RAM March c test assembly files and example project for S32K118 (GCC compiler)
Search instead for
No ratings
You can find here a reference code for a march c software test in order to test RAM memories
Tags (2)
Comments
Do you have example code to test flash (code) too during running time?
Thanks and best regards
He Wei
Hello He Wei,
Unfortunately not. The RAM march tests are based on writing certain bit patterns to RAM and read them out correctly. I don't know how this can be done in flash without impacting the flash endurance.
Version history
Revision #:
1 of 1
Last update:
‎09-17-2019 07:09 AM
Updated by:
