source.codeaurora.org is closed, where is the nxp source code? how to search in new address?
ソリューションへジャンプ
1,442件の閲覧回数
hulk101
source.codeaurora.org is closed, where is the nxp source code? how to search in new address?  I am using linux bsp 32.0 user manual for s32g2 platforms.
S32G-VNP-RDB2
1,416件の閲覧回数
chenyin_h
Hello, @hulk101
Thanks for you reply.
For example, when you want to access the Linux source code, the URL from your documents would be https://source.codeaurora.org/external/autobsps32/linux , currently, it could be https://github.com/nxp-auto-linux/linux
If possible, I suggest using newer BSP version, which may be with more bug fixes and new features.
Chenyin
3 返答(返信)
1,416件の閲覧回数
chenyin_h
Hello, @hulk101
Chenyin
1,430件の閲覧回数
chenyin_h
Hello, @hulk101
Thanks for your post.
Yes, the older BSP is deployed on codeaurora, since it is closed, the newer version source code could not be found via https://github.com/orgs/nxp-auto-linux/repositories?type=all
You may check correct repo according to the requirements.
Chenyin
1,429件の閲覧回数
hulk101
Thankyou,
Could you please help me find the newer version of the source code? The document's that I'm referring to are showing the same repo's.
