3%83%BC%E3%82%BF%E3%80%81uint8%20%E9%95%B7%E3%81%95)%3B%3CBR%20%2F%3E%20void%20CAN_Receive(void)%3B%3CBR%20%2F%3E%20CAN_WaitForClockSync%20%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%2F*%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%20*%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E9%96%A2%E6%95%B0%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D*%2F%3C%2FP%3E%3CP%3E%2F**%3CBR%20%2F%3E%20*%20%40brief%20CAN%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%8C%20CAN%20%E3%83%90%E3%82%B9%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%E5%90%8C%E6%9C%9F%E3%81%99%E3%82%8B%E3%81%BE%E3%81%A7%E5%BE%85%E6%A9%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%20CAN%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%8C%20STARTED%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E5%BE%8C%E3%81%AB%E3%81%93%E3%82%8C%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%90%8C%E6%9C%9F%E3%81%8C%E9%81%94%E6%88%90%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E9%96%A2%E6%95%B0%E3%81%AF%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%2F%3C%2FP%3E%3CP%3E%2F*%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%20*%20%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E9%96%A2%E6%95%B0%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D*%2F%3C%2FP%3E%3CP%3Evoid%20CanIf_ControllerBusOff(uint8%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20ID)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20(void)%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCID%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3Evoid%20CanIf_ControllerModeIndication(uint8%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCID%E3%80%81Can_ControllerStateType%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20(void)%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCID%3B%3CBR%20%2F%3E%20(void)%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3Evoid%20CanIf_Txconfirmation(PduIdType%20CanTxPduId)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20CanIf_u8TxConfirmCnt%2B%2B%3B%3CBR%20%2F%3E%20CanIf_bTxFlag%20%3D%20TRUE%3B%3CBR%20%2F%3E%20(void)CanTxPduId%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3Evoid%20CanIf_RxIndication(const%20Can_HwType*%20%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%80%81const%20PduInfoType*%20PduInfoPtr%20)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20CanIf_u8RxIndicationCnt%2B%2B%3B%3CBR%20%2F%3E%20CanIf_bRxFlag%20%3D%20TRUE%3B%3C%2FP%3E%3CP%3E%2F%2F%20%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92CAN_Receive()%E3%81%AE%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%3CBR%20%2F%3E((PduInfoPtr%20!%3D%20NULL_PTR)%20%26amp%3B%26amp%3B%20(PduInfoPtr-%26gt%3BSduLength%20%26lt%3B%3D%208))%20%E3%81%AE%E5%A0%B4%E5%90%88%20%7B%3CBR%20%2F%3E%20(uint8%20i%20%3D%200%3B%20i%20%26lt%3B%20PduInfoPtr-%26gt%3BSduLength%3B%20i%2B%2B)%20%E3%81%AE%E5%A0%B4%E5%90%88%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20rxData%5Bi%5D%20%3D%20PduInfoPtr-%26gt%3BSduDataPtr%5Bi%5D%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20rxPdu1.id%20%3D%20%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9-%26gt%3BCanId%3B%3CBR%20%2F%3E%20rxPdu1.length%20%3D%20PduInfoPtr-%26gt%3BSduLength%3B%3CBR%20%2F%3E%20rxPdu1.sdu%20%3D%20rxData%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E(void)%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3B%3CBR%20%2F%3E%20(void)PduInfoPtr%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3Evoid%20Can_DummyDelay(uint32%20%E3%83%AB%E3%83%BC%E3%83%97)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20VAR(%E6%8F%AE%E7%99%BA%E6%80%A7%20uint32%E3%80%81CAN_VAR)%20%E3%83%87%E3%83%BC%E3%82%BF%20%3D%200xAA55AA55%3B%3CBR%20%2F%3E%20VAR(%20volatile%20uint32%2C%20CAN_VAR)%20contor1%20%3D%200%3B%3CBR%20%2F%3E%20VAR(%20volatile%20uint32%2C%20CAN_VAR)%20contor2%20%3D%20loops%3B%3CBR%20%2F%3E%E3%81%99%E3%82%8B%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20(contor1%20%3D%200%3B%20contor1%20%26lt%3B%200x2FF%3B%20contor1%2B%2B)%20%E3%81