About Read While Write Error
225 次查看
Jojo_Hu
hi, The memory distribution of Application and Bootloader are as follows. If we want to erase and write Application while running in bootloader, and Ac load at startup has been enabled, do we need to configure the on-core MPU as mentioned in the second picture in PreTaskHook ?
194 次查看
davidtosenovjan
Yes, it seems correct. If you are using MPU, I would recommend to setup it mentioned way.
