C Language main()
C Language main()
1,157件の閲覧回数
QJ_HAPPY
Why is the endless loop in the main function is :
for (;;)
if (exit_code != 0)
break;
return exit_code;
and What causes exit_code = -1?
2 返答(返信)
1,144件の閲覧回数
JRoberto
Hi @QJ_HAPPY
The code that you get from the main function is just a template. That you can use or not.
Normally, you want the software of an embedded system to execute constantly and so, an infinite loop can help you there.
Returning different values that 0 like, return 1 or return -1 can mean that function finished returning error. But this is not mandatory and it's just a way to evaluate the execution of a function. Anyway you can give it the meaning you need.
Best Regards and Happy Coding!
1,076件の閲覧回数
QJ_HAPPY
Thank you for your timely reply. I want to know why I will return - 1 error. Generally, 0 should not be returned if there is no error
