About DSP
About DSP
3,978件の閲覧回数
letseatorange
In this MCU integrated DSP, I would like to know how we can use it? Thanks!
5 返答(返信)
3,709件の閲覧回数
robertboys
Hello
Cortex-M4 does not have a DSP engine as such - but rather DSP instructions.
ARM provides free DSP libraries.  They are called CMSIS-DSP.  Documentation is here:  CMSIS DSP Software Library
Sources and examples are provided.  If you get the free evaluation version of Keil MDK:  You can download and play with the examples.  www.keil.com/NXP  and ARM Version 5.23 Evaluation Software Request
CMSIS-DSP is stored on GitHub here:  https://github.com/ARM-software/CMSIS_5
There is support for Keil, GCC, IAR (this might come from IAR ?) and Cosmic (Cosmic Software - ARM Cortex Products )
CMSIS-DSP has an Apache 2.0 license so is really free.
RTX RTOS is another free offering from ARM.  RTX has a BSD  (new RTX 5 has the Apache 2.0 license) - it is also on GitHub and inside Keil MDK).  Sources are provided as well.
There are ports for Keil, GCC, Cosmic and IAR plus maybe others I don't know about.
See RTX Implementation for more information on RTX.
Hope this helps.
Bob Boys
ARM
3,709件の閲覧回数
letseatorange
I would like to know how to transplant CMSIS library to S32DS
3,709件の閲覧回数
robertboys
Hello
I have ported our usual DSP example (created by Bruno Coppi in Italy) to the S32K-144 using Keil uVision.
The Keil DSP project files are here along with the latest version of the S32K lab:
www.keil.com/appnotes/docs/apnt_299.asp    See page 23 in the lab.
You can use the evaluation version MDK Lite to try this program out.  It is free and not time-bombed.
www.keil.com/mdk5/install
This is a working example that you can see how Bruno put it together and using this, you ought to be able to port it to any tools of your choice.  For S32DS I assume you will need one of the DSP GCC libraries (or the source files).
They are here:  C:\Keil_v5\ARM\PACK\ARM\CMSIS\5.0.1\CMSIS\Lib\GCC and on GitHub.
Use OpenSDA in CMSIS-DAP mode or with any Keil ULINK or Segger J-Link for best results.  Directions are in the lab to configure and use these features.
Bob Boys
ARM
3,709件の閲覧回数
danielmartynek
This question has been answered in your second thread on DSP.
3,709件の閲覧回数
letseatorange
I would like to know how to transplant CMSIS library to S32DS ,THANKS
