why bsp33 /sys/devices/system/cpu/cpufreq is empty?
2,149 次查看
tomhan
hi,
I has set config as follow,but cpufreq is empty:
# CONFIG_UCLAMP_TASK is not set
# CONFIG_ENERGY_MODEL is not set
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_GOV_ATTR_SET=y
CONFIG_CPU_FREQ_STAT=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL=y
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_GOV_CONSERVATIVE is not set
CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
# CPU frequency scaling drivers
# CONFIG_CPUFREQ_DT is not set
CONFIG_ARM_SCMI_CPUFREQ=y
CONFIG_PM_OPP=y
3 回复数
2,129 次查看
MayanksPatel
Hi @tomhan,
Thank you for reaching out to us.
Can you please share board details here for which board you are trying cpufreq?
2,125 次查看
tomhan
hi,
s32g274a bsp33,thanks
2,098 次查看
MayanksPatel
Hi @tomhan,
BSP33 release does not support Frequency Scaling. In BSP35 added support for this.
Mayank S Patel
