Ammclib using with s32k344
ソリューションへジャンプ
2,678件の閲覧回数
Albatros
Currently, I am working on an electric power steering project. Would it be a problem to use Ammclib in that project without accessing source codes and using only what NXP serves me (header files)? Am I going to need to change the source codes if I want to drive my motor?
Note: I am going to use a PMSM motor and I will try to drive it with Field oriented control technic.
タグ(4)
2,653件の閲覧回数
JRoberto
@Albatros
Depending on your implementation you can develope your project with the functions offered by the  Ammclib (headers and compiled files), but if you want to see/edit the Ammclib's functions, then you need to buy the license to do so.
Josue R. Gonzalez
2 返答(返信)
2,654件の閲覧回数
JRoberto
@Albatros
Josue R. Gonzalez
2,561件の閲覧回数
zhouwenxiang
hello ,now I am working on motor control ,and I am using AMMCLIB to let us PMSM work, I want to know more about the AMMCLIB. How can I check the source code of the AMMCLIB?  If I need to buy a license, where can I buy it? Thank you.
