AES Key import returns HSE_SRV_RSP_NOT_ALLOWED
1,050件の閲覧回数
kerti1
1.I had an issue while exporting the AES key. First I defined my AES key in a global variable and imported into the RAM. Then I tried exporting the key from that location. I am sure that RAM keys can be exported. But I am getting an error as HSE_SRV_RSP_NOT_ALLOWED.
Please find the code snippet for export issue
2. What exactly the SHE keys are for. Can I change my MASTER_Key using the keytype SHE key.
999件の閲覧回数
lukaszadrapa
Hi @kerti1
1. Symmetric keys can be exported only in encrypted form, so you need to select cipher keyhandle:
 2. HSE emulates SHE commands for users who want to comply with SHE specification 1.1. It's quite old specification issued by HIS members in 2009.
MASTER_ECU_KEY can be updated using standard secure key update protocol with knowledge of original MASTER_ECU_KEY.
Lukas
