Compile the sample project within MCAL, like S32K14X_MCAL4_2_RTM_1_0_0
   If you try to compile the sample project within S32K14X_MCAL4_2_RTM_1_0_0, you should take care of the command if you use Linaro.
   After you set the environment of compiling and run the command under command window, you should enter
   "launch.bat MODE=USER TOOLCHAIN=linaro"
   NOT
   "launch.bat MODE=USER TOOLCHAIN=LINARO"
   The command is case sensitivity.
Hope you can compile the project successfully.
Cheers!
Oliver
Tags (3)
%3CLINGO-SUB%20id%3D%22lingo-sub-1122742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECompile%20the%20sample%20project%20within%20MCAL%2C%20like%20S32K14X_MCAL4_2_RTM_1_0_0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3BIf%20you%20try%20to%20compile%20the%20sample%20project%20within%26nbsp%3BS32K14X_MCAL4_2_RTM_1_0_0%2C%20you%20should%20take%20care%20of%20the%20command%20if%20you%20use%20Linaro.%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3BAfter%20you%20set%20the%20environment%20of%20compiling%20and%20run%20the%20command%20under%20command%20window%2C%20you%20should%20enter%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%22launch.bat%20MODE%3DUSER%20TOOLCHAIN%3Dlinaro%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%3CSTRONG%3ENOT%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%22%3CSPAN%20style%3D%22text-decoration%3A%20line-through%3B%22%3Elaunch.bat%20MODE%3DUSER%20TOOLCHAIN%3D%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%20text-decoration%3A%20line-through%3B%22%3ELINARO%3C%2FSPAN%3E%3C%2FSPAN%3E%22%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20%26nbsp%3BThe%20command%20is%20case%20sensitivity.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHope%20you%20can%20compile%20the%20project%20successfully.%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECheers!%3C%2FP%3E%3CP%3EOliver%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎07-30-2020 01:53 AM
Updated by:
