Build Error
Build Error
akuma218
While Building an example project on s32ds platform I am getting the below errors.
I would be highly grateful if someone can help me with this or tell me the process how we can resolve this. @nxpnxp
PetrS
be sure you open mex file, click on Update Code button, resolve all config tool errors, if appear and Update Code again.
BR, Petr
akuma218
I have resolved all the errors present in the configuration tools. But, I am still getting errors related to "standardtypes.h" file not present.
@PetrS @nxp
PetrS
so you just started to create new project from example, do only necessary modifications in config tools and still this RTD demo example cannot be compiled?
What is the S32DS and RTD you have?
BR, Petr
akuma218
I have downloaded the example project from the website and trying to build it on the IDE. I have resolved all the errors present in the configuration tools as suggested by you. But, Still I am facing the same issues.
@PetrS @nxpnxp
PetrS
which example project from website you are pointing to? Is it based on the same RTD you have installed? If you create new project from example and select available RTD demo are you able to go through update code and building?
Regards, Petr
