C40 Code Memory Allocation – Hard Fault When Changing Sector
1,288 次查看
GaneshBhagwat
I’m working with the C40 flash memory driver and used the following configuration, which works fine with the default project settings:
#define EXAMPLE_MASTER_ID         (0U)
#define EXAMPLE_SECTOR_START_ADDR (0x00600000U)
#define EXAMPLE_SECTOR_TEST       (C40_CODE_ARRAY_0_BLOCK_1_S256)
#define EXAMPLE_BUFFER_SIZE       (64U) // or 128U
However, when I change the settings to:
#define EXAMPLE_SECTOR_START_ADDR (0x00500000U)
#define EXAMPLE_SECTOR_TEST       (C40_CODE_ARRAY_0_BLOCK_0_S128)
the program hits a hard fault.
Could anyone clarify what might cause this issue?
From my understanding, possible causes could be:
  • The selected start address overlaps with a protected or reserved flash region.
  • The sector/block size definition (C40_CODE_ARRAY_0_BLOCK_0_S128) doesn’t match the actual memory map for the device.
  • Attempting to write or erase from a block where the code is currently executing.
  • Misalignment with the flash controller’s sector boundaries.
I’ve attached an image showing the issue in more detail.
Thanks and Regards,
Ganesh Bhagwat
1,269 次查看
Senlent
Hi@GaneshBhagwat
This should be an Read-While-Write Event Error(RWE), you need to put flash operation into SRAM to avoid RWE.
Please refer to this post:
https://community.nxp.com/t5/S32K-Knowledge-Base/S32K312-C40-Ip-SRAM-RTD-500-DS35/ta-p/2074245
%3CLINGO-SUB%20id%3D%22lingo-sub-2151017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EC40%20%E4%BB%A3%E7%A0%81%E5%86%85%E5%AD%98%E5%88%86%E9%85%8D%20-%20%E6%9B%B4%E6%94%B9%E6%89%87%E5%8C%BA%E6%97%B6%E5%87%BA%E7%8E%B0%E7%A1%AC%E6%95%85%E9%9A%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20C40%20%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%85%8D%E7%BD%AE%EF%BC%8C%E5%9C%A8%E9%BB%98%E8%AE%A4%E9%A1%B9%E7%9B%AE%E8%AE%BE%E7%BD%AE%E4%B8%8B%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%EF%BC%9A%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%23define%20EXAMPLE_MASTER_ID%20%20%20%20%20%20%20%20%20(0U)%0A%23define%20EXAMPLE_SECTOR_START_ADDR%20(0x00600000U)%0A%23define%20EXAMPLE_SECTOR_TEST%20%20%20%20%20%20%20(C40_CODE_ARRAY_0_BLOCK_1_S256)%0A%23define%20EXAMPLE_BUFFER_SIZE%20%20%20%20%20%20%20(64U)%20%2F%2F%20or%20128U%3C%2FPRE%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E5%B0%86%E8%AE%BE%E7%BD%AE%E6%9B%B4%E6%94%B9%E4%B8%BA%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%23define%20EXAMPLE_MASTER_ID%20%20%20%20%20%20%20%20%20(0U)%0A%23define%20EXAMPLE_SECTOR_START_ADDR%20(0x00500000U)%0A%23define%20EXAMPLE_SECTOR_TEST%20%20%20%20%20%20%20(C40_CODE_ARRAY_0_BLOCK_0_S128)%0A%23define%20EXAMPLE_BUFFER_SIZE%20%20%20%20%20%20%20(64U)%20%2F%2F%20or%20128U%3C%2FPRE%3E%3CP%3E%E7%A8%8B%E5%BA%8F%E5%B0%B1%E4%BC%9A%E5%87%BA%E7%8E%B0%3CSTRONG%3E%E4%B8%A5%E9%87%8D%E6%95%85%E9%9A%9C%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E8%B0%81%E8%83%BD%E8%AF%B4%E6%98%8E%E6%98%AF%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%E5%AF%BC%E8%87%B4%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3CBR%20%2F%3E%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8C%E5%8F%AF%E8%83%BD%E7%9A%84%E5%8E%9F%E5%9B%A0%E6%9C%89%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E6%89%80%E9%80%89%E8%B5%B7%E5%A7%8B%E5%9C%B0%E5%9D%80%E4%B8%8E%E5%8F%97%E4%BF%9D%E6%8A%A4%E6%88%96%E4%BF%9D%E7%95%99%E7%9A%84%E9%97%AA%E5%AD%98%E5%8C%BA%E5%9F%9F%E9%87%8D%E5%8F%A0%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%89%87%E5%8C%BA%2F%E5%8C%BA%E5%9D%97%E5%A4%A7%E5%B0%8F%E5%AE%9A%E4%B9%89%EF%BC%88C40_CODE_ARRAY_0_BLOCK_0_S128%EF%BC%89%E4%B8%8E%E8%AE%BE%E5%A4%87%E7%9A%84%E5%AE%9E%E9%99%85%E5%86%85%E5%AD%98%E6%98%A0%E5%B0%84%E4%B8%8D%E5%8C%B9%E9%85%8D%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E8%AF%95%E5%9B%BE%E4%BB%8E%E5%BD%93%E5%89%8D%E6%AD%A3%E5%9C%A8%E6%89%A7%E8%A1%8C%E4%BB%A3%E7%A0%81%E7%9A%84%E5%8C%BA%E5%9D%97%E4%B8%AD%E5%86%99%E5%85%A5%E6%88%96%E6%93%A6%E9%99%A4%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E4%B8%8E%E9%97%AA%E5%AD%98%E6%8E%A7%E5%88%B6%E5%99%A8%E6%89%87%E5%8C%BA%E8%BE%B9%E7%95%8C%E4%B8%8D%E4%B8%80%E8%87%B4%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E6%88%91%E9%99%84%E4%B8%8A%E4%BA%86%E4%B8%80%E5%BC%A0%E5%9B%BE%E7%89%87%EF%BC%8C%E6%9B%B4%E8%AF%A6%E7%BB%86%E5%9C%B0%E6%98%BE%E7%A4%BA%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E5%B9%B6%E8%87%B4%E6%84%8F%3C%2FP%3E%3CP%3E%E5%8A%A0%E5%86%85%E4%BB%80-%E5%B7%B4%E6%A0%BC%E7%93%A6%E7%89%B9%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20C40%20Code%20Memory%20Allocation%20%E2%80%93%20Hard%20Fault%20When%20Changing%20Sector%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHi%40GaneshBhagwat%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E5%BA%94%E8%AF%A5%E6%98%AF%E8%AF%BB%E5%86%99%E4%BA%8B%E4%BB%B6%E9%94%99%E8%AF%AF%EF%BC%88RWE%EF%BC%89%EF%BC%8C%E9%9C%80%E8%A6%81%E5%B0%86%E9%97%AA%E5%AD%98%E6%93%8D%E4%BD%9C%E6%94%BE%E5%85%A5%20SRAM%20%E4%BB%A5%E9%81%BF%E5%85%8D%20RWE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%E6%9C%AC%E5%B8%96%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K312-C40-Ip-SRAM-RTD-500-DS35%2Fta-p%2F2074245%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K312-C40-Ip-SRAM-RTD-500-DS35%2Fta-p%2F2074245%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