%AE%E5%A0%B4%E5%90%88%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%20%5E%3D%20(1%20%26lt%3B%26lt%3B%20%E3%82%B3%E3%83%B3%E3%82%BF%E3%83%BC1)%20%7C%20(0xAAAAAA%20%7C%20%E3%82%B3%E3%83%B3%E3%82%BF%E3%83%BC2)%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%82%BF%E3%83%BC2--%3B%3CBR%20%2F%3E%20%7D%20while(contor2%20%26gt%3B%200)%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3ECan_PduType%20Can_CreatePduInfo(Can_IdType%20id%E3%80%81PduIdType%20swPduHandle%E3%80%81uint8%20%E9%95%B7%E3%81%95%E3%80%81uint8*%20sdu)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20Can_PduType%20Pdu%E6%83%85%E5%A0%B1%3B%3C%2FP%3E%3CP%3EPduInfo.id%20%3D%20id%3B%3CBR%20%2F%3E%20PduInfo.swPduHandle%20%3D%20swPduHandle%3B%3CBR%20%2F%3E%20PduInfo.length%20%3D%20%E9%95%B7%E3%81%95%3B%3CBR%20%2F%3E%20PduInfo.sdu%20%3D%20sdu%3B%3C%2FP%3E%3CP%3EPduInfo%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3Euint32_t%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC1%3D0%3B%3CBR%20%2F%3E%20uint32_t%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC2%20%3D%200%3B%3CBR%20%2F%3E%20uint32_t%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC3%20%3D%200%3B%3CBR%20%2F%3E%20uint8_t%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%3D0%3B%3C%2FP%3E%3CP%3E%2F%2F%20CAN%E9%80%81%E4%BF%A1%E9%96%A2%E6%95%B0%3CBR%20%2F%3Evoid%20CAN_Transmit(uint8*%20%E3%83%87%E3%83%BC%E3%82%BF%E3%80%81uint8%20%E9%95%B7%E3%81%95)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20Can_PduType%20txPdu%3B%3CBR%20%2F%3E%20txPdu.id%20%3D%200x111%3B%20%2F%2F%20CAN%20ID%E3%81%AE%E4%BE%8B%3CBR%20%2F%3EtxPdu.length%20%3D%20%E9%95%B7%E3%81%95%3B%3CBR%20%2F%3E%20txPdu.swPdu%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%20%3D%200%3B%3CBR%20%2F%3E%20txPdu.sdu%20%3D%20%E3%83%87%E3%83%BC%E3%82%BF%3B%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20Can_43_FLEXCAN_Write(CanHardwareObject_TX%2C%20%26amp%3BtxPdu)%3B%3CBR%20%2F%3E%20if(%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3D%3DE_OK)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20printf(%22CAN_Transmit%3A%20%E8%BB%A2%E9%80%81%E6%88%90%E5%8A%9F%5Cn%22)%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20printf(%22CAN_Transmit%3A%20%E8%BB%A2%E9%80%81%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F!!%5Cn%22)%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Eint%20%E3%83%A1%E3%82%A4%E3%83%B3(void)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20CanIf_bTxFlag%20%3D%20FALSE%3B%3CBR%20%2F%3E%20CanIf_bRxFlag%20%3D%20FALSE%3B%3CBR%20%2F%3E%20%23if%20(MCU_PRECOMPILE_SUPPORT%20%3D%3D%20STD_ON)%3CBR%20%2F%3E%20Mcu_Init(NULL_PTR)%3B%3CBR%20%2F%3E%20%23elif%20(MCU_PRECOMPILE_SUPPORT%20%3D%3D%20STD_OFF)%3CBR%20%2F%3E%20Mcu_Init(%26amp%3BMcu_Config_VS_0)%3B%3CBR%20%2F%3E%20%23endif%20%2F*%20(MCU_PRECOMPILE_SUPPORT%20%3D%3D%20STD_ON)%20*%2F%3CBR%20%2F%3E%20%2F*%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%80%81PLL%E3%82%92%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%E3%81%97%E3%81%A6%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3CBR%20%2F%3E%20Mcu_InitClock(McuClockSettingConfig_0)%3B%3CBR%20%2F%3E%20%23if%20(MCU_NO_PLL%20%3D%3D%20STD_OFF)%3CBR%20%2F%3E%20(MCU_PLL_LOCKED%20!%3D%20Mcu_GetPllStatus()%20)%20%E3%81%AE%E9%96%93%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20%2F*%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0PLL%E3%81%8C%E3%83%AD%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%82%8B%E3%81%BE%E3%81%A7%E3%83%93%E3%82%B8%E3%83%BC%E5%BE%85%E6%A9%9F%20*%2F%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20Mcu_DistributePllClock()%3B%3CBR%20%2F%3E%20%23endif%3CBR%20%2F%3E%20Mcu_SetMode(McuModeSettingConf_0)%3B%3CBR%20%2F%3E%20%2F*%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%99%E3%82%8B%20*%2F%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E5%88%9D%E6%9C%9F%E5%8C%96(NULL_PTR)%3B%3CBR%20%2F%3E%20Can_43_FLEXCAN_Init(NULL_PTR)%3B%3C%2FP%3E%3CP%3EDio_WriteChannel(DioConf_DioChannel_DioChannel_CANSTDBY%E3%80%81STD_LOW)%3B%3C%2FP%3E%3CP%3ECan_43_FLEXCAN_SetControllerMode(CanController_0%E3%80%81CAN_CS_STARTED)%3B%3C%2FP%3E%3CP%3E%2F*%20-------%20*%2F%3C%2FP%3E%3CP%3EtxPdu1.id%20%3D%200x111%3B%3CBR%20%2F%3E%20txPdu1.