CAN Message loopback
Sharath_NXP
Hello Sir
I using #S32K148  and TJA1145_CAN_Transceiver
Here when i send CAN ID 0x50 from Canalyzer , i'm getting an echo of same in CAN ID 0x601.
i also checked that  FDCTRL[TDCEN] = 0 , yet i'm seeing the echo messages.
Kindly help me stop this echo (0x601)
Sharath
Senlent
Hi@Sharath_NXP
Without more information, I can't help you determine what the problem is.
Can you provide sample code? I can help you to check the code related to your CAN module.
