source.codeaurora.org is unavailable
已解决
跳至解决方案
2,890 次查看
jiahaisheng
I am in the github codebase:
https://github.com/nxp-auto-linux/ipc-shm-us/tree/release/SW32R45_IPCF_4.4.0_D2303
To download the code for /ipc-shm-us/common/,
use the command: git submodule update --init --recursive
will indicate fatal: unable to access 'https://source.codeaurora.org/external/autobsps32/ipcf/ipc-shm/': Could not resolve host: source.codeaurora.org,
how do I get the code under ipc-shm-us/common/?
Thanks!
1 解答
2,799 次查看
nxf92108
Yes, ipc-shm-us/common is the code from ipc-shm/.
Please, let us know.
在原帖中查看解决方案
2 回复数
2,883 次查看
jiahaisheng
Or is the code under ipc-shm-us /common/ the code under ipc-shm/?
2,800 次查看
nxf92108