%E9%95%B7%E3%81%95%20%3D%208%3B%3CBR%20%2F%3E%20txPdu1.swPdu%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%20%3D%200%3B%3CBR%20%2F%3E%20txPdu1.sdu%20%3D%20%E3%83%80%E3%83%9F%E3%83%BC%E3%83%87%E3%83%BC%E3%82%BF1%3B%3C%2FP%3E%3CP%3E%E3%81%AA%E3%81%8C%E3%82%89(1)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20%2F%2F%20%E4%BE%8B%3A%20%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E5%8F%97%E4%BF%A1%E3%82%92%E8%A9%A6%E3%81%BF%E3%82%8B%3CBR%20%2F%3ECAN_Transmit(%E3%83%80%E3%83%9F%E3%83%BC%E3%83%87%E3%83%BC%E3%82%BF1%E3%80%818)%3B%3CBR%20%2F%3E%20Can_%E3%83%80%E3%83%9F%E3%83%BC%E9%81%85%E5%BB%B6(0xFFFFF)%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%E6%88%BB%E3%82%8A%E5%80%A4%20(0U)%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%23ifdef%20__cplusplus%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%23endif%3C%2FP%3E%3CP%3E%2F**%20%40%7D%20*%2F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204939%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20Transmit%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204939%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22mailto%3AHi%40Vamshi_%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%40Vamshi_%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%80%8C%E3%83%9D%E3%83%BC%E3%83%88%E3%80%8D%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_0-1763102788099.png%22%20style%3D%22width%3A%20560px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1763102788099.png%22%20style%3D%22width%3A%20560px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365639i34A65A513BD03AC6%2Fimage-dimensions%2F560x311%3Fv%3Dv2%22%20width%3D%22560%22%20height%3D%22311%22%20role%3D%22button%22%20title%3D%22Senlent_0-1763102788099.png%22%20alt%3D%22Senlent_0-1763102788099.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_1-1763102794984.png%22%20style%3D%22width%3A%20556px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1763102794984.png%22%20style%3D%22width%3A%20556px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365640i9F323B34A226309A%2Fimage-dimensions%2F556x335%3Fv%3Dv2%22%20width%3D%22556%22%20height%3D%22335%22%20role%3D%22button%22%20title%3D%22Senlent_1-1763102794984.png%22%20alt%3D%22Senlent_1-1763102794984.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_2-1763102810362.png%22%20style%3D%22width%3A%20556px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_2-1763102810362.png%22%20style%3D%22width%3A%20556px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365641i04371D8C1FC76D31%2Fimage-dimensions%2F556x335%3Fv%3Dv2%22%20width%3D%22556%22%20height%3D%22335%22%20role%3D%22button%22%20title%3D%22Senlent_2-1763102810362.png%22%20alt%3D%22Senlent_2-1763102810362.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_3-1763102942518.png%22%20style%3D%22width%3A%20558px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_3-1763102942518.png%22%20style%3D%22width%3A%20558px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365642i721C5E59609F9708%2Fimage-dimensions%2F558x267%3Fv%3Dv2%22%20width%3D%22558%22%20height%3D%22267%22%20role%3D%22button%22%20title%3D%22Senlent_3-1763102942518.png%22%20alt%3D%22Senlent_3-1763102942518.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204493%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20Transmit%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204493%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204300%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20Transmit%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204300%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CSPAN%3E%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256519%22%3E%40Vamshi_%3C%2Fa%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E6%99%82%E9%96%93%E3%82%92%E3%81%8B%E3%81%91%E3%81%A6%E7%A2%BA%E8%AA%8D%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
