CAN_DeInit API Error
Embedded_novice
HI.
I attempted to shut down the CAN controller before the BOOTLOADER jumped to the APP, but when I called CAN_DeInit, it actually wasn't re-initialized, resulting in incorrect frames being sent on the CAN bus after the jump. I would like to know if there are any problems with this logical judgment. I have set CtrlState to TRUE, but the reverse initialization requires it to be FALSE in order to execute.CAN_DeInit.png
Julián_AragónM
Hi @Embedded_novice
1. The controller modes are defined in the AUTOSAR specification, thus described in the FlexCAN MCAL driver user manual found under the following path: "C:\NXP\S32DS.3.X.X\S32DS\software\PlatformSDK_S32K3\RTD\Can_43_FLEXCAN\doc\RTD_CAN_43_FLEXCAN_UM.pdf"
2. By AUTOSAR standards, yes, it is mandatory. The processing logic depends on the driver implementation. For example, in the FlexCAN driver, functions called are FlexCAN_Ip_SetStartMode() and FlexCAN_Ip_SetStopMode(), both of which enable and disable the module, respectively.
AUTOSAR specification also provides a transition diagram in their CAN specification document:
Julián
Julián_AragónM
Hi @Embedded_novice,
Before calling CAN_DeInit, set all controllers to STOPPED to allow it to de-init properly:
/* Stop Can controller */
Can_43_FLEXCAN_SetControllerMode(Can_43_FLEXCANConf_CanController_CanController_0, CAN_CS_STOPPED);
/* De-Initialize Can driver */
Can_43_FLEXCAN_DeInit();
Julián
Embedded_novice
Hi.
I understand your train of thought now. I would like to know if this state transition diagram is correct. Additionally, I have two more questions:
1. Where can I find this state transition in the manual of the MCU? I didn't see any similar state description in the RM.
2. Is this state transition mandatory? Is the same processing logic applied in other MCU architectures?
Julián_AragónM
Hi @Embedded_novice
Julián
%3CLINGO-SUB%20id%3D%22lingo-sub-2189148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECAN_DeInit%20API%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI.%3C%2FP%3E%3CP%3EI%20attempted%20to%20shut%20down%20the%20CAN%20controller%20before%20the%20BOOTLOADER%20jumped%20to%20the%20APP%2C%20but%20when%20I%20called%20CAN_DeInit%2C%20it%20actually%20wasn't%20re-initialized%2C%20resulting%20in%20incorrect%20frames%20being%20sent%20on%20the%20CAN%20bus%20after%20the%20jump.%20I%20would%20like%20to%20know%20if%20there%20are%20any%20problems%20with%20this%20logical%20judgment.%20I%20have%20set%20CtrlState%20to%20TRUE%2C%20but%20the%20reverse%20initialization%20requires%20it%20to%20be%20FALSE%20in%20order%20to%20execute.%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CAN_DeInit.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CAN_DeInit.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361650i4E55AA0680B38758%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22CAN_DeInit.png%22%20alt%3D%22CAN_DeInit.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN_DeInit%20API%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213197%22%20target%3D%22_blank%22%3E%40Embedded_novice%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E1.%20The%20controller%20modes%20are%20defined%20in%20the%20AUTOSAR%20specification%2C%20thus%20described%20in%20the%20FlexCAN%20MCAL%20driver%20user%20manual%20found%20under%20the%20following%20path%3A%20%22%3CSTRONG%3EC%3A%5CNXP%5CS32DS.3.X.X%5CS32DS%5Csoftware%5CPlatformSDK_S32K3%5CRTD%5CCan_43_FLEXCAN%5Cdoc%5CRTD_CAN_43_FLEXCAN_UM.pdf%3C%2FSTRONG%3E%22%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snag_a0158d5.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_a0158d5.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362154iC909B41A57E9BC49%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Snag_a0158d5.png%22%20alt%3D%22Snag_a0158d5.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E2.%20By%20AUTOSAR%20standards%2C%20yes%2C%20it%20is%20mandatory.%20The%20processing%20logic%20depends%20on%20the%20driver%20implementation.%20For%20example%2C%20in%20the%20FlexCAN%20driver%2C%20functions%20called%20are%26nbsp%3B%3CSPAN%3EFlexCAN_Ip_SetStartMode()%20and%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EFlexCAN_Ip_SetStopMode()%2C%20both%20of%20which%20enable%20and%20disable%20the%20module%2C%20respectively.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EAUTOSAR%20specification%20also%20provides%20a%20transition%20diagram%20in%20their%20CAN%20specification%20document%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snag_a0e08b2.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_a0e08b2.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362155i2F6D00495DE4E6C0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Snag_a0e08b2.png%22%20alt%3D%22Snag_a0e08b2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN_DeInit%20API%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi.%3C%2FP%3E%3CP%3EI%20understand%20your%20train%20of%20thought%20now.%20I%20would%20like%20to%20know%20if%20this%20state%20transition%20diagram%20is%20correct.%20Additionally%2C%20I%20have%20two%20more%20questions%3A%3CBR%20%2F%3E1.%20Where%20can%20I%20find%20this%20state%20transition%20in%20the%20manual%20of%20the%20MCU%3F%20I%20didn't%20see%20any%20similar%20state%20description%20in%20the%20RM.%3CBR%20%2F%3E2.%20Is%20this%20state%20transition%20mandatory%3F%20Is%20the%20same%20processing%20logic%20applied%20in%20other%20MCU%20architectures%3F%3CBR%20%2F%3EThank%20you%20very%20much%20for%20your%20help!%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ModeSwitch.png%22%20style%3D%22width%3A%20844px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ModeSwitch.png%22%20style%3D%22width%3A%20844px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361982iEC375E02605EABA1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22ModeSwitch.png%22%20alt%3D%22ModeSwitch.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190147%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN_DeInit%20API%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190147%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213197%22%20target%3D%22_blank%22%3E%40Embedded_novice%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EBefore%20calling%20CAN_DeInit%2C%20set%20all%20controllers%20to%20STOPPED%20to%20allow%20it%20to%20de-init%20properly%3A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3E%2F*%20Stop%20Can%20controller%20*%2F%0ACan_43_FLEXCAN_SetControllerMode(Can_43_FLEXCANConf_CanController_CanController_0%2C%20CAN_CS_STOPPED)%3B%0A%0A%2F*%20De-Initialize%20Can%20driver%20*%2F%0ACan_43_FLEXCAN_DeInit()%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%3C%2FLINGO-BODY%3E
