Example Siul2_Port_Ip_Example_S32K344_ITCM_DTCM S32DS3.4 RTD300
* Detailed Description:
* Example is based on Siul2_Port_Ip_Example_S32K344 and its purpose it to show
* how to integrate ITCM and DTCM memories to the project.
* Modification has been done in following files:
* - main.c
* - startup_cm7.s
* - linker_flash_s32k344.ld
* In the main function, function is placed to ITCM memory and executed. Also
* data field in placed to DCTM and accessed.
* Test HW: S32K3X4EVB-Q172
* MCU: S32K344
* Compiler: S32DS3.4
* SDK release: PlatformSDK_S32K3_3_0_0
* Debugger: Lauterbach Trace32
Revision History:
Ver Date Author Description of Changes
0.1 Apr-04-2019 David Tosenovjan Initial version
附件
%3CLINGO-SUB%20id%3D%22lingo-sub-1605107%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%A4%BA%E4%BE%8B%20Siul2_Port_Ip_Example_S32K344_ITCM_DTCM%20S32DS3.4RTD300%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1605107%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CPRE%20translate%3D%22no%22%3E********************************************************************************%3CBR%20%2F%3E*%20Detailed%20Description%3A%3CBR%20%2F%3E*%20Example%20is%20based%20on%20Siul2_Port_Ip_Example_S32K344%20and%20its%20purpose%20it%20to%20show%3CBR%20%2F%3E*%20how%20to%20integrate%20ITCM%20and%20DTCM%20memories%20to%20the%20project.%20%3CBR%20%2F%3E*%20%3CBR%20%2F%3E*%20Modification%20has%20been%20done%20in%20following%20files%3A%3CBR%20%2F%3E*%20-%20main.c%3CBR%20%2F%3E*%20-%20startup_cm7.s%3CBR%20%2F%3E*%20-%20linker_flash_s32k344.ld%3CBR%20%2F%3E*%20%3CBR%20%2F%3E*%20In%20the%20main%20function%2C%20function%20is%20placed%20to%20ITCM%20memory%20and%20executed.%20Also%20%3CBR%20%2F%3E*%20data%20field%20in%20placed%20to%20DCTM%20and%20accessed.%3CBR%20%2F%3E*%20%3CBR%20%2F%3E********************************************************************************%3CBR%20%2F%3E*%20Test%20HW%3A%20S32K3X4EVB-Q172%3CBR%20%2F%3E*%20MCU%3A%20S32K344%3CBR%20%2F%3E*%20Compiler%3A%20S32DS3.4%3CBR%20%2F%3E*%20SDK%20release%3A%20PlatformSDK_S32K3_3_0_0%3CBR%20%2F%3E*%20Debugger%3A%20Lauterbach%20Trace32%3CBR%20%2F%3E********************************************************************************%3CBR%20%2F%3ERevision%20History%3A%3CBR%20%2F%3EVer%20Date%20Author%20Description%20of%20Changes%3CBR%20%2F%3E0.1%20Apr-04-2019%20David%20Tosenovjan%20Initial%20version%3CBR%20%2F%3E*******************************************************************************%2F%3C%2FPRE%3E%0A%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎02-24-2023 01:35 AM
更新人:
