AN5408, S32K1xx Clock Calculator Guide - excel file missing
6,265 次查看
cipriansalagean
Does anyone know where I can find the associated file AN5408SW for Application Note "AN5408, S32K1xx Clock Calculator Guide".
The link on NXP page is dead - Page Not Found
https://www.nxp.com/docs/en/application-note-software/AN5408SW.zip
5,736 次查看
dianabatrlova
Hi Ciprian,
Thank you for the report.
The available SW for AN5408 and other application notes can be downloaded from below link.
32-bit Automotive General Purpose MCUs|NXP
See section Application Note:
AN5408SW:
https://www.nxp.com/webapp/Download?colCode=AN5408SW&Parent_nodeId=1432753525521684987930&Parent_pag...
I hope it helps you.
Diana
5,737 次查看
dianabatrlova
Hi Ciprian,
AN5408SW:
Diana
5,736 次查看
cipriansalagean
Thank you for the links.
Ciprian
