Example S32K358 GMAC lwIP FreeRTOS RDBESS S32DS 3.6.1 RTD600
* Detailed Description:
* Updated the example lwip_FreeRTOS_s32K358 to enable pinging the lwIP stack from the command window
* on the board RD-BESSK358BMU
*ping 192.168.0.209
*Pinging 192.168.0.209 with 32 bytes of data:
*Reply from 192.168.0.209: bytes=32 time=2ms TTL=255
*Reply from 192.168.0.209: bytes=32 time=1ms TTL=255
*Ping statistics for 192.168.0.209:
* Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
*Approximate round trip times in milli-seconds:
* Minimum = 1ms, Maximum = 2ms, Average = 1ms
* RD-BESSK358BMU:
* - All jumpers in default positions
* - SW2 needs to be ON
* Configuration:
* - Updated pin configuration
* - Updated GMAC clocks
* - IP address set to 192.168.0.209 and enabled UDP_ECHO, etc.
* - Eth_43_GMAC: configured for RGMII 1G
* - Added DIO
* main.c
* - Updated only the header
* device.c
* - Added RTD workaround for DCMRWF* registers
* test.c
* - Commented out the code that shuts down the TCP/IP stack after its predefined timeout
* - Added LED task
* Test HW: RD-BESSK358BMU SCH-91654 REV B1
* MCU: S32K358
* Debugger: Lauterbach Trace32
* Target: internal_FLASH
* EVB connection: RJ45 <-> USB-to-Ethernet adapter <-> Laptop DELL, Windows 11
%3CLINGO-SUB%20id%3D%22lingo-sub-2410521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20S32K358%20GMAC%20lwIP%20FreeRTOS%20RDBESS%20S32DS%203.6.1%20RTD600%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CPRE%3E%3CFONT%20size%3D%222%22%3E*%20Detailed%20Description%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20Updated%20the%20example%20lwip_FreeRTOS_s32K358%20to%20enable%20pinging%20the%20lwIP%20stack%20from%20the%20command%20window%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20on%20the%20board%20RD-BESSK358BMU%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*ping%20192.168.0.209%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*Pinging%20192.168.0.209%20with%2032%20bytes%20of%20data%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*Reply%20from%20192.168.0.209%3A%20bytes%3D32%20time%3D2ms%20TTL%3D255%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*Reply%20from%20192.168.0.209%3A%20bytes%3D32%20time%3D1ms%20TTL%3D255%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*Reply%20from%20192.168.0.209%3A%20bytes%3D32%20time%3D1ms%20TTL%3D255%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*Reply%20from%20192.168.0.209%3A%20bytes%3D32%20time%3D1ms%20TTL%3D255%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*Ping%20statistics%20for%20192.168.0.209%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20Packets%3A%20Sent%20%3D%204%2C%20Received%20%3D%204%2C%20Lost%20%3D%200%20(0%25%20loss)%2C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*Approximate%20round%20trip%20times%20in%20milli-seconds%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20Minimum%20%3D%201ms%2C%20Maximum%20%3D%202ms%2C%20Average%20%3D%201ms%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20RD-BESSK358BMU%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20-%20All%20jumpers%20in%20default%20positions%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20-%20SW2%20needs%20to%20be%20ON%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20Configuration%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20-%20Updated%20pin%20configuration%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20-%20Updated%20GMAC%20clocks%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20-%20IP%20address%20set%20to%20192.168.0.209%20and%20enabled%20UDP_ECHO%2C%20etc.%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20-%20Eth_43_GMAC%3A%20configured%20for%20RGMII%201G%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20-%20Added%20DIO%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20main.c%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20-%20Updated%20only%20the%20header%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20device.c%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20-%20Added%20RTD%20workaround%20for%20DCMRWF*%20registers%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20test.c%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20-%20Commented%20out%20the%20code%20that%20shuts%20down%20the%20TCP%2FIP%20stack%20after%20its%20predefined%20timeout%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20-%20Added%20LED%20task%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20------------------------------------------------------------------------------------------------%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20Test%20HW%3A%20RD-BESSK358BMU%20SCH-91654%20REV%20B1%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20MCU%3A%20S32K358%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20Debugger%3A%20Lauterbach%20Trace32%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20Target%3A%20internal_FLASH%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20EVB%20connection%3A%20RJ45%20%26lt%3B-%26gt%3B%20USB-to-Ethernet%20adapter%20%26lt%3B-%26gt%3B%20Laptop%20DELL%2C%20Windows%2011%3C%2FFONT%3E%3C%2FPRE%3E%0A%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎09-02-2026 03:29 AM
Updated by:
