Uart to SENT protocol transmitter
Often we need to implement a SENT receiver in order to read the information sent by some sensors.
It is useful to have the possibility of transmitting different message patterns in order to test your implementation.
With this project you can transmit via a computer terminal a group of messages (up to 64).
The project runs on a S32K144 EVB board, the output signal goes through J206 pin.
%3CLINGO-SUB%20id%3D%22lingo-sub-1129291%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUart%20to%20SENT%20protocol%20transmitter%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129291%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOften%20we%20need%20to%20implement%20a%20SENT%20receiver%20in%20order%20to%20read%20the%20information%20sent%20by%20some%20sensors.%3C%2FP%3E%3CP%3EIt%20is%20useful%20to%20have%20the%20possibility%20of%20transmitting%20different%20message%20patterns%20in%20order%20to%20test%20your%20implementation.%3C%2FP%3E%3CP%3EWith%20this%20project%20you%20can%20transmit%20via%20a%20computer%20terminal%20a%20group%20of%20messages%20(up%20to%2064).%3C%2FP%3E%3CP%3EThe%20project%20runs%20on%20a%20S32K144%20EVB%20board%2C%20the%20output%20signal%20goes%20through%20J206%20pin.%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎10-11-2019 06:51 AM
Updated by:
