C40 Code Memory Allocation – Hard Fault When Changing Sector
GaneshBhagwat
I’m working with the C40 flash memory driver and used the following configuration, which works fine with the default project settings:
#define EXAMPLE_MASTER_ID         (0U)
#define EXAMPLE_SECTOR_START_ADDR (0x00600000U)
#define EXAMPLE_SECTOR_TEST       (C40_CODE_ARRAY_0_BLOCK_1_S256)
#define EXAMPLE_BUFFER_SIZE       (64U) // or 128U
However, when I change the settings to:
#define EXAMPLE_SECTOR_START_ADDR (0x00500000U)
#define EXAMPLE_SECTOR_TEST       (C40_CODE_ARRAY_0_BLOCK_0_S128)
the program hits a hard fault.
Could anyone clarify what might cause this issue?
From my understanding, possible causes could be:
  • The selected start address overlaps with a protected or reserved flash region.
  • The sector/block size definition (C40_CODE_ARRAY_0_BLOCK_0_S128) doesn’t match the actual memory map for the device.
  • Attempting to write or erase from a block where the code is currently executing.
  • Misalignment with the flash controller’s sector boundaries.
I’ve attached an image showing the issue in more detail.
Thanks and Regards,
Ganesh Bhagwat
Senlent
Hi@GaneshBhagwat
This should be an Read-While-Write Event Error(RWE), you need to put flash operation into SRAM to avoid RWE.
Please refer to this post:
https://community.nxp.com/t5/S32K-Knowledge-Base/S32K312-C40-Ip-SRAM-RTD-500-DS35/ta-p/2074245
%3CLINGO-SUB%20id%3D%22lingo-sub-2151017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EC40%20Code%20Memory%20Allocation%20%E2%80%93%20Hard%20Fault%20When%20Changing%20Sector%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%3CP%3EI%E2%80%99m%20working%20with%20the%20C40%20flash%20memory%20driver%20and%20used%20the%20following%20configuration%2C%20which%20works%20fine%20with%20the%20default%20project%20settings%3A%3C%2FP%3E%3CPRE%3E%23define%20EXAMPLE_MASTER_ID%20%20%20%20%20%20%20%20%20(0U)%0A%23define%20EXAMPLE_SECTOR_START_ADDR%20(0x00600000U)%0A%23define%20EXAMPLE_SECTOR_TEST%20%20%20%20%20%20%20(C40_CODE_ARRAY_0_BLOCK_1_S256)%0A%23define%20EXAMPLE_BUFFER_SIZE%20%20%20%20%20%20%20(64U)%20%2F%2F%20or%20128U%3C%2FPRE%3E%3CP%3EHowever%2C%20when%20I%20change%20the%20settings%20to%3A%3C%2FP%3E%3CPRE%3E%23define%20EXAMPLE_MASTER_ID%20%20%20%20%20%20%20%20%20(0U)%0A%23define%20EXAMPLE_SECTOR_START_ADDR%20(0x00500000U)%0A%23define%20EXAMPLE_SECTOR_TEST%20%20%20%20%20%20%20(C40_CODE_ARRAY_0_BLOCK_0_S128)%0A%23define%20EXAMPLE_BUFFER_SIZE%20%20%20%20%20%20%20(64U)%20%2F%2F%20or%20128U%3C%2FPRE%3E%3CP%3Ethe%20program%20hits%20a%20%3CSTRONG%3Ehard%20fault%3C%2FSTRONG%3E.%3C%2FP%3E%3CP%3ECould%20anyone%20clarify%20what%20might%20cause%20this%20issue%3F%3CBR%20%2F%3EFrom%20my%20understanding%2C%20possible%20causes%20could%20be%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EThe%20selected%20start%20address%20overlaps%20with%20a%20protected%20or%20reserved%20flash%20region.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EThe%20sector%2Fblock%20size%20definition%20(C40_CODE_ARRAY_0_BLOCK_0_S128)%20doesn%E2%80%99t%20match%20the%20actual%20memory%20map%20for%20the%20device.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EAttempting%20to%20write%20or%20erase%20from%20a%20block%20where%20the%20code%20is%20currently%20executing.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EMisalignment%20with%20the%20flash%20controller%E2%80%99s%20sector%20boundaries.%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EI%E2%80%99ve%20attached%20an%20image%20showing%20the%20issue%20in%20more%20detail.%3C%2FP%3E%3CP%3EThanks%20and%20Regards%2C%3C%2FP%3E%3CP%3EGanesh%20Bhagwat%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20C40%20Code%20Memory%20Allocation%20%E2%80%93%20Hard%20Fault%20When%20Changing%20Sector%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CSPAN%3EGaneshBhagwat%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThis%20should%20be%20an%20Read-While-Write%20Event%20Error(RWE)%2C%20you%20need%20to%20put%20flash%20operation%20into%20SRAM%20to%20avoid%20RWE.%3C%2FP%3E%0A%3CP%3EPlease%20refer%20to%20this%20post%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K312-C40-Ip-SRAM-RTD-500-DS35%2Fta-p%2F2074245%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K312-C40-Ip-SRAM-RTD-500-DS35%2Fta-p%2F2074245%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
